Ebay 570 wheel bearing greasers review. - Page 2 - Polaris ATV Forum
ATV Gear and Gadgets All gear and gadget discussions here!
 5Likes
post #11 of 21 (permalink) Old 04-11-2019, 08:06 AM
midwestatvguy's Avatar
Originally Posted by 98whitelightnin View Post
Just got my greaser in the mail and with 20 miles on the machine, it took between 19-22 pumps of red line cv-2.
Did you clean out all the previous grease? I heard Red Line CV-2 doesn't play well with other greases, curious what your thoughts are on that. Just ordered my front and rear greasers, I'm planning on doing it this weekend. Trying to figure out what grease to use...
midwestatvguy is offline
post #12 of 21 (permalink) Old 04-11-2019, 01:01 PM
98whitelightnin's Avatar
I did not clean the original grease out. Ive been using the red line grease for years in everything from ujoints to steering parts in my trucks and anything else that needs grease and have never had any ill effects. We will see if it does not work good with this polaris because its in every grease zerk I could find. oh and the back two bearings took 30 pumps before starting to push out of the seal.
98whitelightnin is offline
post #13 of 21 (permalink) Old 04-11-2019, 02:15 PM
Wanderer's Avatar
Just got my grease bearing tool yesterday. Worked like a charm. 18 pumps in the front and I'll get to the rears tomorrow. I went with a marine grade grease.
Sent from my SM-N950W using Tapatalk
Wanderer is offline
post #14 of 21 (permalink) Old 04-11-2019, 04:55 PM
30 pumps?!? Good lord lol, can't imagine how dry mine are then. Thanks for sharing your red line experience, reviews are crazy good for it. I'll give it a shot...or 30...
post #15 of 21 (permalink) Old 04-18-2019, 11:43 AM
OkieDan's Avatar
Arenít these the same at half the price?
https://rover.ebay.com/rover/0/0/0?m...2F223455430363
I just ordered this set, will be doing 4 Sportsmans when it gets here.
98whitelightnin likes this.
OkieDan is offline
post #16 of 21 (permalink) Old 04-18-2019, 03:27 PM
1948boat's Avatar
Location: Burr Oak in the summer and ride my motorcycle in FL durring the winter
Originally Posted by Matty View Post
Picked these up for $16 on ebay last month. Over the axle bearing greasers.
The good. They're cheap and fit over the axles. They actually work, so that's a bonus. I used these tonight on my 18 sportsman 570 with 160 miles on it.
The bad... Single hole so you have to then them while pumping the gun.
Not sure I understand the bad, is the word "hold" missing, and what does the single hole have to do with it? What single hole? If they are the same ones I bought it has two o-rings so they should stay neutral, there should be no pressure wanting to move them out, they should stay centered. Not trying to make a big thing out of it, just want to understand your experience since I havent used mine yet.
1948boat is offline
post #17 of 21 (permalink) Old 04-18-2019, 03:47 PM
OkieDan's Avatar
He may be talking about these, which don't appear to have 3 holes (I just ordered these): https://www.ebay.com/itm/22345543036...m=223455430363
I just watched this video:
...and it seems like it does a good job with only 1 o-ring which might help prevent putting too much pressure and pushing out the back seal. I may play with the ones I bought and try them with only one o-ring (keep the one on the end on). I may also drill a second and possibly a 3rd hole in the ones I ordered.
OkieDan is offline
post #18 of 21 (permalink) Old 04-18-2019, 03:51 PM
OkieDan's Avatar
Does the Sportsman 450 H.O. use the same size as the Sportsman 570?
2019 Polaris Sportsman 450 x 3
2019 Polaris Sportsman 570
OkieDan is offline
post #19 of 21 (permalink) Old 04-18-2019, 04:05 PM
OkieDan's Avatar
I know this is off-topic, but I think I figured out why my grease gun is hard to put on and take off after watching this video:
I can't believe I'm just learning this @ 41 years old!
indyred570 likes this.
OkieDan is offline
post #20 of 21 (permalink) Old 04-19-2019, 12:48 AM
I think the missing word is ďTurnĒ. There are a few others on the market that have a 3 hole design so you donít have to turn it while pumping with grease but I donít believe turning it is actually necessary because it fills the ridge with grease anyway. I did turn mine around the axle and had no problem doing it. I can see how 3 holes would be a nice addition but turning wasnít a pain in the least bit. The company that makes the 3 hole design, does not make a 35mm for the front hubs on the 570ís.
Go Back   Polaris ATV Forum > Polaris ATV Discussions > ATV Gear and Gadgets
wheel stud replacement dbweathe ATV Repair and Maintenance 3 01-24-2018 11:01 AM
New 35mm Wheel Bearing Greaser For Polaris ATV/UTV TigerTool Tiger Tool 1 01-06-2018 05:37 PM
Ignition switch 570 sportsman Fivespeed ATV New Members 4 12-15-2017 07:03 AM
polaris 570 2015 exhaut heating gab570 Polaris Sportsman 2 05-19-2017 10:58 AM
