Old 05-30-2012, 12:14 PM
HossTexan's Avatar
Member #26696
Is anyone running a 3" with 2.5 rake lift on a 2012 850xp without issues
I keep reading about guys putting the Catvos or other 3" raked lift on the 2012 850s and the owners having issues with the diff locking up. After following up with the OP's via pm on other forums and they all took the lift off. Anyone having success with this setup on the 2012? If so what is the trick?
I'm a former brute owner and have been weighing my options between the Can-Am 1000Xt outlander and the Polaris 850XP.
Thanks,
Old 05-30-2012, 01:56 PM
HossTexan's Avatar
Member #26696
Anyone?
Old 05-30-2012, 02:06 PM
CVCOBRA1's Avatar
Member #23146
Don't know about that lift kit but it seems most who lift the 850's go with after market axles too. The stock OEM axles don't like lift kits.
Old 05-30-2012, 03:03 PM
HossTexan's Avatar
Member #26696
Yeah thanks I plan to run aftermarket axles. But the diff is what i'm worried about. All the guys with issues had them even with aftermarket axles.
Old 05-30-2012, 05:50 PM
Unclewill427's Avatar
Member #24567
On you-tube theres a guy called ostacruiser and he had a guy in there club that had a 850 xp lifted that ran the black mamba tires and had lots of diff problems. I think he said he put 3 diffs in with those tires on. Changed tires to 29.5 outlaws 2 I think and so far no problems. Ended up the black mambas are really heavey tires. Hope this helps.
09 850 XP EPS LE Nuclear Sunset
27" ITP mud-lite's XTR
Polaris rear lock and ride box with bags and moded Lid
PIAA Front Bumber lights upgraded to 55Amp
HMF swamp series muffler
HMF optimizer
K&N air filter
Polaris remote winch
Royal Purple 5w40 oil
Polaris rear bumper to match front that came with it
Polaris 2010 clutch
Polaris 2010 slipper clutch elevator
Old 06-01-2012, 06:11 PM
railroader's Avatar
Member #18915
I have a catvos 3" raked and 32" Sbacks on a 2012 xp. I bought 4 rhino axles at first and rode along a little at the end of winter and no problems. I then installed 4 spring spacers and took the bike out to the first rally and about the 3rd muddy/water hole one of my rear axles broke (cage) on upper cv, I thought maybe I hit a rock, then later in the day I started in a hole going about 2km/h and barely touching the throttle and the second rear axle broke same spot, I figure its to much angle, since then I took out spring spacers and installed two rear gorilla axles. And have no issues yet but I haven't been in mud with this set up yet.
2012 metallic 850 xp eps
32" silverbacks/msa m-12
snorkel your atv snorkels
catvos 3" 2.5" rake lift
rhino axle front gorilla axle rear
Looney tuned
railroader's Avatar
Member #18915
Just curious what diff are people saying that is locking up?
Looney tuned
Old 06-01-2012, 08:00 PM
HossTexan's Avatar
Member #26696
The front diff. I've read numerous people saying it locks up with both rhino and stock axles. And they all ended up selling the lift.
The guy above you is the first I've heard that's had no issue.
2012 850 xp raked lift kit
2012 polaris 850 sportsman with catvos lift
2012 polaris 850 xp lift kit
2012 polaris sportsman 850 catvos lift
850xp 3 catvos front diff problem
catvos lift for polaris xp
catvos lift kits for polaris 550 xp
catvos lift polaris 850 sportsman
catvos raked lift
polaris 850 32 silverbacks
polaris sportsman 850 with raked suspension lift
polaris sportsman 850 xp lift kit for sale
sportsman xp lifted
what is a lift and a rake kit
3" Catvos Lift for 850xp JP10 ATV Parts for Sale 2 02-22-2012 07:40 PM
2010 Polaris Sportsman 500 HO running "HOT" elachance Polaris Sportsman 19 06-23-2011 04:36 PM
HD front spring and 1.5"-2" rear lift Combo kool_500HO ATV Brakes & Suspension 15 05-27-2011 12:13 PM
6" Lift, 30" Tires - PROBLEMS??? Hunt@r07 Polaris Sportsman 1 05-19-2011 05:11 AM
sportsman 800 w/ 2" lift will 30" zilla's fit? QuickSilver74 ATV Wheels & Tires 3 01-21-2011 10:47 AM
