Old 05-18-2010, 05:06 AM
SLxp550's Avatar
Member #4836
Help, is my bearing is bad? 2010 550XP
well i put the atv on a jack to tighten the suspension up a little and i noticed there is a very little play in the front right wheel. the left side is solid. does this mean my bearing is going? there are only 32 miles on the machine. i just bought it....if so does it make this unsafe to ride? im talking about maybe 2cm of play. zero play on the other side though.
2010 550xp
Mossy Oak camo
3500 synthetic Polaris winch
front & rear delux brush guards
Front storage box
When in doubt.......Throttle Out.
Old 05-18-2010, 10:00 AM
SCain's Avatar
Member #4224
If it is a bearing, the more you ride it the worse its gonna get, since its a new machine I'd get the dealer to fix it. Just my .02
Old 05-18-2010, 10:16 AM
slyder01's Avatar
Member #3440
they usually have just a little play, i'm surprised the other side doesnt have any at all. To feel better, you can have your dealer look at it, i'm sure it's okay though
RIDE ON !!
2010 Sportsman 850 XP EPS
2008 Sportsman 400 H.O.
Old 05-18-2010, 10:24 AM
SLxp550's Avatar
Member #4836
i'd really rather not have to load it up. im an hour away from the dealer. or more depending on traffic. I called and they said they usually have a little play in them but bring it in and the will check it out. said may just need to be tightened. I know on a vehicle you dont want any play....thatss where im wondering if the bearing is bad...
2010 550xp
Mossy Oak camo
Front storage box
Old 05-18-2010, 10:27 AM
slyder01's Avatar
Member #3440
you can take off the wheel and tighten, they are easily done
RIDE ON !!
Old 05-18-2010, 10:51 AM
SLxp550's Avatar
Member #4836
thats my plan for this evening. pullin the wheel to see what i can get into in there. anyone know a torque setting for this?
2010 550xp
Mossy Oak camo
Front storage box
Old 05-18-2010, 04:28 PM
SNW629's Avatar
Member #1414
they do have just a little free play,mine had a little in the r/f new. just replaced my left rear, torque is 80ft lbs.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
Old 05-18-2010, 04:47 PM
SLxp550's Avatar
Member #4836
I did pull the wheel off and take a closer look. it is not the bearing rather theres a little play up and down above the hub assebly where it meets the upper a-arm joint. in that joint is where i get more like a 1/16th up upward movement before the suspension takes over. is that atleast normal??
2010 550xp
Mossy Oak camo
Front storage box
Old 05-19-2010, 03:20 AM
SNW629's Avatar
Member #1414
there should be no free play in anything BUT the wheel bearing on a 32 mile xp. what you describe seems to be the ball joint moving up and down in the knuckle like what the recall was for. early 2010 where part of the recall,i would have the dealer check it for free play.
09 850XP EPS
Old 05-19-2010, 07:41 AM
SLxp550's Avatar
Member #4836
got it loaded in the truck. heading to the dealer this afternoon. will let you all know how it goes.
2010 550xp
Mossy Oak camo
Front storage box
bad atv wheel bearings
free play in polaris wheel bearings
freeplay sportsman wheel bearings
front right wheel bearing for atv
how do i know if my wheel bearing is bad on my atv
how do i know if the rear wheelbearing on my atv is bad
how to know if the wheel bearings are bad in atv
how to tell if your wheel bearings are bad on your atv
i have a little free play on my front wheel
polaris 550 wheel bearings
polaris ranger front wheel bearings bad
polaris sportsman bad bearing
polaris xp bearing
polaris xp 550 hub
polaris xp 550 wheel bearing cap
polaris xp 550 wheel bearings
should rear atv hubs have a little play ?
should the rear hubs of an atv have a little play
sportsman xp front wheel bearing
will it hurt wheel bearings if i ride with a little play atv
2010 550XP with Oven!!! MNForestRider Polaris XP 44 08-19-2011 04:18 AM
2010 550XP EPS Browning Camo - Rims & Tires MNForestRider ATV Wheels & Tires 16 06-19-2010 10:14 AM
How to set idle 2010 550xp?? MUDDIE49 Polaris XP 13 06-07-2010 07:46 PM
Big Horns on 2010 550XP Questions Qman ATV Wheels & Tires 6 03-18-2010 03:32 PM
2010 polaris 550xp browning bcrook97 ATV Purchasing and Price 3 01-20-2010 10:52 AM
