Old 09-08-2010, 02:35 PM
03stage2's Avatar
Member #4937
Question Need some quick help with a simple question
IM changing the oil on my 2010 550 xp before my first bug Hatfield McCoy trip tomorrow. Im in the middle of moving so my manual is in limbo. Basically I see the filter and a hexagonal bolt. I assume the bolt is the main drain and then do the flter. However I am having a hell of time getting that bolt out. Am I missing something here? Thanks guys.....
Old 09-08-2010, 03:16 PM
the bolt probably is the main drain, it should be pretty easy to figure out...it might just be very very tight.
Old 09-08-2010, 03:22 PM
MUDDIE49's Avatar
Member #858
Yeah bro,i have the same ride...its torqued on...you have to muscle it loose...just watch your knuckles....Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System
SunPro Temp gauge
Xbow Gripper mount
~DOWN&DIRTY~
Old 09-08-2010, 06:50 PM
nmpolaris's Avatar
Member #3643
Yes, they have gorillas putting the bolt on at the factory. I put a ratchet on mine and gave it a couple of quick, snappy hits and it loosened right up. Don't overtightened when replacing it.
Old 09-09-2010, 04:33 AM
2010 500 HO's Avatar
Member #6458
I think there may be some mention of loctite in the manual. Maybe it's added at the factory. Could be why it's tricky to remove.
Old 09-23-2010, 07:31 PM
03stage2's Avatar
Member #4937
Sorry this is late but you guys are right. When it finally broke loose with a breaker bar it sounded like breaking a piece of glass. Very sharp quick precise breaking sound. Those are some damn tight tolerances....
Need quick answer. disco ATV Repair and Maintenance 5 08-17-2010 06:42 PM
New Member Says Hello - quick question mobilewashexpress Polaris Sportsman 2 08-13-2010 06:37 AM
Did a simple washing kill my bike? jethrob ATV General Discussion 2 06-10-2010 04:38 PM
Need a quick fix 4chevys4me ATV Repair and Maintenance 4 05-29-2010 08:49 AM
Quick fan fix for '04 Sportsman 500 HO Folks ATV Repair and Maintenance 1 02-23-2010 02:54 PM
