Old 03-21-2011, 08:24 AM
dwhst9's Avatar
Member #11907
Send a message via AIM to dwhst9 Send a message via Yahoo to dwhst9
How to reset oil change indicator?
I've searched this forum and also looked through the service manual...I can't seem to find the info. How do I reset the maintenance indicator after changing the oil on a NON-EPS 850 XP?
Old 03-21-2011, 09:42 AM
Toggle the SELECT button until SRV is displayed in the
information area.
2. Press and hold the MODE button until the information
display area begins to flash.
3. Toggle the SELECT button to increase the service interval
hours in 5 hour increments to a maximum of 100 hours.
4. To turn off the service interval function, toggle the
SELECT button until “OFF” is displayed.
Old 03-21-2011, 09:43 AM
dwhst9's Avatar
Member #11907
information area.
I saw that in the service manual, but wasn't sure if selecting OFF would disable it all together or just for that maintenance period?
Old 03-21-2011, 09:44 AM
Selecting off will disable it until you go back in there and set it to a certain hour amount again. It wont come on at all. If you set it 50 hours again, the wrench should go away (except for the 10 seconds at start-up) until the 50 hour mark is reached again.
Old 03-21-2011, 09:46 AM
dwhst9's Avatar
Member #11907
Ah ok, got it. Thanks!
Old 03-21-2011, 09:49 AM
No problem.
how do you reset the maintenance light on a polaris ranger
how to change oil on 2009 polaris ranger
how to reset oil changelight on 2013 polaris rzr
how to reset polaris ranger service light
how to reset service light on polaris ranger
polaris 850 xp reset
polaris ranger service light reset
polaris ranger wrench light reset
reset 2004 polaris atp hour meter
reset maintenance light polaris
reset maintenance light polaris ranger
reset oil light polaris
reset polaris ranger service 2013 ranger
reset service light polaris ranger
05 Magnum 330 engine hot indicator jbramley26 ATV Repair and Maintenance 7 08-13-2011 10:34 AM
AWD Indicator Question deerjw Polaris Sportsman 1 02-21-2011 04:45 AM
Reverse indicator flashes Muggin Polaris Sportsman 5 02-14-2011 06:56 PM
Maintenance Reminder Reset 2004 Sportsman fmongeau ATV Repair and Maintenance 2 11-14-2009 07:41 AM
Reset Maintenance Lights Echo's Mom ATV Repair and Maintenance 1 09-06-2009 11:11 AM
