12-13-2009, 11:49 AM
Member #2288
850 XP Oil Leak
Noticed an oil leak on the underside of the engine. Unfortunately, the metal skidplate is welded to the frame, and there is not enough room to clearly see the bottom of the engine, so I cannot tell where the oil is coming from without pulling the engine. The drain plug, filter, and every other possible leak point seem spotless. However, after running the engine for just a few minutes, oil will start collecting on the skid plate, and eventually start dripping on the ground. No seams under the engine case that I can see. Anyone else experience this or have any ideas?
12-13-2009, 01:52 PM
Member #1634
yes i had the unfortunate luck of having my oil plug strip out, I have changed my own oil on my rigs for years and know better with an aluminum block to over tighten but it happened any ways,
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
12-13-2009, 05:30 PM
And welcome to the board!
12-14-2009, 08:16 PM
Member #2288
Thanks Chopper89. The oil plug was the first thing I checked, but it shows no seepage. The leak appears to be hidden under the metal skidplate.
03 polaris sportsman 700 oil leaking from valve cover, 850 xp oil change, oil leaking out dip stick of polaris 850 xp, polaris 850 oil leak, polaris 850 xp leaking oil, polaris 850 xp oil change leaking, polaris 850 xp oil leak, polaris 850 xp problems oil leaks, polaris 850 xp valve cover gasket leaking, polaris 850xp leak, polaris 850xp leaking oil from side of motor, polaris sportsman 500-tighten oil plug leak, polaris sportsman 850 oil leak, polaris sportsman 850 xp eps leak problems, polaris sportsman 850 xp oil leak, polaris xp 850 oil leaking, polaris xp oil dripping from light, sportsman 700 leaking oil, sportsman 850 oil leak, sportsman 850xp oil leak
