Idle Problem - Polaris ATV Forum
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Trail Boss
Polaris Trail Boss Discussions for the Polaris Trail Boss
Old 08-08-2011, 10:50 AM
Trapp's Avatar
Member #17500
Idle Problem
I just cleaned the carb on my 2003 Trail Boss 330 and it starts but it idles really high. When I turn the idle screw to lower the idle it doesnt do anything it just stays the same. The weird thing is that when I pull the choke the rpms drop
Old 08-08-2011, 01:53 PM
4getful2's Avatar
Member #1234
Check the throttle cable ,to make sure it is not binding up somewhere.
Old 08-08-2011, 04:52 PM
Trapp's Avatar
Member #17500
Thanks! I just had to adjust the throttle cable a bit and now it runs like a champ.
Thanks again for the quick reply!
Old 11-20-2011, 10:10 AM
felony's Avatar
Member #20584
Send a message via AIM to felony Send a message via Yahoo to felony
OMG! i have an 03 325. mine revs super high with choke just barely out, and pulled out all the way the idle drops to almost wanting to die. i thaught it was suppose to do that? also it wont stay running even when warmed up if in put the choke all the in. so in order to ride it i have to have choke pulled all the way out.
i baught this quad a week ago. it had been sitting for 3 years.
Old 11-24-2011, 07:00 AM
Diesel man 03's Avatar
Member #7294
felony, sounds like you need a carb cleaning, jets are probably plugged.
Old 11-24-2011, 09:55 AM
felony's Avatar
Member #20584
Thanks. i just changed all the fluids and filters and spark plug. i never thaught about the carberator.
2005 polaris 330 magnum idle speed
250 trailboss idle to high unless choke on
330 trail boss revs to high
high idle problems on polaris 325 trail boss
idle speed adjustment for 330 polaris
polaris 330 magnum wont idle when cold
polaris 330 trail boss 2006 wont run when cold
polaris 330 will not idle unless choke is on
polaris magnum 330 wont idle
polaris magnum high idle
polaris magnum idles high
trail boss high idle
Problem with idle mix screw Natureboy Polaris Sportsman 10 08-15-2011 04:27 AM
Idle problem QuadCorey Polaris Scrambler 3 07-03-2011 09:12 AM
CVT Problem... Belt slap at Idle... 97 Xplorer iif3lixii Polaris Magnum 2 07-23-2010 05:58 PM
1994 explorer 400L 4X4 idle problem GREYWOLF1957 ATV Repair and Maintenance 3 11-27-2009 10:32 PM
Cold Start Idle Problem - Suggestions Atv Dad Polaris Scrambler 4 11-08-2009 02:50 PM
