Polaris Front Diff Seal Kit Question - Polaris ATV Forum
post #1 of 4 (permalink) Old 12-16-2017, 10:36 AM Thread Starter
rg567's Avatar
2008 Sportsman 500
Front diff is leaking from all three seals.
I was wondering if seal kit 3234593 contains the seals for all three holes? Polaris dealer is no help and all I can find is a picture of what's in the kit: 2-1.5" seals, 1-1.25" seal, and four o-rings.
Another option would be to purchase the seals seperately but I'm unable to find part numbers online and again, no help from the dealer.
Any help would be appreciated.
rg567 is offline
post #2 of 4 (permalink) Old 12-16-2017, 11:40 AM
Depends on if you have a 500 HO or 500 EFI
polman500 is online now
post #3 of 4 (permalink) Old 12-16-2017, 01:31 PM
According to the information I can get, that kit should have all three seals and the o-rings necessary for a rebuild.
That kit fits all these models -
Assemblies where 3234593 is used:
2007 SPORTSMAN 500 EFI (A07MH50AB/AL/AQ/AX/AY/AZ/MN50AF/AN/AT/AY) - Gearcase, Front (If Built After 7/17/06) A07mn50af/An/At/Ay (49Atvgearcase1332568)
2007 SPORTSMAN 800 EFI (A07MH76AL/AQ/AX/AY/AZ/A2/MN76AF/AT/AY) - Gearcase, Front (If Built After 7/17/06) Mn76af/At/Ay (49Atvgearcase1332568)
2007 SPORTSMAN X2 500 EFI (A07TH50AL/AQ/AU/AZ/TN50AF/AS/AU) - Gearcase, Front A07tn50af/As/Au (49Atvgearcase1332568)
2007 SPORTSMAN X2 800 EFI (A07TH76AU/TN76AF/AL/AU) - Gearcase, Front A07tn76af/Al/Au (49Atvgearcase1332568)
2008 SPORTSMAN 500 EFI SCANDINAVIAN (A08MH50SS/SQ) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN 500 HO EFI (A08MN50AF/AN/AQ/AR/AS/AT/AW/AX) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN 800 EFI SCANDINAVIAN (A08MH76SS/SF) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN 800 HO EFI (A08MN76AF/AL/AQ/AR/AS/AT/AX) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN TOURING 500 EFI (A08DN50AF/AS/AW/AZ) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN TOURING 500 EFI QUAD (A08DN50EA) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN TOURING 800 EFI (A08DN76AF/AG/AH/AL/AJ/AS) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN TOURING 800 EFI INTL (A08DN76FC) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN X2 500 EFI (A08TN50AT/AX/AZ) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN X2 500 EFI QUAD (A08TN50EA) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN X2 700 EFI (A08TN68AX/AZ) - Drive Train, Front Gearcase & Mounting
2008 SPORTSMAN X2 800 EFI LE (A08TN76AA/AQ) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN 500 EFI (A09MN50AN/AX) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN 500 EFI TRACTOR (A09MN50ET) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN 800 EFI 6X6 (A09CL76AA) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN 800 HO EFI (A09MN76AX/AZ) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN TOURING 500 EFI (A09DN50AB/AZ) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN TOURING 500 EFI QUAD (A09DN50EA) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN TOURING 800 EFI (A09DN76AB/AL/AY) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN TOURING 800 EFI INTL (A09DN76FC) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN X2 500 EFI (A09TN50AX/AZ) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN X2 500 EFI QUAD (A09TN50EA) - Drive Train, Front Gearcase & Mounting
2009 SPORTSMAN X2 800 EFI (A09TN76AL/AX/AZ) - Drive Train, Front Gearcase & Mounting
2010 SPORTSMAN 500 EFI TRACTOR (A10MN50ET) - Drive Train, Front Gearcase & Mounting (49Atvgearcase1332832)
2010 SPORTSMAN 500 EFI TRACTOR (A10MN50ET) - Drive Train, Front Gearcase & Mounting (49Atvgearcase1332695)
2010 SPORTSMAN 800 EFI 6X6 (A10CL76AA) - Drive Train, Front Gearcase & Mounting (49Atvgearcase1332832)
2010 SPORTSMAN 800 EFI 6X6 (A10CL76AA) - Drive Train, Front Gearcase & Mounting (49Atvgearcase1332695)
2011 SPORTSMAN 800 EFI 6X6 (A11CF76AA) - Drive Train, Front Gearcase & Mounting
2011 SPORTSMAN FOREST TRACTOR 500 EFI (A11MN50ET) - Drive Train, Front Gearcase & Mounting
2012 SPORTSMAN 800 EFI 6X6 (A12CF76AA) - Drive Train, Front Gearcase & Mounting
2012 SPORTSMAN FOREST 800 6X6 (A12CF76FF) - Drive Train, Front Gearcase & Mounting
2012 SPORTSMAN FOREST TRACTOR 500 (A12MN50ET/EX) - Drive Train, Front Gearcase & Mounting
2013 SPORTSMAN 800 EFI 6X6 (A13CF76AA) - Drive Train, Front Gearcase & Mounting
2013 SPORTSMAN FOREST 800 6X6 (A13CF76FF) - Drive Train, Front Gearcase & Mounting
2013 SPORTSMAN FOREST TRACTOR 500 (A13MN50ET/EX) - Drive Train, Front Gearcase & Mounting
2014 SPORTSMAN 800 EFI 6X6 (A14CF76AA) - Drive Train, Front Gearcase & Mounting
2014 SPORTSMAN 800 EFI 6X6 FOREST (A14CF76FA) - Drive Train, Front Gearcase & Mounting
2014 SPORTSMAN FOREST TRACTOR 500 (A14MN50EM/EA) - Drive Train, Front Gearcase & Mounting
2015 FOREST 800 6X6 (A15S6A76FA) - Drive Train, Front Gearcase & Mounting
latebird is offline
post #4 of 4 (permalink) Old 12-16-2017, 04:12 PM Thread Starter
rg567's Avatar
Thanks for the replies
The ATV is a 2008 HO EFI
I think the kit does include the three seals as well as the two o-rings for the large and small case covers. Problem is since I asked this question, I realized I need more than just seals. Lots of metal transfer and junk bearings...
rg567 is offline
Part number for factory winch, 2013 sportsman 500 HO? Smokinu454 ATV Gear and Gadgets 4 11-28-2017 05:38 AM
Replacing Front diff seal Qs DragonMan Polaris Sportsman 9 10-14-2017 08:32 AM
Replacement front seal differentiel touring 2009 rupp70 ATV Repair and Maintenance 4 01-19-2017 02:12 PM
January 2017 - Polaris ATV of the Month Voting! Wreckless ATV of the Month 0 01-16-2017 06:14 AM
Polaris sportsman 570 2 inch lift kit Daltoncroft6 Polaris Sportsman 570 5 09-18-2016 06:27 AM
