Any experience with bearing buddies? - Polaris ATV Forum
 1Likes
  • 1 Post By 303British
post #1 of 3 (permalink) Old 11-11-2018, 04:49 PM Thread Starter
midwest's Avatar
Curious who has real world experience with bearing buddies?? I am picking up a trailer this week and was thinking ahead about them. I have read a few threads and seem to see people who say "I would never use them." Would love to hear the pros and con's, especially if you have experience with them....
midwest is offline
post #2 of 3 (permalink) Old 11-11-2018, 04:55 PM
303British's Avatar
Well if you want to put in the work you will always have the wheel bearings greased. Pro
They throw a lot of grease out when you drive and the wheels and rims are always greasy and the grease attracts a lot of dirt/dust Con
If you are running those little 8 inch rims especially with a boat trailer (High speeds and in out of water) I would use them
If you have 13 inch or larger rims i probably wont use them
sportsmandan likes this.
303British is offline
post #3 of 3 (permalink) Old 11-12-2018, 02:16 PM
Tigman186's Avatar
FWIW, I run them on every trailer I own, from my little 4x8 to the big boat, four place sled trailer, jet skis, everything. The ONLY bearing work I've had to do in the last five years was on the boat trailer. not because the bearing went bad, but because the hub bore that holds the race got hammered out. Bearing still felt like new. Aside from jacking up the trailer and checking for wheel play once, MAYBE twice per season, that's it. And I log thousands of miles on each of my trailers every year. Sled trailers get around 10,000 miles every year, boats around 5,000 each, same with the skis. just pump them full of grease once in a while, and you're good to go. JMO
Tigman186 is offline
New 35mm Wheel Bearing Greaser For Polaris ATV/UTV TigerTool Jansen Motorsports 1 01-06-2018 05:37 PM
Atv Wheel Bearing Replacement - EASY INSTALL! BradRaziano1 ATV Repair and Maintenance 2 10-09-2017 03:48 PM
2014 570 efi eps transmission bearing bad VT500HO Polaris Sportsman 570 2 04-11-2017 05:58 PM
2008 Sportsman 700 X2 ADC Cover Seal & Bearing Drake323 Polaris Sportsman 0 03-13-2017 05:20 AM
Seized clutch bearing edub ATV Repair and Maintenance 4 12-07-2015 05:36 PM
