Biggest wheel and tire combo on an 850 - Polaris ATV Forum
 1Likes
post #1 of 13 (permalink) Old 10-28-2017, 08:37 PM Thread Starter
wpsharpshooter's Avatar
Looking to add some wheels and tires to my 17. What is the biggest set up I can run with out rubbing or needing a clutch kit? Also where's the best deals to be had?
wpsharpshooter is offline
post #2 of 13 (permalink) Old 10-29-2017, 04:40 AM
bp405's Avatar
28" without any trimming. 9" up front 11" on the back, with the OEM spec offset. No NEED for a clutch kit if you aren't hitting deep mud or snow, but highly recommended. Rocky Mountain ATV or Mud Throwers.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #3 of 13 (permalink) Old 10-31-2017, 10:50 AM Thread Starter
Ive heard 28's will fit and no rubbing, Then Ive heard they will rub... Anybody running 28's to confirm my suspicions?
post #4 of 13 (permalink) Old 10-31-2017, 10:55 AM
Mac25's Avatar
28s all four corners, no rubbing !
2013 Sportsman 850 HO XP LE
Kenda K587 HTR 28/14s all 4
Mac25 is offline
post #5 of 13 (permalink) Old 10-31-2017, 11:08 AM
Liftedpsd's Avatar
I ran 30s with minor trimming and hl springs. 28s should be a breeze. Not sure if the 17s changed but look under the front fender there is a fin looking plastic molded piece. I'd cut that off I was told if your tire bottoms out on it it'll crack the front fender.
Sent from my KYOCERA-C6742A using Tapatalk
Liftedpsd is offline
post #6 of 13 (permalink) Old 10-31-2017, 11:16 AM
bobx2's Avatar
Ran 28's on my 850. No problem.
chriswaluk likes this.
2018 Polaris General 1000, Elka Stage 2 Shocks, 29" Tusk Warthogs, Polaris 4,500 lb. winch, Factory UTV Skid Plates, Dux Turn Signal/Horn Kit, EMP Cooter Brown Roof, Ryfab Folding Glass Windshield, Spring Brake Thingy
2015 Sportsman 570 Touring EPS, 26" Kenda Bearclaw HTR's on ITP Delta Steel wheels, Warn Vantage 3000, Elka Stage 1 Shocks, Warn Mid-Mount Plow (Wife's)
bobx2 is offline
post #7 of 13 (permalink) Old 11-03-2017, 06:19 AM Thread Starter
Im guessing since the factory wheels are 14 inch. That I cant go down to a 12 or 13.. Not that I would want to, but what are the advantages of changing up wheel size? I know 12's the tires would be cheaper, other than that? Are there any trail advantages to going up to a 15in wheel over a 14? or is it just preference? I guess you'd gain a little bit of ground clearance but it would be very minimal...
post #8 of 13 (permalink) Old 11-03-2017, 06:21 AM
Liftedpsd's Avatar
The wheel size doesn't get you any more ground clearance. A 26 is a 26 no matter the rims size. If you have an SP you can't go to a 12" rim they won't fit over the calipers. Best bet is stay with 14".
post #9 of 13 (permalink) Old 11-03-2017, 06:41 AM Thread Starter
Mild brain fart on my end .. Yea. you are right... 26 is 26 no matter the wheel size. I am planning on sticking with the 14's. I have looked at wheels and tires till Im blue in the face.. Alot of the wheels I am seeing all tend to look the same... I have seen a few different tires that I like though...
post #10 of 13 (permalink) Old 11-03-2017, 06:42 AM
Liftedpsd's Avatar
What kind of riding do you do? All mud?
What wheel and tire combo for Sportsman 570?? NCTriad570 ATV Wheels & Tires 12 08-27-2017 05:59 PM
Scrambler 500 can I use Stock scrabbler 850 wheel and tire 2016Scrambler850 Polaris Scrambler 1 05-08-2017 10:01 PM
DIY Tire Changing BeadBuster ATV Wheels & Tires 1 11-28-2016 04:04 PM
Aftermarket Wheel / Tire Setup 850scram Polaris Scrambler XP 6 09-26-2016 08:18 AM
