Old 06-26-2012, 06:09 PM
jd1's Avatar
jd1 jd1 is offline
Member #26934
how to put in a temp gauge
i have seen where people have been installing temp gauges, would like to know how so i could do it, where would the wires actully hook up at. pics would be nice to see,or tell me,either one would be apprecated. also its a 2012 850 xp
Old 06-26-2012, 06:25 PM
bigtime's Avatar
Member #14353
I have never installed one but have often thought about it. They best I could tell you is visit ATV Tires Wheels Aftermarket Parts ATV Quad Winch Exhaust ATVs UTVs. Those guys have a really nice kit that includes gauge, electronic sending unit, and directions.
Good Luck, let us know how it goes!
Bigtime
2011 Sportsman 800 EFI:
Front and Rear Polaris brush guards
ITP Delta black steel wheels
26x9 STI Mudtrax XL
26x11 STI Mudtrax XL
K&N Air Filter
Venom #3000 Winch with synthetic rope
DDM Tuning 6000k HID kit
3 Headlight Mod
Polaris Rear Rack Extender
QSC cluth kit
Old 06-26-2012, 06:51 PM
SeanE1987's Avatar
Member #16252
I have oil pressure, coolant temp, and voltage gauges on mine. I had to drill the bottom of the thermostat housing and tap the hole with a 1/8" NPT tap. There are no extra ports to use for the sensor. The wiring is pretty simple. There will be a few orange and white wires on the left side of the battery that can be used for key power. Ground goes to the battery negative. The last wire will go from the gauge to the sensor that is installed on the engine. Getting the cahoneys to drill the cylinder head is the hardest part lol.
2011 Sportsman X2 550 With EPS!!-Polaris 3500lb Winch, Polaris Brush Guard, HID's, PIAA Driving Lights, Autometer Phantom Oil Pressure, Coolant Temperature, and Voltmeter Gauges, Polaris Low Lock and Ride windshield, Acerbis Handguards, Symtec Heated Grips and Thumb warmer, 2+2 gallon Rotopax Fuel packs, Warn 60" Provantage Plow w/ Power Pivot
1998 Xplorer 300-Stock
Click here to learn how to add EPS to an XP!!! ---> http://www.polarisatvforums.com/foru...eering-x2.html
Old 06-26-2012, 07:03 PM
Lennartchurch's Avatar
Member #20564
Hey sean where does your oil pressure gauge sending unit go into ?
Old 06-26-2012, 09:53 PM
Rooskey's Avatar
Member #22134
Dude how can you even see the trail with all that stuff, lol!
Old 06-27-2012, 11:27 AM
4getful2's Avatar
Member #1234
The 500's have an inspection port on the lower left side of the block, for checking oil pressue,for the oil gauge. They don't carry alot of oil pressure ,so you may want to get a low pressure gauge(0-50), for easier reading
Old 06-29-2012, 05:47 AM
SeanE1987's Avatar
Member #16252
The oil feed line for the cyl head has 2 banjo fittings, 1 in the block and 1 in the head. I found a banjo bolt that has a 1/8" pipe thread boss on it, so all i had to do was replace the banjo bolt at the block. I originally had it in the head, but the engine runs under 10 psi when it gets warm, and it barely registered on the gauge. I moved it down to the block and it works a little better now. If I did it again I would probably just do coolant temp and voltage. If you have an 850, they will run 20-30 psi, so the oil pressure gauge would be worth it. I have a line running from the engine, and the sender is mounted on the right side under the air box.
Old 06-29-2012, 05:52 AM
SeanE1987's Avatar
Member #16252
I come from the heavy duty truck world, where trucks can have upwards of 25 gauges in the dash, a few extra gauges just seems right to me lol. I am actually contemplating replacing the oil pressure gauge with fuel pressure gauge lol
Old 06-29-2012, 05:56 AM
SeanE1987's Avatar
Member #16252
If you look at my pic of the side of the engine, the newer 550's have a plug on the cyl head witha blue paint mark on it. Thats what is used for checking oil pressure with a manual gauge. The port in the block is cast closed and not drilled on mine. Polaris uses a really small metric thread for the plug, and I couldnt source a fitting for it (the polaris tool is only for temporary use and its like 5 inches long)
Old 06-29-2012, 06:31 AM
Member #20564
Thanks for the info. I am gonna put one on mine
2012 polaris sportsman 550 efi tuner forum
atv coolant sensor and gauge
atv coolant temperature gauge
atv temp gauge
atv temperature gauge
atv temperature sensor and gauge
how to install a temperature gauge on a polaris atv
installing temp gauge sportsman
instsalling auto meter weter temp gauge in polaris rzr
oil pressure guage polaris 550 sporteman
polaris 850 volt meter
polaris atv teperature guage
polaris easy temp gauge instal
polaris tempurture gage fittings
poolaris 850 xp oil pressure gauge
temp gauge and fan on bypass Born2rescue ATV Performance Modifications 13 05-12-2012 05:28 AM
Quadovator coolant temp gauge kit Wes ATV General Discussion 21 02-29-2012 03:32 PM
installing temp gauge Stretch ATV General Discussion 3 09-25-2011 03:17 PM
what is your temp? peterbilt Polaris Sportsman 11 03-22-2011 07:56 PM
water temp gauge banditboy21 ATV Repair and Maintenance 20 12-20-2010 07:06 PM
