05-13-2010, 09:44 PM
Member #571
slyder01..my unit's P/S also exhibited the same symptoms you describe.as well as some others. Hopefully you find a competent technician..what you are describing is a problem..and it will most likely be the P/S motor.
05-14-2010, 06:09 PM
Member #3440
I have a lot of confidence in my dealer, especially what they went through and did to get my valve cover that was on back order and wasnt being released until May 7th. They got it on the 5th and had my machine ready that day and i was able to make the club ride that weekend. Also they are going to extend my warranty for the time it was in the shop which was 3 weeks.
It's funny now, today i put new tires on and it seems fine, besides all the noise it makes, when i had it jacked up and no tires on, holy crap! the thing made such LOUD noises and vibration.
Called my dealer today, but a little late, the tech was gone.
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
09-02-2010, 05:38 PM
Member #6953
Hey
Just got reading all the post and thanks for the info. I know its off topic and im new and havent figured out how to navigate the forums yet but I have a 2010 550 and I want to buy a snorkel kit but have had no luck finding one. Can anyone point me in the right direction? Thanks
09-02-2010, 05:56 PM
Member #2920
POLARIS SPORTSMAN XP 550 500 600 700 800 850 SNORKEL KIT
 - Polaris 3500 Winch
- Viking Hause Fairlead and Safety Thimble
- Elka Stage 1 Triple Rate Shocks with Rebound
- Front Lock n Ride Storage Box
- WES Lock and Ride Rear Touring Box
- Rotopax Front Storage Fuel Cells
- Hand Warmers
- Garmin GPSMap 62S
- 27" Grim Reapers
- 8000K HID Lights
09-03-2010, 11:18 AM
Member #5401
Hopefully this is an isolated incident but something else to watch out for on the 2010 850 Sportsman XP. Bought mine the end of May and the shift lever was hard to move at times. The dealer said that was normal, but something still didn't feel right. 2 weeks ago the entire shift lever stripped out and I was stuck in reverse. Luckily I was out of the woods and could back the trailer close. It appears the clutches were out of alignment and could not shift properly. The dealer could not even manually shift out of reverse with a pair of vice grips. Only reason this may not be isolated is when I went for an ATV saftey training course someone else had a 2 up 850 XP and was experiencing the same issue. I am not a Polaris basher, I love the ride from the XP, just a warning so you won't get stuck somewhere when the shifter strips out.
09-07-2010, 12:33 PM
Member #3440
if the shifter feels real hard to shift while out riding, dont force it, turn the machine off, then shift it.. that will work until you get the problem fixed.
RIDE ON !!
09-07-2010, 07:24 PM
Member #628
Originally Posted by cvjoint
They said all these things about the RZR-S that I owned. The axles pop out. The air box takes in dirt and the motor blows up. I had none of these problems. And I rode all the side by sides and the S rode the best. They are saying these things about the 850 xp and its the best riding quad out there. I rode all the other brands before I rode the 850 xp and its the best riding and well thought of quad. I will probably have these problems also but I will deal with them.  I don't think there is another quad out there now to compare to the 850 xp. I know. I know the can-am's power and speed. But I really don't think its well rounded like the 850 xp is. Just my 2 1/2 cents. I am not Polaris loyal. I owned alot of other quads and older Polaris quads also. But with this new design of the XP I think its the best one out there.
IMHO Polaris has the best riding atv in the business period with the XPs and even with the older 500/800 bodystyles.....However as an overall 4wheeler, it is not in the same league as Can Am atvs PERIOD. Especially in the engine and reliability department. I would not even compare the two.
Yeah Can Ams cost more. But its a gaurentee that you will have more money tied up in a Polaris for maintenance over a 2 to 4 year period than you will in a Can Am. Yeah Can Ams have some issues and some lemons, but nothing like Polaris.
I can honestly say though that I would still buy one (Polaris) over any Japanese atv out there.
I've been a loyal Polaris owner for 6 years and I would buy another one in a heartbeat, but dragging out the toolbox out all the time gets old sometimes.
 CAN AM
06 Sportsman 500efi LE. 26" Big Horns
09 Mossy Oak RZR w/ 26" Bajacross, Big Gun exhaust
10 Can Am Renegade 800R Muzzy pipe, Dobeck, Precision Steering Stabilizer and anti vibe mounts, Grim Reapers, Twin Air, graphics kit
09-08-2010, 01:19 AM
Member #6015
Well I've got around 1000 miles on my 2010 and don't think I'm having any of the problems with wheel bearings, or power steering unit. I'll double check the wheels out later today but have not noticed anything. If something is going out I'll chime back in. I've never been in a mud hole over 4" deep and running stock offset wheels with 26" Bighorns. I have been down many rocking, rutted out roads at high speeds so if anything is going to fail it is a good test.
2010 Sportsman 850XP EPS, 3500 Polaris winch synthetic cable and remote, front and rear brush guards, 5 HID lights, lock and ride rear box, Bighorn 26" tires on stock rims. Hand and thumb warmers.
Brute Force AMR 840 13.1-1, X4 Cams, Muzzy Pro, over-sized 39MM carbs, plus 1.5 mm over size valves, Big Kev performance full race port, JH machine clutch, programmable dynatek, Boss Noss wet nitrous system.
09-08-2010, 04:51 AM
Member #3440
I have 1200 hard miles on mine, all my a-arm bushes are loose which that happened 500 miles ago. The machine is a maintenance nightmare, for greasing i mean, wish popo would put sealed bushings in. As for the engine, no problems there, runs great nd tons of power and love the smoothness of the ride and the power steering and that's why the parts get beat to crap. You don't feel the heaviy rock hitting.
I know one thing, ITP XTR tires don't hold up to the abuse an 850xp can put out... my right rear side wall got 4 plugs in it, all at once and 2 weeks ago i got a quarter size blow out in the other rear in which i had to order another one and these tires only have 500 miles..
RIDE ON !!
09-08-2010, 02:16 PM
Member #6015
I stand corrected on my mileage I've only gone 600 miles but just blocked mine up and tried to find anything loose and either I don't know what to look for or nothing is worn out. I know what wore tie rod and wheel bearings act like and mine are still tight. A-arm bushing don't have any play yet. I did have my fittings all greased at 20 hour oil change.
One thing I need to stress most of my riding is mountain and desert so I rarely get in much water other than a occasional mud puddle I can't go around and my wheels are the stock off set and this is a 2010 January build. Not sure if they made any changes from first year.
2007 polaris ranger xp recall, 2008 polaris ranger xp vibration, 2011 polaris ranger 800 xp problems, 2011 polaris ranger 800 xp recall, 2011 polaris ranger 800 xp recalls, 2011 polaris ranger rough idle, 2011 ranger xp grease points, how to calculate offset for aftermarket wheels for polaris 850 xp, polaris ranger 700 xp vibration problems', polaris ranger 800 xp idle problems, polaris ranger 800 xp problems, polaris ranger 800 xp problems or recalls, polaris ranger recall 2011 xp, polaris ranger vibration problems, polaris ranger xp 800 tie rods, polaris ranger xp vibration issue, ranger 800 xp front arm problems, rebuilt polaris rzr front drive shaft, rough idle on 2011 polaris ranger, why does my tires lean out
