Disappointed in my sportsman 850 - Page 5 - Polaris ATV Forum
post #41 of 48 (permalink) Old 01-15-2017, 06:01 AM
2015Sportsman's Avatar
I agree with you, Polaris is getting sued for the heat issue.
2015 Sportsman Touring 570 EPS White.
Clutch kit, front windshield, bull guards, led bar and 14" wheels with 26" Baja cross tires.
2014 Scrambler 850 XP Stock.
2015Sportsman is offline
post #42 of 48 (permalink) Old 01-15-2017, 07:22 AM Thread Starter
Liftedpsd's Avatar
When I get mine back I'm going to hook a 1200 lb trailer to mine and pull it through sugar sand. Ill bring it in every week until they get tired of fixing it. Adding a new heat shield is NOT a fix IMO.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Liftedpsd is offline
post #43 of 48 (permalink) Old 01-15-2017, 06:40 PM
terb's Avatar
We need to blame the EPA more than Polaris........
2014 XP850 Red
2012 CRF450X
2009 Red Grizzly 700 EPS
2009 Silver Rhino 700
2010 Haulmark 28' race trailer
terb is offline
post #44 of 48 (permalink) Old 01-16-2017, 04:57 AM
bobby25's Avatar
You are very right. They haft make them so lean from factory pass emissions. Can Am is same way have horrible over heating problems. You add fuel to air fuel mixture and fixes your over heating problem
bobby25 is offline
post #45 of 48 (permalink) Old 01-16-2017, 02:17 PM
Farm850's Avatar
RVS tunes can reduce exhaust temps 100-150 degrees, whether that alone will stop plastics melting I don't know. Up side you get more performance.
Farm850 is offline
post #46 of 48 (permalink) Old 01-16-2017, 03:41 PM
TheATVDepot's Avatar
^^^. Curious about this statement. Do you have data to prove this?
2015 Sportsman 570
Polaris 2500 # winch
Polaris Heated Grips and Thumb
Front and Rear Rack Extenders
Winch accessory kit
Polaris xenon bulbs all 3
Superbrite LED tail light bulbs
Tusk Handlebar Mitts
Polaris Glacier Pro 60" Plow, snow flap, and side markers
2008 Outlaw 90
2017 Ranger 900XP Silver Pearl LE
TheATVDepot is offline
post #47 of 48 (permalink) Old 01-16-2017, 05:31 PM
Farm850's Avatar
Yes it will help it some. We can only go so far in the fueling before we go backwards in power. The lower fan temps also help overall running temps too. We are seeing around 100-150 degree difference in exhaust temps through the head pipes and joint area before the muffler.
Thank you,
Ryan
Farm850 is offline
post #48 of 48 (permalink) Old 01-17-2017, 05:27 AM
bp405's Avatar
Talking about lower engine temps I would think putting in a lower temp t-stat in would also be a very effective in lower EGT's.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) FOR SALE KLCFLC Polaris Sportsman 2 02-18-2019 05:57 PM
3280431 ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) KLCFLC ATV New Members 1 09-18-2017 07:52 PM
Shock interchange TDMax Polaris XP 7 07-13-2016 05:21 PM
