Old 02-05-2012, 03:24 PM
Vibe's Avatar
Member #17796
Taking forever to go into 4WD
Has anyone running in the cold and snow found that
the first time of the day like when you are loading your
machine on the trailer the thing will not go into 4 wheel drive
but after i run it a while it will go in and i don't have any more
issues all day.
please advise
2012 Sportsman Touring 850 Bronze Mist LE
Old 02-05-2012, 04:35 PM
scat6's Avatar
Member #22929
Yes, I've had that happen too. I talked to a guy that is a whiz with things like that and he seems to think any bit of moisture in the front end (if you have a machine with the Hilliard Clutch style) would freeze up and cause it not to engage properly. After you drive it for a bit and get the gear oil warmed up some it will allow it to work like it should. So have no worries, you are not the only one with that problem, my '04 700 does it all the time in the winter.
2004.5 700EFI Sporty
26x10x12 Dirt Devil XT fronts
26x12x12 Dirt Devil XT rears
custom rear bumper
2500lb warn winch
K&N air filter
60" cycle country plow
Old 02-05-2012, 09:01 PM
bp405's Avatar
Member #18562
my buddy was just talking about this. he has an 2011 850 xp eps touring and said the thing bangs into 4x4 when he's plowing. he also says he has no traction. so i told him he has to upgrade the stock tires for the traction and i found it odd about the 4 wheel drive because i hear polaris's 4x4 set up is top notch.
2011 sportsman 800 efi
polaris front brush guard
polaris rear brush guard
polaris front lock n ride cargo box
polaris rear rack extender
warn RT 3.0 winch
polaris front spring adjusters
ricochet a-arm guards
ricochet full frame skid plate
itp T-7 beadlock 14"
maxxis big horn 2.0 26x9 front
maxxis big horn 2.0 26x11 rear
QSC clutch kit
pictures of bronze mist polaris atv
wwwpolaristxforever
Jerk and clunk when taking off amandacosner ATV Repair and Maintenance 12 Yesterday 05:41 AM
Taking off plastics kstrotz29 ATV Visual & Body Modifications 4 11-19-2011 01:19 PM
taking my dog atving rale ATV General Discussion 5 07-13-2011 01:28 PM
can you rebuild a clutch without taking it off scrambler1 Polaris Scrambler 3 03-23-2011 05:16 PM
brake cylinder taking apart gjones1 ATV New Members 3 09-14-2010 12:45 PM
