Front differential output seal leaking - Polaris ATV Forum
post #1 of 10 (permalink) Old 05-12-2014, 07:14 PM Thread Starter
Boundertom's Avatar
My machine is a 2011 850 Touring LE. I just noticed some leakage from the front differential at the right axle. Diff fluid is down slightly, ADC fluid is fine. I am wondering how difficult it is to replace the seal. Obviously, the axle needs to be removed. But, can the seal then be removed, or does the side cover of the diff have to be removed? If that is the case, how much trouble could I get into there? Ironically, I still have Polaris extended warranty, but I am traveling for the summer, and don't want to tie up the machine for an extended time. I do plan to talk to the dealer in Flagstaff tomorrow, and see if they might be able to help out.
I may just keep a close watch on the fluid, and keep it topped off. But, I expect to put 2,000 to 3,000 miles on in the next few months. Currently at around17,500 miles.
I should have bought a service manual 3.5 years ago, but I will be getting a new machine in the fall, so don't want to spend $ on a manual now.
Any advice is appreciated! Thanks!
Tom, currently in eastern AZ
Boundertom is offline
post #2 of 10 (permalink) Old 05-13-2014, 08:03 AM
alleghenyamerican's Avatar
I cant answer your question off hand, but did i read that right, you have 17,500 miles on your 2011 850 touring?
2016 850sp
alleghenyamerican is offline
post #3 of 10 (permalink) Old 05-13-2014, 10:54 AM
Vibe's Avatar
Pull the axle and change the seal, if oil can get out water can get in
2012 Sportsman Touring 850 Bronze Mist LE
Vibe is offline
post #4 of 10 (permalink) Old 05-13-2014, 05:56 PM Thread Starter
Boundertom's Avatar
I made an appointment for the Flagstaff dealer to check it out next week. I ordered the seal kit, so it will be on hand. Polaris doesn't sell individual seals, only a kit with all the seals for the differential. Hopefully it will be an easy fix.
AA: actually, I guess I lied a bit about the mileage. I was guessing when I made the original post. I just checked and it is at 17,399. My friend and riding partner has the same machine, and just turned over 20,000. BTW, I see that you are in Dublin, OH. I lived in north Columbus all my life, until I retired in 2005.
Tom, camping in the Ponderosa Pines in eastern AZ
post #5 of 10 (permalink) Old 05-14-2014, 04:45 AM
I'm definitely jealous. I'm lucky to get 400 miles a year now. Columbus isn't exactly the hot bed of atving. Just curious after all those miles have you had to replace anything major on your touring?
2016 850sp
post #6 of 10 (permalink) Old 05-14-2014, 06:03 AM
Diesel man 03's Avatar
I have 1600 miles since 2005, and that includes using it for snow plowing, I have a 500.
Diesel man 03 is offline
post #7 of 10 (permalink) Old 01-10-2017, 05:49 PM
Gulf550's Avatar
I know this is an old thread and I'm not trying to hijack it, but I am having the same problem on my 2010 850 Xp. My right front output seal is leaking. Well I drained the fluid and it was milky. The seal itself is not hard to replace. But I have a question on how the seal started to leak. I recently installed a triangle atv snorkel kit. The snorkel kit has you put bellows on the vent tubes to make it a closed system incase you would submerge it, water won't go into the differential through the vent tube. Now is that a good idea putting the bellows on the vent tube? Could to much pressure build up in the differential to cause the seal to let loose? I don't have much expierence with different types of snorkels, and was hoping for some input from other members.
Gulf550 is offline
post #8 of 10 (permalink) Old 01-11-2017, 07:50 AM
cariboo's Avatar
i am not a snorkel guy but the vent tube is a open system for the oil to expand and retract and if you close it the pressure has to go somewhere.
why not to the seal?
cariboo is offline
post #9 of 10 (permalink) Old 01-11-2017, 09:21 AM
Battle_Design's Avatar
The bellows allows pressure to expand and con tract as needed. Now if the seal was already going, the added bit of pressure might have helped it fail.
850 XP
Battle_Design is online now
post #10 of 10 (permalink) Old 01-11-2017, 04:56 PM
Gulf550's Avatar
Thanks for the replies. I got the seal changed out tonight. I agree with both statements. So I decided to run all the vents tubes back up to the headlight pod. I never expect to go that deep anyways. I will do a test run around the sub division to annoy my neighbors and change the front diff fluid again. Hopefully I didn't mess anything up in the diff. Thanks again for the input..
Gulf550 is offline
Transmission's front output shaft seal? Doc_Holaday Polaris Sportsman 5 03-16-2014 09:54 PM
Inner front hub seal leaking potminer Polaris Scrambler 5 04-27-2013 05:47 AM
Front diff seal leaking shore Polaris XP 15 12-24-2011 04:42 AM
Leaking from front hub seal 99 sportsman 500 RMR ATV Repair and Maintenance 6 09-28-2010 01:56 PM
Seal leaking, front differential HappyCamper ATV Repair and Maintenance 1 04-17-2010 09:26 PM
