Bleeding cooling system - Polaris ATV Forum
post #1 of 4 (permalink) Old 11-07-2017, 09:36 AM Thread Starter
TgatlinJr09's Avatar
I have a07 500 sportsman x2 efi are there any bleeding procedures for the cooling system after changing the water pump and thermostat? Thanks
TgatlinJr09 is offline
post #2 of 4 (permalink) Old 11-07-2017, 10:08 AM
bp405's Avatar
Get the front of the machine16"-20" off the ground. Run the engine with the rad cap off. Let it go through multiple t-stat cycles until all the air is purged.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #3 of 4 (permalink) Old 11-07-2017, 10:32 AM Thread Starter
post #4 of 4 (permalink) Old 11-14-2017, 01:17 PM Thread Starter
I have done like you said but it runs fine until you put the cap on and then it runs hot no bubbles not leaking fan is running I don't know what else to do
Polaris Glacier Plow system vs Warn Provantage center mount Brightguy ATV Gear and Gadgets 10 10-02-2018 10:10 AM
Fitting another model muffler to '00-'02 Magnum? RacerP Polaris Magnum 5 01-11-2017 05:06 AM
sportsman 400 cooling system spudneck ATV Repair and Maintenance 0 06-30-2016 12:30 PM
sportsman 400 cooling system spudneck Polaris Sportsman 0 06-30-2016 12:01 PM
TheATVSuperStore Mighty Tite Tie Down System after a accident. Thor TheATVSuperStore.com 2 05-20-2016 03:41 PM
