Squealing noise on 850/1000 - Polaris ATV Forum
post #1 of 10 (permalink) Old 04-10-2018, 11:35 AM Thread Starter
dslanec's Avatar
We are at Hatfield McCoy right now. Were from northern Michigan. We went on our 1st ride here today. After a bit of riding I noticed my machine was making a noise I had never heard before. When we stopped my wife said the same thing about her machine too. At idle it doesnít make it. As soon as you take off up until about 4500 rpm it makes it. Soon as you get over that rpm it stops. The machines run fine nothing wrong that we noticed. It just weird that both machines are making the same noise and neither have made it before? Is it something to do with being at a different elevation? Iím attaching a video so you can hear it.
2017 sportsman 850sp
Cecco pinion cover
Carbon fiber valve stem caps
Billet aluminum gas cap
Hand and thumb warmer
Rear Polaris led brake light
Atv guru front Bumber
Elka stage 3 shocks
Wife's
2018 sportsman 1000XP
RVS stage 1 tune
Iron baltic A arm guards front and rear
26" Bighorn tires
Billit aluminum Polaris shifter
Billit aluminum gas cap
Polaris lock n ride rear storage box
Rear rack extender
Front Polaris extreme bumper
Rear polaris extreme bumper
3500# polaris winch
Hays Fab Led headlights & grill
Cup holder storage bag
Hand and thumb warmers
Hand guards
Elka stage 3 shocks
dslanec is offline
post #2 of 10 (permalink) Old 04-11-2018, 12:55 AM
sportsmandan's Avatar
i couldn't hear anything abnormal .
2016 Scrambler 1000 xp
GSE single slip on muffler
Direction2 flares
2016 Sportsman 570 non ebs
Direction2 flares
ITP XTR radials
sportsmandan is offline
post #3 of 10 (permalink) Old 04-11-2018, 06:32 AM
shane-o's Avatar
That is belt noise, use low when moving slow, keeps the belt cooler, it is "normal" noise, get a few miles on and it may improve,
2015 xp 1000 black pearl,
-polaris front and rear bumpers
-polaris hand/thumb warmers
-polaris body guard
-gse slip on
-front diff fix
-cecco frame braces
-lock and ride front box.
-dobeck fuel controller
-big horn originals/mega mayhems depending on the ride
shane-o is offline
post #4 of 10 (permalink) Old 04-11-2018, 06:45 AM Thread Starter
dslanec's Avatar
Itís the high pitched squeling noise. Itís most apparent toward the end of the video.
Cecco pinion cover
Elka stage 3 shocks
Wife's
RVS stage 1 tune
26" Bighorn tires
Rear rack extender
3500# polaris winch
Hand guards
Elka stage 3 shocks
dslanec is offline
post #5 of 10 (permalink) Old 04-11-2018, 06:55 AM Thread Starter
dslanec's Avatar
I donít think itís from being in the wrong gear. My machine has 20 hours on it so it should be broke in. Can you hear the actual noise Iím talking about? You canít hear it right away, more toward the end. Iím getting ready to head out for another day of riding Iíll update later about how it goes today.
Cecco pinion cover
Elka stage 3 shocks
Wife's
RVS stage 1 tune
26" Bighorn tires
Rear rack extender
3500# polaris winch
Hand guards
Elka stage 3 shocks
dslanec is offline
post #6 of 10 (permalink) Old 04-11-2018, 04:39 PM Thread Starter
dslanec's Avatar
Well I put on about 60 miles today. The noise was there all day. Low, high, 2 wheel, 4 wheel , uphill or down hill. As long as the machine is in gear and between 2500-4500 rpm. Iím heading back to Michigan tomorrow so Iíll see if it goes away once Home? On another note the Big Horns performed great at Hatfield McCoy. I would not want to have stock tires in this terrain!
Cecco pinion cover
Elka stage 3 shocks
Wife's
RVS stage 1 tune
26" Bighorn tires
Rear rack extender
3500# polaris winch
Hand guards
Elka stage 3 shocks
dslanec is offline
post #7 of 10 (permalink) Old 04-22-2018, 04:11 PM Thread Starter
dslanec's Avatar
Update once I got back home......The noise completely disappeared. Both machines stopped making that noise. I still donít know what it was but it must of had to do with being at a higher elevation is all I can think of??? Glad spring is finally here in northern Mi so I can get some more miles in.
Cecco pinion cover
Elka stage 3 shocks
Wife's
RVS stage 1 tune
26" Bighorn tires
Rear rack extender
3500# polaris winch
Hand guards
Elka stage 3 shocks
dslanec is offline
post #8 of 10 (permalink) Old 09-28-2018, 06:20 AM
dieseldaryl's Avatar
2012 Polaris 850 xp
Hello,My atv has almost 12,000k on it which is around 7500 miles got to be the biggest pile of junk.Anyway Iíve spent more on this quad in repairs than I paid for it.I was wondering if anybody knows if I could get shock bushings for my quad or does Polaris not make them does anyone have any ideas shocks are 500 $ for the front shocks.Thanks .
dieseldaryl is offline
post #9 of 10 (permalink) Old 09-28-2018, 06:41 AM
shane-o's Avatar
You should likly use the search button or start your own thread , jc capri i believe make shock bushings for your machine
-polaris body guard
-gse slip on
-front diff fix
-cecco frame braces
shane-o is offline
post #10 of 10 (permalink) Old 09-28-2018, 07:35 AM
bp405's Avatar
Yeah JCCapri, garage products, or super Dave's make bushings for your shocks and complete sets for your wheeler!!!!
2011 Sportsmanģ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsmanģ 570-T
2019 Alumaģ A8818
bp405 is offline
2015 570 SP clicking noise 570spclark Polaris Sportsman 13 10-12-2017 12:15 AM
Front Diff Noise and Increase Resistance Issue - '05 Sportsman 800 jimmy_m ATV Repair and Maintenance 9 01-18-2017 04:22 PM
Clicking noise in front end BadBoy1212 Polaris Sportsman 570 1 09-03-2016 05:04 PM
2010 850 touring whining noise Jtmoney ATV Repair and Maintenance 2 08-20-2016 05:11 PM
Squealing noise from clutch/belt? THKSNOW ATV General Discussion 1 01-11-2016 04:05 PM
