Xp A-arm bushing wore out!!! - Page 2 - Polaris ATV Forum
post #11 of 20 (permalink) Old 09-21-2012, 08:03 PM
jccapri's Avatar
Send a message via Yahoo to jccapri
You are dead on that one wolverine
jccapri is offline
post #12 of 20 (permalink) Old 09-21-2012, 10:12 PM
denseleit's Avatar
Mr. jccapri, do you make your own bushings out of the nylatron or are you affiliated with boss bearing. They selling nylatron bushings too??? Also are there differences between the 09 xp's and the newer xp's bushings or is just different numbers needed???
denseleit is offline
post #13 of 20 (permalink) Old 09-21-2012, 11:32 PM
joevee1446's Avatar
Bushing are bushed out
I have roughly 4200 miles on my 09 850xp. I ordered the all ball front bushings, tie rod ends, and ball joints. Mine stock units have been crap since around the 500 mile mark just had to many other problems to deal with the bushings and ball joints. The tie rod ends look fine and have normal wear, but I figured I would replace them too.
My rear bushings look good and feel good; think I will wait to replace them.
My 850XP is a mechanics dream. I have gone through 5-starters, 6+ belts, two front CV joints, two front wheel bearings, and a ton of other little things. My bike is pretty much stock except for 29" tires, HMF slip-on exhaust, 1.5 inch shock lift. It has been a pain in the azz for repair issues.
joevee1446 is offline
post #14 of 20 (permalink) Old 09-22-2012, 12:46 AM
jccapri's Avatar
i make them myself in my spare bedroom . polaris made a change in 2010 and thin in2011 they changed back to the 2009 bushing , now the 10/11/12/13s rear uppers are different thin the 09. now the 10 uses the same as the 09/11/12/s . what they changed was what they were made of
jccapri is offline
post #15 of 20 (permalink) Old 09-22-2012, 08:10 AM
denseleit's Avatar
I just finished rebuilding my starter. Pulled it apart and it was wet and rusty. Cleaned everything, lots of material left on contacts. re greased and put back together. Siloconed the joints and bolts to make "waterproof" again. Works like new again. Well your 6 belts is from not having a gear reduction kit. I've been on 30's for a long time with no blown belt. The rest sounds like mine too. lol
post #16 of 20 (permalink) Old 09-22-2012, 08:14 AM
denseleit's Avatar
So which changes did they make, are the newer ones bigger or smaller, what changed on them? Or are they all the same size, but different material?
post #17 of 20 (permalink) Old 09-22-2012, 09:13 AM
jccapri's Avatar
All are same size and 09/11/12/13 all have same part # the 10s have a diff. Part # same size they tried a different material that did not work as good as the old material witch does not seem to work. Some say theres last but if you look at them the design was followed they are designed to ride on a bed of greese about 1/16" thick but greese doesn't support weight. If you remove them and clean the dirt and sand out then they become very loose the only part that is tight on a new stock bushing is a 50 thousandths thick lip on the end and that is were the play comes in and if you keep greese in them you by hand can not or its hard to move them but a 800 to 1000 bike moving it's easy. Sorry for the long rear
jccapri is offline
post #18 of 20 (permalink) Old 09-22-2012, 01:16 PM
joevee1446's Avatar
Reduction
I have an HPI big wheel clutch kit installed, including the Helix for the secondary clutch. I installed the complete clutch kit right after I blew the first belt, around the first 500 miles. It just tuned 4600 miles today and I have been running the current HPI extreme belt for the last 600-800 miles. Gotten far better usage from the HPI belt or maybe I have been more gentle with the bike over the last 800 miles..
post #19 of 20 (permalink) Old 09-22-2012, 01:20 PM
joevee1446's Avatar
Bushing
jccapri, how good are your bushings, are they lasting longer then the OEM bushings? If so, what do you charge for a complete front end replacement on a 2009 Polaris 850XP? My current bushings have LOTS and LOTS of slack in them. The bushings have never been replaced and the bike has 4600+ miles on it.
Thanks in advance for any and all help.
post #20 of 20 (permalink) Old 09-22-2012, 04:21 PM
jccapri's Avatar
Hello. Now how long do they last to be honest i do not know. Now on my 09 850 i was replacing stocks every 150 to 170 miles or every big show like mud stock or mud fest at mud creek or river run now thats 3 sets in under 400 miles thats when i started looking in to making my on we have 2 09 850s my bushing i made how around 300 miles on them and are still tight and yes not meany miles making the bushing has taking alot of my time up. There are some how have told me they have over 500 to 1000 miles on them and are still tight thats all i know about how long they last. As for as cost they are 150.00 for a 09 front and rear or 80.00 on haft orders and 10/11/12/13 are 155.00 or 80.00 for the front or 80.00 for the rear. A 09 has 32 short a arm bushing 10s and up have 24 short and 4 long plus shipping in U.S. Is 12.00. if you need more info please send me a P M thanks
jccapri is offline
bushing help lard_lad_123 ATV Repair and Maintenance 6 09-04-2012 02:47 PM
Rear Brake Hub wore grove in trans case HaulerATV ATV Brakes & Suspension 1 05-23-2012 05:32 PM
Best place for A-arm bushing? Ronin2 Polaris Sportsman 2 03-09-2012 02:00 AM
New A-Arm bushing coppertop Polaris XP 2 10-24-2011 10:01 PM
Xp bushing kit Vettdude ATV Brakes & Suspension 2 10-12-2011 05:13 PM
