12 850 pinion cover necessary??? - Polaris ATV Forum
post #1 of 20 (permalink) Old 02-16-2017, 02:40 PM Thread Starter
jehar46's Avatar
Just got a 12 850 ho and have been reading about the pinion cover deal. I plan on keeping it pretty much stock maybe someday some different 26" tires. Is it necessary to replace that cover? How many stock ATVs have broke them? Thanks for any advice
wifes
13 550xp
3500lb winch
polaris glacier3 plow
polaris front&rear bumpers
polaris hand Warmer's
mine
2012 850ho limited edition
Polaris hand warmers
Polaris 2500lb winch
Polaris front & rear bumpers
jehar46 is offline
post #2 of 20 (permalink) Old 02-16-2017, 02:42 PM
paulpolar600's Avatar
1900 miles on mine with stock size bighorns and I haven't had a problem.
Sent from my SAMSUNG-SM-G891A using Tapatalk
2011 Sportsman 500 HO
Custom Kimpex 2up seat
Kimpex Passenger Pegs
Polaris hand guards (Black)
27" Titan 589
Swamp XL exhaust
Hi Lifter 1.5" wheel spacers (Front & Rear)
paulpolar600 is offline
post #3 of 20 (permalink) Old 02-16-2017, 05:22 PM Thread Starter
jehar46's Avatar
Glad to hear that!! Thanks for reply
wifes
13 550xp
3500lb winch
mine
jehar46 is offline
post #4 of 20 (permalink) Old 02-16-2017, 11:49 PM
Battle_Design's Avatar
Get the cover.
850 XP
Battle_Design is offline
post #5 of 20 (permalink) Old 02-17-2017, 05:57 AM
Lollygagger77's Avatar
I have 3800 miles on mine and I had 27" XTR's and have not had any issues, but now I have 28" Terminators, so I think I will put it on mine, but for you, to be honest if you are smart about using 4 wheel drive you should be fine, like if your out on a frozen lake, just throw it in 4x4, I think some have had issues where they hammer it and the back tires spin so hard in 2 wheel drive and then the diff locks in randomly and Boom.. Also in Reverse at full throttle some have had issues, but I have a youtube showing me hammering it backing out of a hole and again no issues. (my youtube name is shaner7757 and it is the one I push out a stuck Grizzly)
Just make sure and change all the fluids if you haven't and I recommend using Polaris fluids, but most will recommend something after market...
NEW ADDITION: 2016 RZR 900S w/EPS
2012 Polaris 850 XP HO w/EPS
-28" Terminators
-HD Springs and JCCAPRI bushings
-QSC Clutch kit
-3500# Polaris winch with Synthetic Rope
-Polaris Front Brush Guard
-Polaris Lock n Ride front and rear storage
-Polaris Mid Lock n Ride Windshield (smoke)
-60" Warn ProVantage Plow
-Symtec Hand Warmers
-Quadrax Rear seat w/foot rest kit from ATVSUPERSTORE - Square Tube
Old Machines:
2006 Sportsman 800 EFI, 2005 Sportsman 700 Carb, 2004 Sportsman 500HO Carb, 2000 Sportsman 500 Carb
Lollygagger77 is offline
post #6 of 20 (permalink) Old 02-17-2017, 06:52 AM
moore3cam's Avatar
I have been rolling the dice, no cover, 950 miles on mine so far so good. I would do the upgrade but I don't want to loose the ADC. Seems like I'm one of the few who like using it. That being said, 95% of my riding is trail riding so I rarely need to use 4wd except for steep hill climbs and creek crossings.
I think alot depends on your riding style. Will you be putting it in deep mud, technical rock climbing? In both of those cases I would replace the cover if it were me.
2017 RZR 1000 XP LE w/ Ride Command
2013 Sportsman 850 XP HO EPS, 28" Kenda Bearclaw HTRs, Elka Stage 2, ATV-Guru bumper w/ LED light bar, JCCapri bushings, Cecco F+R braces, Uni air filter, NGK plugs, ODI Rogue grips
SOLD 2003 Sportsman 700 Twin, 26" Mud Lite XTRs
SOLD 2000 Honda Rancher 350 ES, 26" Outlaws
Kawasaki Bayou 220
Honda ATC 3 Wheeler
moore3cam is offline
post #7 of 20 (permalink) Old 02-17-2017, 08:31 AM
It can happen in any situation. Specifically in 2wd.
850 XP
post #8 of 20 (permalink) Old 02-17-2017, 09:22 AM Thread Starter
jehar46's Avatar
No deep mud mostly trail ridding. It breaks in 2wd more than 4 if your spinning the tires?
wifes
13 550xp
3500lb winch
mine
jehar46 is offline
post #9 of 20 (permalink) Old 02-17-2017, 09:50 AM
moore3cam's Avatar
I thought it was only happening in 2wd with newer sportsman with the "close ratio" AWD where the 4wd was accidentally engaging despite being in 2wd. I thought older 850s usually only broke while AWD was engaged.
Has it also happened on older bikes in 2wd? Maybe i need to reconsider my gamble...
Kawasaki Bayou 220
Honda ATC 3 Wheeler
post #10 of 20 (permalink) Old 02-17-2017, 05:25 PM
807VikingMetal's Avatar
The risk is a 1500$ parts bill, downtime and the hassle of swapping the diff if you do it yourself, You may never need it but 170$ was cheap insurance and peace of mind too me.
I tell everyone with an XP about it so at least they are informed, as this is the 1 main weak spot with pricey repair.
2012 850xp eps
32" Sludgehammers -5"/2" lift -Turner eagles
MSA battles 5+2 - GSE filter/Pipe - Ranger Gears
HD springs -QSC clutch kit/ EPI HD belt
Heretic Lights -Front diff fix -Cecco frame braces
Jccapri bushings -Swaybar removed.
07 IQR 685 144 sold
807VikingMetal is offline
850 and 1000 front gearcase pinion cover recall Durf577 Polaris Highlifter 35 04-18-2017 11:44 PM
Pinion Cover install on my 16 Sportsman XP 1000 skeewee32 Polaris Sportsman XP 1000 32 03-02-2017 05:32 PM
Best Pinion Cover for Sportsman 850?!? Edsta1228 ATV General Discussion 13 02-28-2017 05:02 PM
Front differential pinion cover exploaded! Only 60 miles gator800r Polaris Sportsman XP 1000 15 12-29-2016 07:48 AM
Shock interchange TDMax Polaris XP 7 07-13-2016 05:21 PM
