Tie-Rod really close to tire - Polaris ATV Forum
 1Likes
post #1 of 13 (permalink) Old 05-15-2019, 09:25 AM Thread Starter
Mossyoaklgock's Avatar
Not sure if this is the right place since it's steering related.
I cannot figure out why one tierod end is so close to one tire but not the other. I've checked all connections, etc and nothing on the suspension, hub or anything connect looks bent or out of place. The only thing I can think of is that one wheel is bent (I do have shake a slow speeds though).
I replaced all the steering components so they are all new and not worn out.
I swapped wheels and when I did that, there was more clearance so that makes be believe that the wheels is bent.
Here are two pictures of what I'm talking about.
If the issue is not with the wheels, what could it be? The strut?
Name:	Polaris Tie-rod - 1.png
ID:	117913   Click image for larger version
Name:	Polaris Tie-rod - 2.png
Mossyoaklgock is offline
post #2 of 13 (permalink) Old 05-15-2019, 09:38 AM
The one is normal. The other not so much.
Post a pic of the wheel that is so close. Are the rims OEM?
I'm not being a smart azz but it wouldn't be mounted backwards would it?
Have the hubs or struts ever been replaced?
polman500 is online now
post #3 of 13 (permalink) Old 05-15-2019, 10:19 AM
HawkX66's Avatar
How are your wheel bearings?
Semper Fi!
04 Sportsman 600 4x4
HawkX66 is offline
post #4 of 13 (permalink) Old 05-15-2019, 11:03 AM Thread Starter
I bought the ATV used so I'm not sure on the wheel bearings. How can I go about testing those? Probably not a bad idea to just replace them anyways.
I'll check the wheels since these tires were on there when I bought it.
Just curious but how would the wheel bearings affect the clearance?
post #5 of 13 (permalink) Old 05-16-2019, 01:57 AM
HawkX66's Avatar
If your wheel bearings are bad enough they can cause your wheel to sit at an angle. They'd have to be pretty bad though. You can check them by jacking up your quad and wiggling the wheel. There shouldn't be any play.
Semper Fi!
HawkX66 is offline
post #6 of 13 (permalink) Old 05-16-2019, 07:04 AM Thread Starter
My wheel bearings appear to be OK since there was no movement. I did swap the wheels and when I did that, both cleared so I'm not sure what is the issue. I'm going to replace the bearings anyways because they are likely the originals.
I compared both sides and measured random points and everything looks to be straight. If it's not the wheel bearings, I'm thinking it could be the wheels and one is slightly bent. But it's odd because it rubs on the entire rotation, not just one spot.
I'll check the hub again but it appeared straight because the wheel sits on it just fine.
post #7 of 13 (permalink) Old 05-16-2019, 07:34 AM
HawkX66's Avatar
Either a wheel bearing is good or it's bad so I don't really see a need to waste your time and money on replacing them. Is it possible you have a front versus rear wheel issue? I'm not sure about your specific set up, but sometimes wheel offsets can be different.
Semper Fi!
HawkX66 is offline
post #8 of 13 (permalink) Old 05-16-2019, 08:40 AM
OP, you never did actually say what machine we're talking about??
Regardless, if the hub and/or strut has ever been replaced on that side, the PO may have used parts from a different year or model machine that has a slightly different mating surface on the hub or a different offset angle for the tie rod attachment hole on the strut which is causing that side to be a little closer than the other.
post #9 of 13 (permalink) Old 05-16-2019, 08:52 AM
sportsmandan's Avatar
i would take the rim u suspect is warped to a tire shop and when they mount it to their machine they will see if its warped, it could be the mounting surface that is warped. A used steel rim is very inexpensive if thats whats on ur quad.
2016 Scrambler 1000 xp
GSE single slip on muffler
Direction2 flares
2016 Sportsman 570 non ebs
Direction2 flares
ITP XTR radials
sportsmandan is offline
post #10 of 13 (permalink) Old 05-16-2019, 09:11 AM
HawkX66's Avatar
A simple spin on the hub would tell him that. The distance to the tie rod end would vary as it's spinning if it's warped.
Semper Fi!
HawkX66 is offline
Schedule of Events | 2019 Discount Tire Rally on the Rocks Discount Tire Discount Tire 0 05-07-2019 03:33 PM
Tie rod mod 2000 Scrambler 400 mcaliebe ATV Brakes & Suspension 8 12-04-2018 04:57 PM
Space between tire and tie rod Levi8599 ATV Wheels & Tires 11 05-04-2017 03:47 AM
DIY Tire Changing BeadBuster ATV Wheels & Tires 1 11-28-2016 04:04 PM
