Old 06-06-2010, 04:54 AM
Sage crusher's Avatar
Member #5300
XP550 EPS -Strange Noise- help!!!!
just got the new 2010 XP 550 EPS home last night- and when I was shining it and removing the warning stickers-- and setting the clock I noticed a very different and disturbing noise.
When I turn the key on and the fuel pump primes ( motor not running)
( I was playing with the power steering)
There is a gurgling noise that is constant. It sounds like a coffe pot when it get's down to making the last bit of water-
It appears to be coming from the lower left side down around the dip stick area.
The noise never goes away until I turn the key off- and if I start the quad it is to noisy to here if it is still there.
Setting the clock and other functions just by having the key on this is very noticable..
ANy HELP? or is this a normal annoying sound to just used to??
S.C.
1995 Xplorer 400L
2005 Sportsman 800 Hunter
2010 Sportsman 550 EPS
Old 06-06-2010, 05:08 AM
Nobike's Avatar
Member #3904
call the dealer and have them make a note of this complainant you only have 3 mt warranty my new xp550 without power steering never made this noise if it continues take it back I've had my xp 5 mt ride hard and its perfect
2010 550 XP
Old 06-06-2010, 05:17 AM
Member #5300
Warranty
I was never offered an extended warranty-
Can you shed some light ( cost) and can I still obtain it?
I went out this morning when the motor was cold and t still makes the noise-
Only thing i can think of is the power steering unit as this is when it has power to it initally
1995 Xplorer 400L
Old 06-06-2010, 05:47 AM
bukaty's Avatar
Member #4899
Low on gas? This machine is fuel injected and the fuel pump may be sucking air
Old 06-06-2010, 06:03 AM
Member #5300
Nope-
Full tank from the dealer and the gauge reads full
Is anyone having this noise from a EPS model?
Thanks for the help so far guy's
1995 Xplorer 400L
Old 06-06-2010, 06:48 AM
SNW629's Avatar
Member #1414
normal noise from the eps with the key on. some may make more noise than others.
09 850XP EPS
RT30 WARN WITH KFI MOUNT
Old 06-06-2010, 09:59 AM
Member #5300
No Way this is normal-
do you know what noise I am talking about?
I just pulled the EPS fuse and the noise stopped- replaced it (hot) and the coffe maker sound came back--
So it is the EPS unit, but now is this normal or not...
I will be going to the local dealer ( not where I bought mine) and see if any floor models makes this grugling.
1995 Xplorer 400L
Old 06-06-2010, 03:43 PM
Banshee's Avatar
Member #5082
Can't help with the noise, but supposably, You should be able to get the extended warrenty at any time up to the expiration of standard warrenty. Talk to your dealer about that.
Old 06-06-2010, 05:27 PM
chopper89's Avatar
Member #1634
Cool
SNW629 is right its normal. mine has done that from new and got 1400 miles on it and no problems except the recalls.
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
01 polaris sportsman 500 making noise in reverse
2009 polaris atv power steering makes noise at key on
2011 polaris 850 atv gurgling noise in power steering
850 xp power steering turns off
fuel pump for sportsman 550 eps
gasoline gurgling in polaris sportsman 500 tank
jacking points on polaris 550 eps
noise in polaris 550 sportsman touring
noisey polaris 550
polaris 550 eps recalls
polaris eps making npoise
polaris sportsman eps squeak while turning
polaris sportsman jacking point
polaris sportsman xp 550 bad noise
polaris sportsman xp550 shutting off
polaris xp power steering strange noise
polaris xp550 prob lems
power steering polaris xp550
sportsman xp power steering problem
what causes noise from polaris sportsman 550 xp
2009 XP550 with EPS noises whiskerybear ATV New Members 7 06-05-2010 08:30 AM
800 xp noise pdhunter250 ATV General Discussion 4 05-31-2010 04:57 AM
06 scrambler noise -- could be nothing? zeer Polaris Scrambler 2 01-31-2010 04:20 PM
Strange problem Kempek Polaris Sportsman 10 09-01-2009 07:40 PM
TB 330 Chain noise + brake noise bob330 ATV Repair and Maintenance 1 04-20-2009 02:08 PM
