2012 RZR 900 XP Voltage regulator and wires overheating.....bad - Polaris ATV Forum
post #1 of 6 (permalink) Old 06-20-2017, 09:32 PM Thread Starter
greengoathead's Avatar
Angry 2012 RZR 900 XP Voltage regulator and wires overheating.....bad
Ok guys, first off, i know this is a RZR question, and i have posted over there too, but this thing is really kicking my butt. any help would be appreciated!
Ok guys, I am really at a deadend.....Long story:
Last fall battery quit charging. Replaced the VR. Still not charging or holding charge, so I bought an Odyssey battery $185. Voltage regulator got extremely hot and buned the floor. I though I had just gotten a bad VR, so I replaced it. Went on another trip and the exact same thing happened. Unplugged and made it back by the skin of my teeth to camp. Got to be a passenger for the rest of the trip, which really sucked. The Polaris dealer thought positively that it was the stator, so bought both a stator and a VR. I now replaced the stator and VR 3 days ago. After running around the block for 2 minutes, I came back to check, and the VR is extremely hot again and the wires coming out of the stator are too hot to touch.
Battery after sitting overnight reads 12.55v
10.8 at the startup hit
14.5 immediately after startup at the battery at an idle
14.4-14.5 at 3000-5000rpm with NO jump during rev or decline from 5000-1200
unhooked the red and black wires from VR to battery and they test at 14.3 up to 14.78 revving to 5000rpm.
hooked back up to battery and again 14.55ish at idle-5000rpm.
unplugged harness from stator to VR and tested all 3 wires at [email protected] // [email protected] // [email protected]
checked ohms on stator at 1.2
pulled the ground wire from frame, wire brushed both the frame to bare metal and connectors are polished shiny bare metal.
I even ran another ground from the battery to the frame in addition (temporarily) and continues.
Battery checked out perfect and borrowed a battery from a buddy, and the exact same scenarios continue to happen.
I am at a complete loss.
Why do I seem to be getting an overcharge and losing VRs? When I changed the stator, all looked normal in there, and I saw just a tiny bit of oil in the stator cover. reading in other places, this is not abnormal, but it seemed odd to me.
Please let me know your ideas, I am at a real loss at this point. This charging system is pretty dang basic and it really has me baffled.
UPDATE: used buddy's battery and same thing. all wires/terminals have been cleaned and reinstalled.
HELP!!!!!!!!!
greengoathead is offline
post #2 of 6 (permalink) Old 06-21-2017, 05:16 AM
bp405's Avatar
Bad wiring is my thought. Go through the wiring harness and look for grounded or shorted wires.
2011 SportsmanŽ 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 SportsmanŽ 570-T
2019 AlumaŽ A8818
2020 OutlanderŽ 1000R XXC (on order, ETA mid-Sept)
bp405 is offline
post #3 of 6 (permalink) Old 09-14-2019, 11:53 PM
billvwi's Avatar
Hey did you ever get a solution to the overheating regulator ? I'm on my 3rd one..
The regulators have never been on trail. Wires start overheat as soon as it starts. One is a Mofset relocation kit. All higher end quality products.
Thanks.
billvwi is offline
post #4 of 6 (permalink) Old 09-15-2019, 03:36 AM
bp405's Avatar
Chk these out https://squareup.com/store/cycleworx...timate-package. Seems to be the answer. Just a better built component designed for the abuse seen out on the trail.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 AlumaŽ A8818
bp405 is offline
post #5 of 6 (permalink) Old 09-15-2019, 05:11 AM
billvwi's Avatar
billvwi is offline
post #6 of 6 (permalink) Old 09-15-2019, 12:44 PM
Do you have any high current accessories? Is the battery the original size? Poor connection between wiring harness and the VR unit will cause hot wires.
latebird is online now
