03-28-2010, 09:16 AM
Member #858
How to set idle 2010 550xp??
My brother inlaw just bought a new sportsman 550xp sportsman...he's complaing about the idle being too high and its too hard to shift into gear...should he wait and break it in or take it back? Is there any idle adjustments maybe we can back it down...its running about 1850 in park...and i think its affecting the shifting...its hard to put into gear?? any sugguestions...?? Thanks Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
03-28-2010, 12:02 PM
Member #1644
is the thumb throttle adjusted right? there should be just a little bit of play in the throttle you may have it set too tight... other then that it's all computer controlled. if the trottle cable is set right and it's still high and under warrenty take it in.
03-28-2010, 02:32 PM
Member #1495
dont want to hijack you thread anybody fouling spark plug on 550 XP just got one and when i got it dealer gave me a new plug said polaris changed the mapping and its rich a lot longer on the new ones said if i start it leave it run for 10 min sound right to you guys its a good dealership very pleased do i have to let it run 10 min to put it on the trailer thanks keep the shiny side up
03-28-2010, 03:34 PM
Member #3625
I picked up my 2010 550xp two weeks ago and it seems to shift out of park and into the other gears a little easier the more I use it.
The spark plug issue is a new one for me. My dealer never mentioned it. I start it up and let it run for a few seconds to let the oil circulate and them take off!!
03-28-2010, 04:07 PM
Member #3743
idle should be 1,100 +or- 50 r.p.m.s
The Kid
heel clicker
Warn 2500 puller outter
SS108's
29.5's Laws skinny/fat
rubber down custom intake
homemade exhaust snorkel
rad. relocated up top
chains on front & rear A arms
swaybar removed
03-29-2010, 01:56 PM
Member #501
My 09 550 XP idles around 1650 rpm, I called the dealer about how rough it idled, they said that the newer models will have a higher idle ( around 1830 rpm)to make it smoother and if I wanted they can program the 09 XP.
The reprogram only makes the idle smoother and does nothing for performance. So I left mine as is. The adjustment on the thumb throttle is to take the lash out of the cable.
09 Sportsman 550 XP w/EPS Mossy-oak
-Polaris 3500 Winch with Recovery kit
-Mad dog Rear bag and fender bags
-Garmin GPS MAP60csx
03-29-2010, 02:02 PM
Member #858
Ok thanks Mech...we're leaving as is...no reason to fool around with it at this time....Thanks for all your responces...Muddie49
2009 Polaris 500 HO
Polaris hand guards
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
03-29-2010, 04:08 PM
Member #1644
sounds like your dealer has some tards working there. the only reason they would bump up the idle is to get more power out of the stator. 1650 sounds too high i'm amazed you can get it out of gear.
05-17-2010, 04:16 PM
Member #4949
Mine Idles at around 1750 after it has been running for a while, the owners guide says 1800 for the first few minutes of operation and then 1750 +/- 50 So I doesnt sound like the idle is a problem
05-17-2010, 05:45 PM
Member #4899
I think I saw it in the owners manual or maybe on the DVD but they said that Polaris set the idle high for a period of time and that it would adjust automatically after it was ridden awhile.
2009 550 sportsman adjust idle speed, 2009 polaris 550 idle adjustment, 2009 polaris 550xp hard to shift, 2010 polaris adjusting idol, adjust idle on polaris xp 550, how do you adjust idle speed on a polaris atv, how do you adjust throttle on 2009 polaris 550xp efi, how to adjust 2009 polaris sportsman 500 idle, how to adjust idle on polaris 500, how to adjust idle on polaris sportsman 550 efi, how to adjust idle speed on polaris atv, how to get my polaris 550 xp to idle down, idle speed 09 polaris 550, my polaris sportsman 500 is idle to high how do i fix it, polaris 550 xp idle adjustment, polaris sportsman 550 idle speed, polaris sportsman 550 xp spark plug, polaris xp 550 spark plug location, polaris xp 850 stator adjustment, setting the idle on 2010 polaris 550
