Old 09-22-2009, 10:05 AM
terb's Avatar
Member #1364
Those looking for xp winch mount
KFI Products.com 1-877-346-2050
Polaris Sportsman XP 550/850 Winch Mount
Product Information
Brand new "KFI" Winch Mount for the following Polaris ATV's:
2009-2010 Polaris Sportsman XP 550/850
2010 Polaris Sportsman Touring 550/850
2010 Polaris Sportsman 550 X2
Designed to work with the following winches:
KFI: S2000 / A2500 / A3000
WARN : U2500 / A2000 / A2500 / 1.5ci / 2.5ci / 2.5ce / 2.5s / 3.0ci / 3.0ce / 3.0s
WARN : RT15 / RT25 / RT30 / XT15 / XT25 / XT30
RAMSEY : ATV2500 / ATV3000
SUPERWINCH : All ATV Winches
MILE MARKER: All ATV Winches
VENOM : All ATV Winches
CHAMPION : C10013 / C10014 / C10018
CHAMPION : C20049 / C20049-2 / C20051 / C20249 / C30045 / C30145
NOTErequires a Roller Fairlead with a 4.875" Bolt Pattern)
MANY OTHERS SIMILAR TO THE ABOVE (call for details)
- Standard ATV Winch 4-hole bolt pattern of 3.00" X 4.875"
- Standard ATV Winch 2-hole bolt pattern of 3.100"
- Standard ATV Fairlead bolt pattern of 4.875"
Specifications:
100% MADE IN USA
Constructed of 10 GA GR50 steel
Designed to fit between in the OEM location below the radiator
Unlike all other mount competitors our mounts are metal bead blasted before they are powder coated for the best possible finish prep.
Powder coated black for supreme durability
Mounts the same as OEM intended
Works with all Polaris OEM Brush Guards and Double Tube Bumpers
Very easy to install
Complete installation instructions included
All mounting hardware included
Will NOT work with Polaris Glacier Plow
Satisfaction guaranteed
Roller fairlead and winch not included
Why buy the OEM Kit when you can SAVE $100-$150 by getting your Winch separate and buying our High Quality 100% American made winch mount. Your Sportsman is pre-wired with the battery wires pre-ran from your battery to the contactor mount located under your front RH wheel well. We have everything you need in our kit to mount your winch and fairlead.
Price: $38.00
2012 Yamaha WR 250R
2011 White LE XP 850
2011 Yamaha WR 450
2009 Red Grizzly 700 EPS
2009 Silver Rhino 700
2008 Raptor 700 95HP
2010 Haulmark 28' race trailer
atv champion winch mount
atv winch bolt pattern
champion c20049
champion c20049-2
champion c20249
champion c20249 winch instalation instructions
champion winch 10014
champion winch kits 20249 mount
champion winch model c20249
champion winch mount bracket for polaris
champion winch mounting kit
diagram for champion atv winch mounting plate
how to make a home made winch mount for a polaris xp ranger
polaris ranger winch mount kit for champion winch
polaris ranger xp winch mount
polaris xp winch
sportsman xp 850 winch kit
sportsman xp winch
sportsman xp winch mount
warn winch kit for polaris xp 550
