210 550 intermittent EPS warning light - Polaris ATV Forum
Old 06-11-2010, 09:50 PM
Seismic_Pirate's Avatar
Member #5097
I might have known telling someone my EPS sounded and worked great was a bad idea. Next morning I get an intermittent EPS warning light (and engine icon). It "might" be that the steering stiffens up, as well, but it's only happened at higher speeds. It's only come on twice in the same morning and doesn't come up when I start it so it doesn't throw code. Anyone out there have the same issue in the past?
2010 Sportsman 550 XP EPS
60" Moose plow
2500 Warn
Hot grips
Kolpin scabbard
steel front and rear rack extenders
rear lock n ride cargo box + Backrest & rear pocket bags
Old 08-21-2010, 05:42 PM
MikeBaker5501's Avatar
Member #6680
I just purchased an '10 850xp eps today. First 15 minutes were fine, then I had the engine light come on and then EPS light with very same symptoms as yours. Also, I noticed my speedometer was not functioning it continued to read 0. Did you find a solution. I hate to have to run it back to the dealership with only two hours on the machine. Very disappointing start to EPS ownership.
Old 08-21-2010, 11:22 PM
crimson850's Avatar
Member #5005
Ok were you in high or low gear? and were you taking off fast?
2010 Polaris 850XP LE crimson red edition.-TOTALED
Pure polaris front and rear deluxe brush guards.
Pure polaris front and rear a arm guards.
Pure polaris lock & ride tall windshield
Pure polaris lock & ride gun scabbard
Pure polaris steel rear rack extender
ITP terra cross tires
Maxxis RAZR 4 speeds
UNI air filter
oury grips
RATH racing pre runner style chromoly bumper (front)
Ricochet Skid Plate (chassis)
Hot seat performance hypershift clutch kit
SSI decal kit
Powermadd handguard factory rider.
For any of your performance needs I would go with only Hotseat performance. I dont work for them just love there GREAT service and their amazing products[/SIZE][/SIZE][/SIZE]!
Old 08-22-2010, 03:52 AM
Member #6680
I was in high gear coming up a slight grade. I would not say I was getting into it because I was trying to take it real easy with breaking it in. I then stopped read the book a few minutes and tried to run in low for a while and it did it then also. I think it is more RPM driven than H/L driven. I did go under the front cover and push a few connectors in to make sure tight and it worked fine for about 100yds then did the same thing again.
Old 08-22-2010, 05:32 AM
SNW629's Avatar
Member #1414
mike did you check your battery bolts? they come loose a lot on the xp if you do not use some blue loctite on them and can be the cause of many electrical problems.
2010 850XP EPS,ITP XTR,DALTON CLUTCH KIT,WARN RT30,KFI MOUNT.HMF SWAMP XL.
Old 08-22-2010, 08:29 AM
Member #5097
I poked around and found my battery terminals slightly loose. They didn't seem loose enough to effect anything, but the problem never returned after tightening them properly.
60" Moose plow
2500 Warn
Hot grips
Kolpin scabbard
Old 08-29-2010, 04:05 PM
bluecluee's Avatar
Member #4988
I had the same thing happen to me on my 550xp just yesterday. It only has less than 5 hours on it! I turned the engine off and restarted it and everything has been fine since then. Kind of disappointing on a new machine to see that engine light come on. I will post again if it comes back.
Anyone else have ideas?
Old 08-30-2010, 03:39 AM
Member #6680
I broke in an took mine to the dealership. They had to replace the speed sensor. The EPS fades out with either speed or RPM and this is controlled by the speed sensor. Apparently because mine was malfunctioning, it would not fade but simply shut the EPS off suddenly.
Old 08-30-2010, 04:57 AM
Smoothbassman's Avatar
Member #2920
Same thing happened on my 2009. Got those battery bolts tightened down and the issues went away. I put some of those star rings under my bolt heads to stop them from backing out, and after 500 more miles, they still haven't backed out.
  • Polaris 3500 Winch
  • Elka Stage 2 Triple Rate Shocks with Rebound
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
  • Ricochet Full Skid Kit
  • Go Pro Hero 3 Black Edition
Old 08-02-2013, 01:08 PM
Treacherous's Avatar
Member #542
Sorry old thread resurrection... I had this happen on my '13 550 this morning.
Thanks for info!! My negative leads were loose on battery. I need to get some of these star rings.
'13 Polaris 550 XP EPS (1K- miles/90 hours) (4/11/2013 build/Polaristar until 9/2018)(Road legal)
-Polaris Deluxe Front (2876595) & Rear (2876597) Brushguards
-Thor's best ATV mirrors
-Polaris Steel Front & Rear Rack Extenders
-Ricochet full 8 piece kit (black anodized)
-Cecco frame brace
-Silent Rider (ATV Silencer)
-WARN ProVantage 3500
-KFI Winch mount
-Polaris OEM grip & thumb heaters
-Polaris Front lock & ride box
-Thor's 3 Way ATV Hitch 1 1/4" Box type
'04.5 Polaris 700 SP EFI (3268 miles/302 hours) - Gen VI chassis (Original Owner)(Road legal)
'85 Honda TRX 250
Washington Off Highway Vehicle Alliance (WOHVA)
2010 polaris 850 xp eps warning light
2014 sportsman eps warning indicator
eps signal fo 850 sportssman
eps warning light
eps warning polaris
polaris 550 eps warning light
polaris sportsman 550 eps light
polaris sportsman 550 eps light on
polaris sportsman 550 warning lights
polaris sportsman warning light
sportsman 850 cation lights
steering wheel warning lights on polaris atv
Warning labels removed. 850 xp ATV General Discussion 8 05-05-2010 12:55 PM
2008 Sportsman 500...Intermittent Brake pull??? Fattonz ATV Brakes & Suspension 5 02-15-2010 06:47 PM
Bogus Virus Warning from this forum 2000 Xpedition 425 ATV General Discussion 8 02-14-2010 05:50 AM
Low Fuel Warning Light fourlayne ATV Repair and Maintenance 6 01-11-2010 10:09 AM
Hazard / Warning sticker removal? BRKCOP ATV General Discussion 2 01-04-2010 03:44 PM
