Old 05-03-2010, 06:58 PM
850 xp's Avatar
Member #4692
2010 850xp Engine Noise
New to the site and was hoping for some input.
A few days ago I made the move from Bombardier to Polaris.
I love the machine but am worried about the way the engine sounds.
Almost sounds like loose lifters at an idle then at higher R's has that faint sound you hear with worn crank bearings.
Then when you shut it down there's a rattle in the engine.
The dealer says these are normal noises with the 850's, Does anyone else hear these noises with your machines?
Old 05-03-2010, 07:02 PM
cvjoint's Avatar
Member #4470
I got some noise at lower speeds that sounds like valves chattering. Ask the dealer about it and said it was normal and others do it. 4 valves per cylinder.
2010 camo 850 xp
Old 05-03-2010, 07:14 PM
850 xp's Avatar
Member #4692
Thanks cv
I've even went and looked up videos of these and did notice they all seem to have that issue.
Pretty annoying but hopefully I'll get used to it, Maybe an aftermarket exhaust can drown it out.
And if it does end up being an issue I guess I'll just deal with it then, I did grab the 5 yr extended warranty, Hopefully they wont give me the runaround if it becomes necessary.
2010 Stealth Black 850XP w/EPS, Front and Rear Brush Guards, PIAA Lights, 3,500 Front Winch, 2,500 Rear Winch, Lock n Ride Front Cargo Box, Rear Rack Extender, Alum CV Guards, Hand and Thumb Warmers, 5' Glacier Plow.
2000 DS650, Full Big Gun Exhaust, Stage 3,
Old 05-04-2010, 03:05 PM
PawPaw's Avatar
Member #962
No sound's like that coming from my engine. Smooth for a large bore twin
Old 05-06-2010, 04:29 AM
craigracin15's Avatar
Member #4030
mine sounds like my dirt race car with the valve lash set loose....hopefully it want be a problem...
Old 06-01-2010, 01:35 PM
us27motorsports's Avatar
Member #5105
Send a message via Yahoo to us27motorsports
Even from our dealership from prep to the showroom floor these models have that Noisy Engines! Then again that is alot of power to be to quiet~! lol
Robert Blackwell
It Director
Us27 Motorsports & Trailers
5301 N US127 Hwy
St Johns,Michigan,48879
www.us27motorsports.com
Old 06-01-2010, 02:41 PM
BobT's Avatar
Member #3783
Mine is very quiet. Only 230 miles.
Boilermaker
2010 850 Touring, ATV-Guru Cobra bumpers
Old 06-19-2011, 09:05 AM
MPR850's Avatar
Member #14507
I've to ask, R U sure it's coming from the engine? I've a similar noise, and when listening with a long screwdriver I located it to the tranny. When I shut the engine off I can here the same rattle. When revving it up to about 1800rpm's the noise is compleatly gone! Could it be the flexplate?
Old 06-19-2011, 09:17 AM
lod666ftw's Avatar
Member #14566
IMO, my 2011 is the quitest polaris i've ever owned. It has the usual cluck in driveline that there famous for. When I bought my frist polaris in 01, I thought it was gonna blow up or break everytime I rode it. I have 9000 miles on that 01 500 ho and never have done anything but chane oil and put gas in it. Changed belt twice. I have 700 miles on 850 and I think it is almost to quite fo the power they create.
2011 850 XP pursuit camo
26" Sedona Ripsaw Tires
Lock and ride front box
QuadBoss rear box
2001 500 HO
26" Mudlite XTR's
Old 01-04-2012, 06:26 PM
dragking's Avatar
Member #21812
my xp 850 engine was quiet for 3400 miles then main bearings went out. crank was walking in block , flywheel was rubbing on oil pump cover. mine sounded like wrist pin knocking when i tore it apart. slyder01 had same problem.
2010 polaris 850 xp bearing noises
850xp engine noise
850xp knock at idle
atv engine sound\
new polaris ranger engine knock
polaris 850 engine
polaris 850 engine noise
polaris 850 valve adjustment
polaris 850 xp noise
polaris 850 xp noisey engine
polaris engine noise
polaris ranger 700 engine knocking
polaris sportsman engine tick
polaris xp 850 engine for sale
symtoms of valves to loose on 850 xp
used polaris 850 xp engine
valve adj 09 honda rancher atv
valve adjustment on a 850xp
who makes polaris 850 engine
who makes the polaris sportsman 850 xp motor
550 xp engine noise jodyford Polaris XP 155 04-06-2012 05:37 AM
Sportsman 800efi engine noise MudslingingSooner ATV Repair and Maintenance 0 04-09-2010 06:39 PM
Engine Noise johnowens Polaris Scrambler 3 02-15-2010 08:02 AM
2010 850xp prairiedawg Polaris XP 20 10-14-2009 10:03 AM
2002 Sportsman 400 Engine Noise P_olaris ATV Repair and Maintenance 2 08-04-2009 02:05 PM
