Adjusting Rear Foot Brake - Polaris ATV Forum
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Trail Boss
Polaris Trail Boss Discussions for the Polaris Trail Boss
Old 08-25-2011, 07:12 PM
jakes99trailboss's Avatar
Member #17012
My rear foot brake doesn't work it just sinks to the floor when you step on it. In the manual, it says it is a mechanical floating disc brake. How do I adjust it to make it work? There is a rod that goes into a box and there is a nut which looks like you can adjust it, I am just not sure how. Also, there is a brake fluid line coming from the reservoir on the handlebars to it.
Old 08-25-2011, 10:31 PM
Razorback's Avatar
Member #4649
They're not adjustable. Just works off of hydraulic pressure like most other brakes. Possibly time to change the fluid and bleed the lines, or the master cylinder could have gone out on you.
2006 Sportsman 450
HD springs
Front Brushguard
3 headlight mod
55w driving lights
Old 08-26-2011, 02:56 AM
cwlongshot's Avatar
Well the foot pedal/rear brake may not be adjustable...The rear brakes are!
When installing new pads on my '00 TB I found I had to adjust the spacing on the pads with the caliper. At first I did not realize this and threw the pads in and buttoned it up.... I had NO pedal!! I took it back apart and looked at what I had done and found I needed to "screw" in the caliper to a correct distance between the pads and disc. Once accomplished, I had a pretty good pedal again....
Have you changed the pads? Do you have a manual? Its all outlined there.
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
Old 08-26-2011, 03:49 AM
SeanE1987's Avatar
Member #16252
My 98 xplorer has one, there should be a bolt with a jam nut on it, loosen the jam nut, turn the bolt in (both need 7/16" wrenches) till you have a good pedal, then tighten the jam nut. I believe there is even a spec for it, not sure what it is though, just make sure the brake doesn't drag.
I am here: http://maps.google.com/maps?ll=43.092705,-75.706301
Mine- 2011 Sportsman X2 550 With EPS!!-Mile Marker 2500lb Winch, Guru Brush Guard, 3000K HID's, PIAA Driving Lights, Autometer Phantom Oil Temperature, Coolant Temperature, and Voltmeter Gauges, Polaris Low Lock and Ride windshield, Acerbis Handguards, Symtec Heated Grips and Thumb warmer, 2+2 gallon Rotopax Fuel packs, Warn 60" Provantage Plow w/ Power Pivot
Hers- 2012 Sportsman 550XP EPS Blue Fire LE 27" ITP Mudlites on ITP SS212 Wheels, Polaris 2500 lb winch
Just Because- 2000 Magnum 325 2x4
Old 08-26-2011, 08:14 AM
broman's Avatar
Member #17544
+1
Old 08-26-2011, 10:52 AM
sfrasher's Avatar
Member #13967
My 01 Trail Boss sunk to the floor. I had to bleed the line and it worked great. The line at the bleeder was plugged, so had to clean that out first.
If a 99 is like my 01, the hand brake is on the left handlebar and has it's own reservoir. It's bleeder is the one on the left on the rear axle. The hand brake controls both front wheels and the rear axle.
The foot brake is on the right side and has it's reservoir about ankle high behind a cover. It's bleeder is the one on the right. It only brakes the rear axle.
The bleeders are a fitting inside a nut. Hold the nut with a wrench and loosen the fitting with another wrench. The first time we did mine, we turned the nut and fluid came up around the threads. Then we figured out that there was another fitting inside that nut.
Spence
2001 Trail Boss 325, AA model, since April 2011
"I've been sane, and I've been crazy. Crazy is more fun!"
Old 08-26-2011, 01:51 PM
Member #17012
Smile
Good news! I just got the rear brake working... It works perfect now! I just loosened the jam nut and tightened the bolt a little. Thanks a lot guys!
Old 08-31-2012, 08:36 AM
Kcamacho's Avatar
Member #29557
nice work. I think i am having the same issue. My pedal is to the floor, it still stops the brakes when i apply it but it doesn't seem to spring back up. My question is should the aux brake pedal rise back up after applying it like on a motorcycle or does the pedal move down as the brakes wear?
Thanks for any info.
Old 08-31-2012, 09:19 AM
Member #17012
Wow, blast from the past! It should spring back up. When it is sprung up, the top of the pedal should be parallel with the foot rest.
Old 08-31-2012, 10:57 AM
Kcamacho's Avatar
Member #29557
I figured it should. I'll have to check the manual but does anyone remember where the spring it that brings it back up? Or should the hydrolic pressure bring it back up?
Thanks for the reply.
1998 polaris trail boss rear brake adjustment
2000 polaris magnum 325 4x4 auxiliary brake not working
2004 polaris sportsman 400 rear brake ajustment
2006 polaris sportsman rear brake adjustment
adjusting back brakes on 04 polaris sportsman
adjusting brakes on 1998 polaris 300
adjusting rear brakes polaris 700 sportsman
brake adjustment on polaris fourwheeler
fore wheeler brake adjustment
how repair rear brake kawski atv 300 1999
how to adjust rear hydralic brakes o atv
polaris predator rear brake pedal adjustment
Polaris Rear Foot Brake upgrade Hit.The.Gas ATV Performance Modifications 15 11-01-2015 04:58 PM
foot brake problems DAHOOK ATV Repair and Maintenance 7 02-27-2012 08:07 PM
425 magnum foot brake WistfulSine398 ATV Brakes & Suspension 3 07-30-2011 08:08 AM
foot brake question Doty ATV Brakes & Suspension 5 01-25-2011 06:54 PM
foot brake line jhollen ATV Brakes & Suspension 5 12-04-2009 08:09 PM
