Old 11-13-2010, 03:04 PM
RobinHood's Avatar
Member #9099
97 300 Intermittent start issues
Hello everyone, this is my second post. (first was in the introduction section)
I spent the day looking over my newly acquired Polaris. I have been having trouble with starting the bike.
I took the carb out today and replaced all the components with the rebuild kit I ordered. Replaced the spark plug, ensured it was getting spark and gapped correctly. Finally, I charged the battery.
When running, the bike pulls hard and runs great. NO missing, or sputtering at full throttle.
The problem is, the bike will die if it is allowed to idle for a couple minutes. Also, if I come to a hard stop the bike dies. In both instances, it is impossible to get started again. However, if it sits for 30 minutes or more, it will fire right back up.
Any thoughts? Thanks in advance.
Old 11-13-2010, 07:24 PM
Old 11-13-2010, 07:33 PM
mkeddie's Avatar
Member #4866
Send a message via Skype™ to mkeddie
sounds like maybe the motor is getting flooded
did it run ok before the rebuild???
2010 850 XP EPS Stealth Black
from dealer
2500lb. winch (with wireless remote)____60" Glacier® II Plow System with extras___Lock & Ride® Front Cargo Box____Rear Rack Extender___Moose hand and throttle warmers
HID Plug and Play Light Kit for 550/850(www.theatvsuperstore.com) lower lights tinted with 20% window tint (still brighter than stock but not blinding bright)
Front & Rear A-Arm Guards XP550/850 2010(www.theatvsuperstore.com)
28" zillas on stock 14" rims(http://www.4wheelparts.com)_____26" stock tires on itp ss212 14" thanks SNW629
Deluxe Front/Rear Brushguard(http://www.superatv.com/)
3 in 1 Polaris atv hitch from (www.theatvsuperstore.com) might i add it was a gift they sent me just for buying some stuff
Galls® 100W Remote Siren (http://www.galls.com/)
lots of lights
motor cycle radio
(still to come Wes Standard(rear seat and storage), dalton clutch kit, 2 inch lift, stealth snorkel kit if they ever make them for the 2010 )
Old 11-14-2010, 06:55 AM
RobinHood's Avatar
Member #9099
mkeddie- Yes it ran fine before, as it does now once it gets started. It was doing this starting thing prior to the rebuild. I thought maybe the floats were sticking and the jets were clogged.
It is random. One time the starter will work, then it wont. One time the pull star will work, then it wont. When it does fire up, it is instantly. Hit the starter and boom, it is running like a champ. When it doesnt work, it sounds like I am going to burn the starter up.
If the carb has been gone through, what could be causing the flooding if that is the issue.
Old 11-21-2010, 04:10 AM
3inthedirt's Avatar
Member #9037
Ignition. Check the wire to the plug with a voltmeter. Move it all around while checking. Other than that look for wire with no insulation and test every one involved with ignition, including grounds. If that proves to be fine, then replace the cdi. The fact that it acts up when hot and works again when cold is a tell tale sign of ignition/wiring.
intermittent starting polaris
polaris 300 starts intermittently
polaris 300 will not run full throttle
polaris intermittent start
polaris intermttent
polaris sportsman intermittent starting cold
polaris sportsman random start issues
2009 850 XP intermittent power loss earthresin Polaris XP 6 12-31-2010 02:10 PM
210 550 intermittent EPS warning light Seismic_Pirate Polaris XP 8 08-30-2010 03:57 AM
95 700 Sportsman intermittent pod failure "HELP" bigtodd ATV Repair and Maintenance 3 02-21-2010 05:35 AM
2008 Sportsman 500...Intermittent Brake pull??? Fattonz ATV Brakes & Suspension 5 02-15-2010 05:47 PM
Engine start issues cold dirtdobbercracker Polaris Sportsman 0 12-19-2009 08:07 PM
