Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Trail Boss
Polaris Trail Boss Discussions for the Polaris Trail Boss
Old 02-01-2012, 05:16 PM
Palvader's Avatar
Member #22829
Send a message via Skype™ to Palvader
Trailboss 250 2x4 two-stroke backfiring
Hi all, I'm 16 and I bought my first ATV back in the late fall of 2011. My problem is I can't get it to stop backfiring! I just ordered a new carb rebuild/needle kit and will see if that will help to fix the problem. Any advise?
Old 02-01-2012, 07:43 PM
Old 02-01-2012, 08:31 PM
factionfx's Avatar
Member #20681
Does it backfire when you let off the throttle? If so, it could be that the throttle cable is #1 getting slightly stuck, or #2 it needs to be adjusted.
If it is getting stuck, it is emulating 'being stuck wide open', and trying to kill the engine while there is fuel being brought into the engine. (I had this problem on a 2001 Scrambler 400 after I bypassed the oil pump, but neglected to run a single throttle cable. the stock throttle cable is dual pull, one to pull on carb, one to pull on oil pump.) I ordered the single cable for it.
If yours is getting stuck, you need to try to lube it first. If that doesn't work you'll need to get a new throttle cable.
This video explains it better than I can put in words.
Video: Polaris ATV Thumb Throttle Maintenance Tips | eHow.com
Additionally, here is a link discussing the ETC.
Adjusting Throttle Control
Good luck!
2012 Sportsman 500, Red.
Old 02-01-2012, 09:22 PM
starpuss's Avatar
Member #16228
InTake Boot? Check for Hair Line CRacks
2005 polaris predator 500cc
1997 polaris xplorer 400
1977 yamaha it175cc
1994 Suzuki RM250
1982 Yamaha YZ250
Old 02-07-2012, 04:51 PM
Palvader's Avatar
Member #22829
update
Hi guys, thanks for the great advise. I checked the throttle/oil cable[s] and they were working great. I don't think the rubber intake boot has any cracks, but I will check that. I installed the rebuilt carb, a brand new airfilter, a new gasline, fuel filter, and oil filter. And it would not start! I checked the spark, and sure enough has intermittent spark only about once every 2-3 seconds! I took off the pullstart/side cover and the flywheel is stuck! My three-prong puller won't fit into the two holes in the flywheel. So I can't get at the stator. I'm wondering if some of the wiring is messed up. What should I check first?
Thanks a lot guys!
Peter
Old 02-12-2012, 04:45 PM
Palvader's Avatar
Member #22829
Hi guys, I just finished rewiring the lights and indicator-bulbs. I also remembered that (a month ago) when I replaced the coil and CDI box, I could not get the bottom half of the coil on tight, the wrenches just did not fit. So I tightened up the coil, and now it runs like a Honda! (A Honda chainsaw) It rips! Thanks for all the great advise!
Peter
Old 02-15-2012, 04:52 PM
Palvader's Avatar
Member #22829
Hi guys, I put a new battery in "The Boss" and fixed the headlight. When driving I heard a thumping coming from the clutch/belt shroud, I started to take the shroud off and then got interpreted. So I'm going to try to fix whatever that is tomorrow.
Peter Lindblom
The proud owner of an 89 trail boss
Old 03-06-2012, 10:45 AM
Palvader's Avatar
Member #22829
Hi guys, the bumping is just the nicks in the older belt making some noise, no big deal.
Peter Lindblom
Old 03-06-2012, 12:01 PM
antoniodef's Avatar
Member #11247
If your old belt is beat up, try getting a new one. You might be shocked at how much power you were missing from the old belt slipping.
2011 Trail Boss - HIDs SOLD
1986 quad 2x4 250cc
2 stroke backfire
2 stroke backfiring
2-stroke backfire when off throtle
250 polaris rebuid 250 trailboss
250 trailblazer back firing
how to fix a sticking throttle on a 1994 trail boss
oil pump for atv 250 honda 05
polaris 250 2stoke engine backfires
polaris atv sticking throttle
polaris trail boss backfires
polaris trailblazer 250 backfire
polaris trailblazer 250 backfiring
polaris trailblazer is backfiring
sticky throttle trail blazer 250
two cycle engine backfire
two stroke backfiring
two stroke engine backfire
two stroke polaris atv
why does my two cycle engine backfire
Tires for my 1998 Trailboss 250 2-stroke mlhend2002 ATV General Discussion 1 06-01-2011 11:08 AM
air screw on 1998 trailboss 250 2-stroke mlhend2002 ATV General Discussion 1 05-24-2011 06:06 PM
trailboss 2 stroke oil type bruce ATV Repair and Maintenance 4 12-29-2010 08:30 AM
what is a 1986 trailboss 250 4 or 2 stroke 1986polaristrailboss ATV General Discussion 7 08-31-2010 06:48 PM
250 Trailboss 2-Stroke Auto-Mixture kyleIHC ATV Repair and Maintenance 6 06-19-2010 08:51 AM
