Front diff seal leaking - Polaris ATV Forum
Old 12-21-2011, 03:19 PM
shore's Avatar
Member #19003
Well, it's seeping. It's the seal that the front driveshaft from the engine goes into on the back of the front diff.
Is this seal a PITA or easy? I'd like to avoid pulling the front diff if at all possible.
sold
09 850xp
30" Zillas Blk 212's
2012 Outlander 1000XT
30" Zillas BLk 212's
Old 12-21-2011, 03:41 PM
can just pull front shaft off, get a seal puller and remove and replace seal
Old 12-21-2011, 03:59 PM
shore's Avatar
Member #19003
That sounds easy enough.
compress the driveshaft, pull it out.
Pick seal out from back
Slip new seal in and tap her in, fill her back up and move on.
I really didn't want to pull that front diff.
I was just curious if that stupid Auto Decent Control thing was the fluid that was leaking out from there.
sold
09 850xp
Old 12-21-2011, 04:02 PM
A.K.'s Avatar
Member #21297
mine is too. 2010 550 xp eps. 170 miles 20 hours..what a friekin joke. these xps are plagued with problems.
had i done more research i would have surley had been scared off from buying this bike.
i have the clunk into gears.
i have the noisy transmission. sounds about to blow...but its normal!?
i have the leaky front seal..whats next for this brand new expensive bike. i hope it isnt the intake valve like i have heard.
i have the play in the handlebars that people are using threadlock on at the steering post.
and still worrying about broken a-arms.
put the patv13 spring in primary the other night. totally unacceptable polaris shipped these out..they are dangerous.
time will tell if i regret buying this bike. it does ride awsome, but the other issues are way uncool.
i have rode a 2000 325 magnum for ten years. been a great bike. geuss times have changed for polaris.
Old 12-21-2011, 04:07 PM
shore's Avatar
Member #19003
what about the play in the steering stem?
I have play in the bars also and it is not really at the tie-rods. It's at the box on top..sorta
sold
09 850xp
Old 12-21-2011, 04:11 PM
jccapri's Avatar
Member #8500
Send a message via Yahoo to jccapri
true i have a 03 mag 330 no problems and i rode it harder then the 850
Old 12-21-2011, 04:24 PM
A.K.'s Avatar
Member #21297
i read on hear about it being under the eps unit...well..mine was on top of unit. there was a bolt and nut that i tightend and got a little better. however im sure it will snap before i get it tight enough. its already cranked beyond what i consider tight,and still play left. gonna give it a little more torque next time in garage. if it snaps i will go get grade8 hardware and try again.
Old 12-21-2011, 04:34 PM
A.K.'s Avatar
Member #21297
i almost forgot the stupid location of clutch duct under rear seat. first ride out clutch got wet where my magnum would have scoffed at...and im thinking.." how is this extreme performance?!"
Old 12-22-2011, 06:41 AM
shore's Avatar
Member #19003
My 09 duct is up near the airbox but still under the seat, pretty slick to have it up there.
funny we where talking about the front diff seal. I ran her around the block to make sure the front seal wasn't going to let go and the rear end was whining. Odd, never done that, drained it ans was milky, lol. No leaks visible so I think it might have taken some water in the vent tube when I washed it last. I saw a drop of moisture in my vent tube(clear). We didn't ride any water last time we went out..none.
sold
09 850xp
Old 12-22-2011, 03:17 PM
A.K.'s Avatar
Member #21297
damn i feel your pain. pisses me off
saw your other thread too....wheres the nearest cliff?
so what are we leaking from front front diff? demand drive plus fluid?
2010 polaris xp front differential seal replacement
2010 sportsman 850 xp leaking diff
atv front differential seal replacement
atvfront seal fix leak
front differential leak on atv
front differential seal for 2010 polaris 850 sportsman
front differential seal for 2010 polaris 850 sportsman#gsc.tab
how to change front differential seal in a polaris
how to change seal on polaris front differentian
how to replace front differential seal on polaris 550
polaris front diff seal replacement
rzr s front diff leaking
2010 550XP Front Diff Seal Replacement? D Clemen ATV Repair and Maintenance 7 04-26-2016 03:50 AM
REAR END SEAL LEAKING! help needed! POLARIS13 Polaris Sportsman 2 12-01-2011 05:38 PM
polaris 500 front diff seal leak mye01532 ATV New Members 4 02-08-2011 09:38 PM
Leaking from front hub seal 99 sportsman 500 RMR ATV Repair and Maintenance 6 09-28-2010 02:56 PM
Seal leaking, front differential HappyCamper ATV Repair and Maintenance 1 04-17-2010 10:26 PM
