Is there a problem with the search function? - Polaris ATV Forum
Site Issues & Suggestions Problems or questions with the forum? Have a few suggestions to make the site better? Post it here!
post #1 of 9 (permalink) Old 12-26-2015, 05:11 PM Thread Starter
seven4eight's Avatar
Is the search function not working well? Anything I search for comes up with zero or only 4-5 threads. For instance if I type in 2001 Sportsman 400, it only comes up with two threads. I'm familiar with the search function, and use several other forums. Doesnt matter which browser I use
seven4eight is offline
post #2 of 9 (permalink) Old 12-26-2015, 08:51 PM
JX2K1's Avatar
Wish I could help, same thing happens when I try to use it.
2003 Sportsman 700 Twin
2009 Sportsman 850 XP Camo
JX2K1 is offline
post #3 of 9 (permalink) Old 12-27-2015, 05:28 AM
Old509cc's Avatar
Try this
Seach hints / tricks?
My ride
1999 Sportsman 509
Rebuilt engine. R2C air filter. Block & tank heaters. QSC clutch kit in a QSC primary.
All steel grease-able tie rod ends. HPD steering bushing. 2" leveling kit.
25" Sedona ripsaws on 12" Badlands. Custom shock covers. Oury grips
Backup/work light. LED low beams. HID 35W high beam. Rev override switch delete.
Alba water temp, VDO volt, oil temp and pressure gauges. Cooling fan indicator light.
Hand and thumb warmers. Borla 14" Pro XS muffler. Custom prop shaft lock collar.
Dad's
2014 Sportsman 570 EPS
2500 Polaris winch. Polaris hand warmers. Lock and ride windshield. 60" Glacier plow.
Brothers'
2006 Sportsman 500 HO
Polaris 2500 winch. 24" box. Custom prop shaft lock collar.
2014 RZR S 800
Superwinch Tera 3500. Polaris roof, custom mounts. Pawltector parking brake.
Front & rear bumpers. Custom fire extinguisher mount. Rear diff pinion nut Torqued.
Faithful friends no longer with us
2004.5 Sportsman 500 HO.
2007 Rincon 680
Old509cc is online now
post #4 of 9 (permalink) Old 12-27-2015, 04:11 PM
807VikingMetal's Avatar
Its garbage, HCS uses the same software.
2012 850xp eps
32" Sludgehammers -5"/2" lift -Turner eagles
MSA battles 5+2 - GSE filter/Pipe - Ranger Gears
HD springs -QSC clutch kit/ EPI HD belt
Heretic Lights -Front diff fix -Cecco frame braces
Jccapri bushings -Swaybar removed.
07 IQR 685 144 sold
807VikingMetal is offline
post #5 of 9 (permalink) Old 12-28-2015, 02:13 PM Thread Starter
Ok, just making sure. Always like to use search function before asking any questions, like anyone with half a brain should do.
post #6 of 9 (permalink) Old 12-29-2015, 06:47 AM
MustBeNice's Avatar
I've found the search engine needs a word to be over 4 characters (5+) long to retrieve anything.
I have also found it's easier to do a Google search for what you are looking for and just include "polarisatvforums" at the end!! Example..... Google search for: "2001 Sportsman 400 polarisatvforums" and you may find useful information?!
Good Luck!
Matthew "MustBeNice"
MustBeNice is offline
post #7 of 9 (permalink) Old 12-29-2015, 08:00 AM
Old509cc's Avatar
^^ that's what the thread I attached was for. In it I suggest doing what I do, include "site:www.polarisatvforums.com"
My ride
1999 Sportsman 509
Dad's
Brothers'
2014 RZR S 800
2007 Rincon 680
post #8 of 9 (permalink) Old 12-30-2015, 06:51 AM
MustBeNice's Avatar
Well then.... great minds think alike!
post #9 of 9 (permalink) Old 12-30-2015, 08:20 PM
Old509cc's Avatar
Ya got that right!
My ride
1999 Sportsman 509
Dad's
Brothers'
2014 RZR S 800
2007 Rincon 680
Go Back   Polaris ATV Forum > Polaris ATV Forums > Site Issues & Suggestions
exhaust problem yasam Polaris Scrambler XP 2 12-16-2015 06:29 AM
PROBLEM: Polaris 2006 Sportsman 800EFI Cranking problems gagobbler ATV Repair and Maintenance 1 12-14-2015 03:32 PM
Sportsman 500 ho dash cluster problem hunte567 ATV Repair and Maintenance 0 12-05-2015 05:50 PM
Shifting problem 14red570 Polaris Sportsman 570 12 12-02-2015 11:54 AM
Electric Problem hunte567 ATV Repair and Maintenance 2 11-28-2015 08:56 AM
