Won't Start - 2 stroke - Polaris ATV Forum
Polaris Trail Boss Discussions for the Polaris Trail Boss
post #1 of 35 (permalink) Old 08-07-2012, 08:41 PM Thread Starter
Panhead's Avatar
1993 250 Trail Boss. New piston 1 yr. ago. Ran good. Died like it ran out of gas. r&r and Cleaned carb., no problem found. Only runs (poorly) when mixed gas is poured into spark plug hole, then dies. Spraying WD in carb throat does not work. WTF ?
Also, shortly before all this, the headlight glowed real bright corresponding to rpms and burnt out.So did the brights when tried them.
Need fun again. Any suggestions ?
Panhead is offline
post #2 of 35 (permalink) Old 08-08-2012, 05:29 AM
Bruce! is offline
post #3 of 35 (permalink) Old 08-08-2012, 08:58 AM
sfrasher's Avatar
This probably won't help, but I know that mine needs the ignition on before it will start. With the electrical problem you had, I would check out the ignition circuitry.
Spence
2001 Trail Boss 325, AA model, since April 2011
"I've been sane, and I've been crazy. Crazy is more fun!"
sfrasher is offline
post #4 of 35 (permalink) Old 08-08-2012, 12:24 PM
aknawful's Avatar
bad reeds? and a bad voltage regulator.
1998 Honda 300
2005 Predator 50
2012 Outlander 1000XT. Elka Stage 4s, Rox 2", Bearclaw HTRs.
aknawful is offline
post #5 of 35 (permalink) Old 08-09-2012, 07:00 PM
radchevy's Avatar
Thats the battle the 250's dont have reeds and when starting you blow fuel out the card and no vacuum is created. I am putting reeds on my 250 maybee the POS will start and run better.
Trail Boss 250 2x4
Trail Boss 350L 4x4
radchevy is offline
post #6 of 35 (permalink) Old 08-10-2012, 02:43 AM
aknawful's Avatar
there are 2 diff engines. trail boss(no reeds) and trail boss 2x4(reeds)
1998 Honda 300
2005 Predator 50
aknawful is offline
post #7 of 35 (permalink) Old 12-14-2012, 08:08 AM Thread Starter
Panhead's Avatar
It has been a year since first post on this problem. Took a break. Mine has no reeds. Where would they be , and look like what? The cylinder has port holes. I saw nothing like a reed when I rebuilt it. Must be invisible. SO. with no reeds, now what. Checked fuel flow, spark, ok. Runs poorly when gas squirted into spark plug hole and then dies. Problem started by acting like it ran out of gas.
Thanks for the suggestions , I'm learning two stroke .
Panhead is offline
post #8 of 35 (permalink) Old 12-14-2012, 03:05 PM
unclekato's Avatar
Could be bad crank seals or when you rebuilt it, did you put the arrow on the piston in the right direction?
2008 500 efi, oem front and rear bumpers rear rack 2500lb polaris winch
unclekato is offline
post #9 of 35 (permalink) Old 12-14-2012, 05:20 PM Thread Starter
Panhead's Avatar
Piston is installed correctly. It ran for a year .
Panhead is offline
post #10 of 35 (permalink) Old 12-18-2012, 07:17 AM Thread Starter
Panhead's Avatar
What else can it be ?
Thanks for the ideas, but so far they have not solved the no start problem. What else can prevent fuel from entering the combustion chamber and firing ? Please read the previous posts before answering.
One thing is for sure, if I put a Chevy V8 in it , I can fix it !
Panhead is offline
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Trail Boss
Scrambler 400cc 2 stroke or 500cc 4 stroke dsbummy Polaris Scrambler 11 05-12-2012 04:50 AM
2 stroke to 4 stroke engine swap? dstewart Around The Garage 4 12-26-2010 12:05 PM
Another Won't Start Question 400 2-stroke MediMan Polaris Sportsman 2 11-12-2010 03:28 PM
250 2 stroke wont start. dac71 ATV Repair and Maintenance 3 08-25-2010 05:37 PM
95 sportsman 2 stroke won't start gryyde84 Polaris Sportsman 1 08-14-2010 07:00 PM
