01-20-2012, 10:04 PM
ProVantage Plow with Power Pivot is the bomb!
01-20-2012, 10:05 PM
Member #10066
Hey Thor how'd those sti's do in the snow? Better than the reapers you love so much?
01-20-2012, 10:10 PM
They have done a great job so far. A great tire for the money. I am going to take them out for longer ride in fresh snow tomorrow & will let you know.
01-20-2012, 10:16 PM
Member #10066
Sounds great. BTW your new ride looks awsome!
01-20-2012, 10:22 PM
Thank you!
01-21-2012, 01:11 AM
Member #16252
Originally Posted by Thor
After plowing with the power pivot I must say this is the only way to go. Cuts the plow time down. It makes plowing much easier & when finished the job looks like it was done by a pro! Any questions on this unit feel free to call the shop & ask for me. [/IMG]
I would have to agree 100% . It is a pricey option, but when you consider that the 60" blade is only 1 ft shorter than a typical plow for a Chevy Colorado or Ford ranger, you realize how good a value it is. I've only plowed 3 times since I got it, but it's been worth very penny and seems like it can do pretty much anything a small pickup truck can do anyway.
1998 Xplorer 300-Stock
01-21-2012, 08:08 AM
After I was done plowing today I went for a test run. The tires did a great job in 8 to 12 inches of snow. Both in 2wd & 4wd. The nobs clean out very well giving you the traction needed. These touring units are sure smooth at higher speeds. I am going to like this new unit!
02-05-2012, 08:09 PM
Member #22869
Did you upgrade the swing
So, I'm wanting to go with the center mount Provantage 54" blade- I have a new 2011 850XP. I weigh in at 200lbs. Would you go with a stiffer spring? I will plow about 15 times a winter and my driveway is about 300 feet.
2011 850 XP
2,500 lb winch on a KFI mount
Warn ProVantage 60" blade on a center mount
and a wish list a mile long
02-05-2012, 08:17 PM
No, stick with stock you will be fine. I do carry the mid mount system also. Feel free to give me a call at the shop. I do also have a used mid mount in stock if you want to save a few $$.
Thor
how does polaris touring plow, plow, polairs power plow, polaris atv, polaris touring pivot plow, polaris winch warn plow thor pivot, warn plow
