2014 Polaris sportsman 90 - Polaris ATV Forum
post #1 of 5 (permalink) Old 05-22-2019, 04:49 PM Thread Starter
Rogerbar88's Avatar
My 2014 Polaris sportsman 90 has camber issue in the front tires. The top of the tire is leaning way in and the bottom of the tires is way out. Is there any ideas on what the problem is? Thank You
Rogerbar88 is offline
post #2 of 5 (permalink) Old 05-22-2019, 06:58 PM
Metro500's Avatar
You might consider checking to see if the front shocks are adjustable. Not sure of the technical term but they seem to set at the softest setting if they are adjustable. Look for a large lock-ring towards the bottom of the spring. Iím not an expert on shocks/struts but this changes my daughters 90cc wheel camber. Is the camber off with no one sitting on the machine?
Metro500 is offline
post #3 of 5 (permalink) Old 05-23-2019, 06:34 AM
Yes, it's simply the position of the wheel in it's travel arc - looking at the bottom of the wheel, they camber in at the bottom of the arc and camber out at the top of the arc - typical of the single a-arm suspension of the Chinese entry level quads.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is online now
post #4 of 5 (permalink) Old 05-24-2019, 08:50 AM Thread Starter
Rogerbar88's Avatar
Yes and it is extreme. I tried adjusting the shocks and it seems to make no difference.
post #5 of 5 (permalink) Old 05-24-2019, 09:33 AM
Did you buy it new? If not, I wonder if someone changed the shocks and put on short ones. Maybe the shocks are stuck?
Get the quad up on a jack, basket or something to get the front end off the ground - take one shock off and let the wheel down to check it's camber.
Perhaps if it was purchased used, the PO was jumping with it and landing on the front end hard enough to bend the spindles.
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
2009 sportsman 500 ho (carb) tranny interchangeable with other years? aldom Polaris Sportsman 2 06-23-2018 01:46 PM
Local Dealer Claims... autosport7 ATV General Discussion 17 04-12-2018 02:56 PM
sportsman rear facing "work light" swamped ATV General Discussion 4 03-01-2018 04:09 AM
bleeding brakes procedure 2014 polaris sportsman 400H0 Polaris Sportsman 2 06-24-2017 03:45 PM
