Go Back   Polaris ATV Forum > Polaris ATV Forums > Site Issues & Suggestions
Site Issues & Suggestions Problems or questions with the forum? Have a few suggestions to make the site better? Post it here!
Old 07-23-2010, 05:10 AM
bigman223's Avatar
Member #6055
Question 350 sportsman 1993 wont idle any ideas
my polaris sportsman 350 wont idle i replaced the carb and it still wont it runs good but it wont idle. anything would help.
Old 07-23-2010, 03:05 PM
4getful2's Avatar
Member #1234
if the carb you put on there is good and clean( pilot jet and air screw). i'd check the electric throttle control and make sure you have a 1/8" gap.
then make sure you have the carb mounted all the way in the intake boot and tight.
does the engine have good vacuum?? cover up the air intake with your palm and should kill the engine , if not you have a vacumm leak.
strong spark? fairly fresh plug??
Old 07-23-2010, 06:19 PM
bigman223's Avatar
Member #6055
the carb is brand new and i tried the air intake and it seems fine and the throttle controller isn't the problem. my repair man looked at it through and through. i put new plugs in and tested them. idk what the problem is the carb is mounted like it says to in the Manuel.
1993 polais trailblazer will not idle
1993 polaris 350 won't idle
1993 polaris 350 wont idle
1993 polaris 350l will not idle
1993 polaris 350l, idle
1993 polaris idling problems
1993 polaris sportsman 350 service manual
1993 polaris sportsman wont idle
350 polaris sportsman
93 polaris sportsman not idling right
how to clean carb on atv polaris 1993 atv sportsman
polaris 350 still won't start
polaris 350l won't idle
polaris trail blazer won't idle
polaris trailblazer 350 idling problems
polaris trailblazer wont idle
polaris+350 sportsman
02 magnum 325 wont idle good InVermont ATV Repair and Maintenance 1 06-06-2010 11:23 AM
Trailblazer wont idle and bogs 3 Polaris Atvs Polaris Trail Blazer 2 04-19-2010 07:19 PM
Sportsman 500 wont idle Aggiemike Polaris Sportsman 5 04-10-2010 04:00 PM
04 predator wont idle,any advice wil help T PAYNE Polaris Predator 1 03-16-2010 09:42 AM
polaris xplorer 400 wont idle bracbrown1 Polaris Sportsman 2 06-07-2009 05:06 AM
