One sided trouble. - Polaris ATV Forum
post #1 of 7 (permalink) Old 06-10-2019, 09:52 PM Thread Starter
Auctioneer25's Avatar
One sided trouble.
Hey guys and gals. Having a little issue with my 2011 Sportsman 800. I bought new tires last week. 12x9x27’s. Everything fits except for the right front (if you’re looking at the bike). For some reason the right front tire rubs the tie rod end. I pulled the front wheels off, did a realignment, put them back on...same problem. I checked my ball joints, decided they were a little loose, so I changed them this evening. Put the tires back on and that tire is still rubbing. I have about 3/4” clearance on the left tire but the right one is right up against the tie rod. Any suggestions what could be causing the problem?
Auctioneer25 is offline
post #2 of 7 (permalink) Old 06-11-2019, 03:50 PM
ThorsHammer's Avatar
bent knuckle?
2017 Sportsman 570 Touring EPS
3500 lbs Polaris winch with Synthetic Rope
Front Utility Rack
ODI Rogue Lockon Grips
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
ThorsHammer is offline
post #3 of 7 (permalink) Old 06-11-2019, 05:03 PM Thread Starter
Haven’t thought about that. I’ll take a look. Thank you very much. I’ll let you know.
post #4 of 7 (permalink) Old 06-12-2019, 09:08 AM
did you get just tires, or tires and wheels? if you got tires and wheels, is the offset on one different from the other? easy test, put the right on the left, & visa Versa. if the left now doesn't fit, you've got two different offsets.
Front Utility Rack
4" LED on the pod
  • Dynojet kit
post #5 of 7 (permalink) Old 06-12-2019, 09:16 AM Thread Starter
No...just tires. I did buy the wheeler used though. So someone could have switched the wheels. I’ll try that tonight. The knuckle wasn’t bent...so I can mark that off. 👍🏻
post #6 of 7 (permalink) Old 06-14-2019, 05:50 AM
midwest's Avatar
Dumb question but was it rubbing with the old tires?
midwest is offline
post #7 of 7 (permalink) Old 06-14-2019, 08:09 AM Thread Starter
No it wasn’t. But they were stock, so smaller tires. The larger tire revealed the issue. The local Polaris dealership replaced a cv axle on that side...I wonder if there is a possibility they put a shorter axle in? That would change the pitch of the housing.
