cvt problems - Polaris ATV Forum
Old 06-22-2013, 08:46 PM
kohen's Avatar
Member #4527
cvt problems
Just wondering if anyone can tell me why my Polaris xp850 would move with out touching the throttle the bike is not reving any diffrent it did it to me twice where it would slowly go forward and then I would shut the bike off put it in park turn it back on and back in high or low and it wouldn't do it anymore also it was hard to put in gear and then it would get really easy once it was shut off thanks for any input
Old 06-22-2013, 08:53 PM
lost cause's Avatar
Member #9763
Common causes of this are idle too high or wrong belt. What RPM is your idle at? Have you changed your belt recently? Those are the two quick and easy things to check.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
Old 06-22-2013, 09:01 PM
turboshelby's Avatar
Member #35082
One way bearing it the primary clutch is sticking. 09's tended to eat through the lower shim and rub the sheeve. Sometimes if the clutch gets hot it will cook the grease in the bearing, and it can be fixed with a parts washer and new grease. Sometimes they just wear out, but if the idle is normal then 95% likely this is your problem.
Sent from my XT907 using Tapatalk 2
2009 850 EPS - 2500 miles and counting
2009 550 EPS - 8200 miles and counting
2006 500 EFI - 18,700 miles and *SOLD*
Old 06-22-2013, 09:03 PM
kohen's Avatar
Member #4527
It's got original belt and rpms are normal would water in cvt cause the bike to do that went through some deep water holes in the mountains I was in
Old 06-22-2013, 09:08 PM
buddy_1's Avatar
Member #15674
I would check for broken engine mounts and also pull cvt cover off and check for binding clutches. It sounds like your belt is too tight causing it to keep the secondary spinning all the time. That will make it hard to shift with the engine running. If the engine is moving around it could cause the belt to tighten up. If the primary clutch is binding it could keep the belt moving. Do your ride in deep water/mud? Could have gotten some water inside the cover and caused it, Buddy.
I know the "VOICES" aren't real but they have some great ideas.
1999 Sport 400 2x4
Complete rebuild w/Wiseco piston by Todd Kerby, Comet clutch, Swamplites front & rear, 03 Predator Rear Hubs,
ITP Pro Baja Wheels (4x156 front & rear), DG Front Bumper, Fuj Rear Grab Bars and RZR Belt
Old 06-22-2013, 09:38 PM
kohen's Avatar
Member #4527
Yeah I was in some deep water maybe sucked a little water in it is not moving buy its self all the time thanks for all the replys I will have to pull the cover on cvt and check engine mounts
Old 06-22-2013, 09:41 PM
kohen's Avatar
Member #4527
Thinking about clutch kit what would you recommend thanks my bike is a 2012 Polaris xp 28 zillas and 2 inch rubber down lift thanks
Old 06-22-2013, 10:16 PM
x93pgtx's Avatar
Member #25557
Call qsc and have him spec out a clutch for your set up.
2013 850XP HO
F/R Polaris Bumpers
2up Seat / Foot Pegs
HL HD Springs
QSC Clutch kit
27" Grippers
Direction 2 Flares
Lock N Ride Front Box
Lock N Ride Tall Windshield
3000lb Winch w/ Custom Mount
60" Kimpex Click N' go
Custom Plow Wings
Old 06-22-2013, 11:11 PM
lost cause's Avatar
Member #9763
Pull your clutch cover and make sure your belt is good and that you don't have any debris in the clutches. As far as clutch kits go, call adam at quadshop customs for your clutching needs. If you need something more extreme, Airdam is the absolute best clutching.
EPI HD SPRINGS
1.5" SPACERS
GORILLA AXLES
SUPER ATV ARMATURE
K&N AIR FILTER
POLARIS 3500 WINCH
POLARIS OEM BELT
STOCK EXHAUST
Old 06-23-2013, 05:09 PM
Bigmacksportsman850's Avatar
Member #36441
Same thing happened to mine and its in the shop right now. Its the one way clutch bearing. Mine also had a squeak when the belt got warm.
-2014 Polaris Rzr 900xp Orange Madness
-2013 Polaris Sportsman 850xp Red ho
-2013 Polaris Sportsman 500
-2014 Polaris Sportsman 400
-2003 Dodge ram 5.9 cummins Tow pig
Last edited by Bigmacksportsman850; 06-23-2013 at 07:56 PM. Reason: spelling fix :)
atv cvt transmission problems
cvt quad transmission rear clutch clicks in high gear
cvt transmission problems polaris
does polaris cvt belt cause problems
how to get polaris cvt to release all the way
kawasaki cvt transmission problems
no one-way bearing on primary clutch on cvt system
polaris cvt belt failure
polaris cvt problems
polaris cvt transmission
polaris sportsman 400 ho problemncvt
water in atv cvt issues
Battery Problems/HID Problems BowHuntingSportsman500 ATV Repair and Maintenance 4 01-06-2013 06:18 PM
problems with my 07 450 nilsson84 ATV Repair and Maintenance 0 12-19-2011 05:13 PM
Big Problems bkhall Polaris Magnum 7 11-10-2011 05:03 PM
Having problems please help Jacko ATV Repair and Maintenance 6 02-02-2011 02:02 PM
4x4 problems spankster Polaris Sportsman 5 10-18-2010 03:32 PM
