Plow setup - Page 2 - Polaris ATV Forum
Polaris Trail Boss Discussions for the Polaris Trail Boss
post #11 of 22 (permalink) Old 06-23-2013, 06:20 PM
FuntanaS's Avatar
Originally Posted by Anthonyk View Post
You are 1000% wrong
my eton was less than half the size and 2wd
zero issues plowing
you dont plow straight blade, its turned left or right
1000%
What is an eton? A little weight 2x4 trailboss will not be very good for plowing any measurable snowfall.
FuntanaS is offline
post #12 of 22 (permalink) Old 07-08-2013, 10:21 PM Thread Starter
Antdady's Avatar
This is what I found. Can I make it work? I have a winch attached.
Antdady is offline
post #13 of 22 (permalink) Old 07-08-2013, 10:28 PM Thread Starter
Antdady's Avatar
Btw, I've plow my driveway all last winter with a 92 Suzuki 160 2wd w/ chains. No problems. I'm sure the trail boss will have no problem.
Antdady is offline
post #14 of 22 (permalink) Old 07-09-2013, 06:40 AM
FuntanaS's Avatar
Where do you live? I'm in Minnesota and we can get a foot or more of wet snow in one shot. With my Sportsman 500 with a 50" plow there is no way in hell I could plow that in 2WD and that thing is probably about 1000lbs with rider and plow.
FuntanaS is offline
post #15 of 22 (permalink) Old 08-22-2013, 11:59 AM Thread Starter
Antdady's Avatar
I'm in northern Montana.
Sent from my iPad using Tapatalk - now Free
2009 Polaris Sportsman 550 XP
Tusk 2500lb Winch
Tusk 50" Subzero Snowplow
Ancla Tires
Tamarack Rear Locking Storage Box
Antdady is offline
post #16 of 22 (permalink) Old 08-22-2013, 01:21 PM
MustBeNice's Avatar
Sure can......
1) I'd tip the quad up on end, or lift up the front with a come-along with a garage rafter (or the like).
2) Find a spot in the center near or just in front of the foot pegs on the frame, that either a "U-bolt" or "Square U-bolt" can slip over.
3) Link up / center the push tube mounting bracket with these spots (u-bolts) and drill new holes in the mountign plate.
4) Assemble mounting plate to frame with U-bolts, hook up Plow and have a blast
If, No area for U'bolts over frame.....
5) Use the pictured small plates to "sanwhich" bracket to bottom of ATV via the skid/belly frame plates.
Matthew "MustBeNice"
MustBeNice is online now
post #17 of 22 (permalink) Old 08-30-2013, 05:20 PM
Deadbuck's Avatar
I found a Murray tractor plow set up on Craigslist for $40. Bought a harbor freight winch for $50. The back end of the plow push bar matched right up to my hitch on the back of the bike... My welding guy fashioned a mount on the front of the bike and a hook up on the plow to make it all good! Now just waitin for a good ole nor eastah to get here!
1990 Trailboss 250 4x4 2 Stroke magic!
4 Bear Claw tires
1 Front Rack
1 Rear Rack
1 Seat
Makes alota smoke!
HF 2000# winch
Repurposed Murray tractor plow($40 from Craigslist)
New front bumper
New front struts
New(to Old Red) fox rear shock
Interstate (yuasa?) AGM battery
Deadbuck is offline
post #18 of 22 (permalink) Old 09-11-2013, 12:40 PM Thread Starter
Antdady's Avatar
This is what I got. Works out pretty good too other than the fact I can't raise it as high as I want because of the up front clearance of the push tubes.
Tusk 2500lb Winch
Ancla Tires
Antdady is offline
post #19 of 22 (permalink) Old 09-11-2013, 01:36 PM
MustBeNice's Avatar
Looks good! Nice Work!!
Also looks like it mounted up about as I explained in my above post!
Should do the job nicely.
An idea to get more lift..... If you were to cut a small "V" wedge notch (3/8-1/2" wide at open end) out of the push tubes, but not all the way through the tube, just in front of the A-arms. Then bent together the cut openings and rewelded the tube together. Maybe braced on the inside between the tubes if needed. Doing this should buy you anothe 2-4" of "lift" for the blades ground clearance, but clearance under the machine will stay the same.
Hope that explanation is clear as mud!
Like the Glacier 3 Mid Mount push tubes.... like just behind the blade mount / swivel area in this picture....
post #20 of 22 (permalink) Old 09-11-2013, 01:44 PM Thread Starter
Antdady's Avatar
But wouldn't the push tubes drag when the blade was lowered all the way down?
Tusk 2500lb Winch
Ancla Tires
Antdady is offline
Go Back   Polaris ATV Forum > Polaris Model Specific Discussions > Polaris Trail Boss
Plow Setup Questions TNWB ATV General Discussion 11 10-20-2011 12:42 PM
Will this plow setup work? bvsouthc ATV General Discussion 2 09-06-2011 04:07 PM
Best plow setup to put on my Polaris ATV rbarm ATV General Discussion 32 08-15-2011 04:15 PM
Plow setup 4x4guy Polaris Sportsman 12 12-25-2010 04:04 AM
Question about DDT Enterprises plow setup Leftbridge Around The Garage 1 12-11-2010 01:55 PM
