Old 11-12-2010, 04:12 PM
foxrider714's Avatar
Member #8759
hard time starting!!!! help!
ok so the bike has a very hard time starting cold i guess cause when ever i get it to run it will start fine with the key or pull start.. i cleaned the carb like 3x and i have spark but i am going to buy a new one anyway....somebody help!!!
Old 11-12-2010, 04:14 PM
North Branch's Avatar
Member #1986
Dumb question... what kind of bike?
Old 11-12-2010, 04:24 PM
Member #8759
lol my bad..its a 2004 TB 250
Old 11-12-2010, 05:03 PM
Member #1986
Well, you said it starts fine after it's been warmed up, so I'm guessing that the compression is OK. They do need a minimum amount of compression to start. The coil must be pretty decent too. Normally if they are weak, it shows more when they are hot.
Have you verified that the choke cable and choke are working correctly?
Have you tried different pulls of the choke when trying to start cold... like halfway, all the way out?
Have you pulled the plug right after trying to start it to see if getting too much, or too little gas?
Old 11-14-2010, 09:12 AM
Member #8759
you know what when i do pull the choke it feels like it dont do nothing cause i pulled it out when it was running and the bike did not start to die..and i looked up the fule/air and i have it 2.5 turns out but then some people said 1.5 turns out but anyway when i do get it stared it runs fine.. i will look and try and fix the choke
Old 11-14-2010, 11:54 AM
Member #1986
Yep, make sure the choke cable is not froze (rusted tight) or that it's not broke. If either are the case, you need to get it adjusted when you're done.
2004 polaris ranger hard starting
2010 polaris ranger hard start when hot
2010 polaris ranger hard to start
2010 polaris ranger wont start when hot
atv has hard time starting
hard starting polaris ranger
polaris atv hard time starting
polaris ranger 400 hard starting
polaris ranger 400 hard to start
polaris ranger hard start cold
polaris ranger hard starting when hot
polaris ranger not starting
polaris ranger starts hard
polaris ranger will not start
polaris ranger will not start when hot
polaris trail blazer hard start
why does my polaris trail blazer start up rough
425 xpedition hard starting lennard ATV Repair and Maintenance 4 10-29-2010 06:21 PM
01 400 sportsman hard time with cold start chris.wishart ATV Repair and Maintenance 2 08-18-2010 03:18 AM
hard starting sportsman 90cc Fessman ATV Repair and Maintenance 3 04-22-2010 11:03 AM
hard starting sportsman 90cc Fessman ATV Repair and Maintenance 1 12-25-2009 02:28 PM
Outlaw 525 hard starting canucklehead ATV Repair and Maintenance 3 12-02-2009 12:12 AM
