Old 03-27-2011, 06:29 PM
Monkey Man's Avatar
Member #12591
Send a message via ICQ to Monkey Man Send a message via Yahoo to Monkey Man
Polaris 850XP X2 LE Review
Well, I have taken my first full trip on my new Polaris and I loved it, I traded my Honda TRX400FA in to get it and I don't regret it at all. This isn't a criticism of the Honda though, it is a well built, stocky, reliable little machine but like a lot of Honda owners I felt the desire a lockable differential, low range selection in the gearing and a more comfortable ride. I looked at a lot of bikes but I had previously owned a 250cc trail boss and an Xplorer 400 that I had rebuilt so I was familiar with the Polaris format and feel.
I looked at different brands...
Can-Am: Beautiful bike, Price was a problem though
Suzuki: Great bike, not what I wanted though (features and feel)
Yamaha: Once again, great bike but not what I was after
Honda: Another great bike but Dammit Honda, where's the features folks have wanted for so long, Listen to your customers and the marketplace.... (I was very tempted by the 680 though)
Engine:
I was first impressed by the sheer torque of the 850XP, I didn't go WOT as it is still in the break-in period and I want it to last a lot of years but even at 3/4 throttle it'll throw you back in your seat easily and the power is smooth with the twin cylinders, I was impressed with the EFI when starting up and the throttle response is very linear and considering the engine is still new and a bit tight the fuel economy wasn't too bad at all. The engine has a paper element in the air cleaner department and I couldn't be happier (there is a God in the ATV world after all...), I have always preferred paper elements over foam and oil combinations and this one has the outerwear mesh to help it last longer.The exhaust system is Nice, a good throaty sound without excess noise and if you keep the throttle low you can sneak about the place without disturbing the locals although up close it attracts onlookers as it sounds good, really good, almost "roadbikelike".
Transmission & Driveline:
The CVT (or should that be PVT??) is excellent with power starting to apply at 1300rpm with a very smooth takeup and wide output range and if in low range the torque transfer is very controllable in tight sections of the trail or as I found when fording water there was no noticable speed loss as I waded in a few inches over the footboards. The EBS and ADC are 2 things I have never had before, EBS makes engine braking just like the hydrostatic transmission braking on my Honda (a feature I really did like about my old bike) and the ADC made decending steep dunes and slopes much more controllable and manageable. The traction of a Polaris is something I missed when I went to a Honda with it's limited slip diff in the front I felt it was a step backwards for me, I wanted more and this bike delivers, I climbed slopes and dunes previously impassable to me and did so with confidence and ease. 4wd always active in reverse as standard is indeed nice and there is so much torque available at low rev's I didn't find the need to push the override button even on soft sand (but I will at some stage I am sure).
Brakes:
The brakes are awesome but after having Honda drum brakes that requred servicing it would be an expected opinion but I found them powerful yet easy to control and I don't mind the single lever system at all and the foot lever is easy to access and comfortable to use.
Handling:
The handling is good despite the weight of the bike and the rear suspension with it's anti roll bar is excellent as other IRS bikes I have ridden tuck their tail under easily under heavy cornering which to me looks and feels awkward and unstable. The Polaris felt stable the whole ride and even when I tested it sidehilling a dune it didn't feel or behave "tippy" at all plus yes, Nothing rides like a polaris, even after a hard day on the dunes I felt good!! The ground clearance is excellent, the tires really grippy (Carlisle 489 MkII) and the adjustable shocks allowed me to play about with the suspension to get what I wanted from it. I don't have the EPS on mine, it wasn't standard for this model and I couldn't justify the cost of adding it as the standard steering is about half the weight of the Honda's so I considered it an upgraded item already.
Lighting
The standard lights are crisp and bright, I think they could only be improved with a set of 10 Watt led units or a bar to spread the light pattern or maybe HID replacements if that's what tickles your fancy...
Rider Comfort:
The bike is well laid out, everything is where you need it and your position on the very well padded saddle meant I can keep a straight back with my feet on the footpegs and my arms are not cramped or stretched to reach the handlebars. The generous footboards made it easy to move my feet about to shift weight on climbs, slopes and decents and the agressive pattern on the footboard plastics meant my boots didn't slip at all.
There are more points I really like about my new bike (like the great storage ability on it and the excellent speedometer/combination display) that I have not mentioned them here, I haven't found anything I don't like so far. I am of course somewhat biased in my opinion (and this review is ONLY my opinion, agree or disagree as you see fit) as I have previously owned Polaris quad bikes and liked them but this thing is a true leap ahead compared to my old bikes and others I have ridden. I can't wait to hit some serious trails now and have some Great Adventures....
Best Regards - MM
It's Trail Time!!!
Old 03-27-2011, 07:38 PM
biz4two's Avatar
Member #208
Thumbs up
GREAT review! These XP plateform machines...are really the best out right now...IMO ( x2 )...
biz
Took delivery on February 4, 2011
2011 Sportsman 850 Touring EPS -- Mine
2011 Sportsman 550 Touring EPS -- Wifie
Sold 2009 Sportsman XP 850 Sold
Purchase date: May 2009
Sold date: December 2010
Old 03-27-2011, 11:52 PM
Monkey Man's Avatar
Member #12591
Thanks Biz....
I posted this review over at the other ATV site I frequent and the comment was good review but where's the pics??
Here's the few I have so far...
Best Regards - MM
It's Trail Time!!!
Old 03-28-2011, 10:19 AM
terb's Avatar
Member #1364
Now that you have a few miles on it, be sure tp check your air filter to see if you have oil in the air box.
2012 Yamaha WR 250R
2011 White LE XP 850
2011 Yamaha WR 450
2009 Red Grizzly 700 EPS
2009 Silver Rhino 700
2008 Raptor 700 95HP
2010 Haulmark 28' race trailer
Old 03-28-2011, 06:13 PM
Monkey Man's Avatar
Member #12591
All clean, not a drop in there
Best Regards - MM
It's Trail Time!!!
Old 03-28-2011, 08:43 PM
supercoe's Avatar
Member #12480
Ditto on the 850 X2 love, these things are great.
Old 03-29-2011, 07:42 AM
bfbill650i's Avatar
Member #5375
I frequent my local Polaris dealer ALOT. I am in LOVE with the 850 x2. The salesman has tried every trick in the book trying to convince me.He even had me try one out that had just come in from Po-Po.Amazing quad!!!Almost, just almost had me sold (had to get outta there).
There are 3 things that nag me. All Polaris dealers around here deal in kawie and IF I buy I will have to trade. Nobody wants to offer me a decent price on my trade-in. They all offered me less for my 650 than I got for my outty 400 and these two quads are about the same age at time of trade. Thats one concern here are the other two. IF I buy a new quad I, like Fishy here, would like to install 27" or bigger pitbull tires, but what I want can't be done without a little modding (this I can live with ..... but mod a new machine??!) AND last but not least is its a PO-PO, They do NOT have the best of track records around here. (THE XP MAY BE DIFFERENT) All the Po-Pos here tend to eat belts , overheat and just break way more often it seems than other wheelers. Yet some guys have no trouble and swear by them!!
I'm really conflicted and confused!!!
2006 camo brute force 650i modded
Old 03-29-2011, 01:20 PM
supercoe's Avatar
Member #12480
Look at it this way, installing larger tires is modifying the vehicle so don't expect it to always just work.
I was torn between the 850 x2 and the 800xtr but decided either one would be awesome so it wouldn't matter.
All toys break, get the one that makes you happy.
If you want reliability buy a car.
Old 03-29-2011, 02:01 PM
terb's Avatar
Member #1364
"All toys break, get the one that makes you happy"
That's true, but lots of people have trouble with there XP850s...
2012 Yamaha WR 250R
2011 Yamaha WR 450
Old 03-29-2011, 02:24 PM
bfbill650i's Avatar
Member #5375
Its comments like this that makes me leary!!........................................... although I did know about the brutes tie-rod issue and over-heat but (never ever had those issues...."touching wood"!)
2011 polaris 550 x2 reviews
2011 polaris 850 xp problems
2011 polaris 850 xp review
2011 polaris 850 xp reviews
2011 polaris sportsman 850 xp review
2011 polaris sportsman 850 xp x2
2011 polaris sportsman 850 xp x2 problems
208 polaris sportsman 700 x2
gebraucht polaris 850 x2
polaris 850 x2
polaris 850 x2 problems
polaris 850 x2 review
polaris 850 x2 review test
polaris 850 xp
polaris 850xp reviews
polaris 850xp weight
polaris atv problems x2 2011
polaris x2 850 review
polaris x2 review
ATV Helmet Review. Thor TheATVSuperStore.com 7 10-25-2011 10:59 AM
New ATV helmet review. Thor Around The Garage 18 02-26-2011 11:05 AM
Battery Replacement and Review JAK ATV Repair and Maintenance 2 02-21-2011 05:05 PM
2010 Polaris Sportsman XP 550 Touring Review redneck2725 ATV Purchasing and Price 0 03-07-2010 04:47 AM
