Lubrication points on 2017 Polaris Sportsman - Page 2 - Polaris ATV Forum
post #11 of 16 (permalink) Old 03-30-2018, 10:40 PM
bp405's Avatar
The funny thing is the VL chassis of yesteryear had a ton more lube points. All but 9 remain. I have actually added some to my machine. I know it's a PIA for you guys with the XP chassis but I'd personally prefer all the lube points. For what it's worth a grease gun with a flexible hose will help to get those more difficult zerks. They are tips for the grease gun that are a great tool to have as well. Finally some guys have actually changed the factory straight zerks to 45's and 90's to aid in the greasing process.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #12 of 16 (permalink) Old 03-30-2018, 10:46 PM
bp405's Avatar
This is a nice kit that comes with the flexible hose.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #13 of 16 (permalink) Old 03-31-2018, 09:35 AM
markyrocks's Avatar
The lower point on the rear wheel carrier is literally blocked by a piece of metal from the a arm so no amount of zerk gun trickery would get you in there. I just started taking stuff apart until I could access it. Way easier to remove a couple bolts than to bang my head off the wall. But ya I have a flexible hose ect. I do know I need a tip that has a quick connect snap on feature. Mine you have to manually tighten. ... I got it under control tho. I've done a boat load of mods ect to this thing lately, I know this machine like the back of my hand.
markyrocks is offline
post #14 of 16 (permalink) Old 03-03-2019, 09:06 PM
rusherjim's Avatar
Question Good idea on Zerks
You know, that's a pretty good idea on changing the factory straight zerks to 45s and/or 90s. Makes sense to me.
I'm new to ATVs, just bought a 2011 Sportsman 850 Touring EPS. I haven't lubed anything (yet), but have gone through, located the zerks and cleaned them off, in prep. I've found 6 zerks on the front end, 8 zerks in the rear end, and am aware there's one on the back end of the front propshaft. I can see that at least 2 zerks in the rear are going to be near impossible to access, unless I jack the frame up so I can release pressure on the wheels/tires, and get them to drop down a bit. That's probably where it would be good to replace with 90s.
For those that own the same ATV type...did I miss any lube points?
rusherjim is offline
post #15 of 16 (permalink) Old 03-05-2019, 06:59 AM
TomTom's Avatar
I have a 2014 550 Touring,there are 10 zerks in the rear and 8 in the front so you probably missed a few.
TomTom is offline
post #16 of 16 (permalink) Old 03-05-2019, 10:40 PM
rusherjim's Avatar
Yep, thanks for the advice. After your post I went back and found all of them (10 rear, 8 front).
Much appreciated. And for future readers...yes, I know about the zerk located ON the front prop shaft...but apparently located at the REAR portion of that shaft. Again, thanks to all previous posters.
Service manuals cookies ATV Repair and Maintenance 1081 05-30-2019 05:34 AM
ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) FOR SALE KLCFLC Polaris Sportsman 2 02-18-2019 05:57 PM
3280431 ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) KLCFLC ATV New Members 1 09-18-2017 07:52 PM
HMF Exhausts Polaris Sportsman Lineup HMF_Exhausts ATV Performance Modifications 0 05-25-2016 12:17 PM
