850 exhaust - Polaris ATV Forum
post #1 of 17 (permalink) Old 10-20-2009, 11:00 AM Thread Starter
FL8fitty's Avatar
Talking 850 exhaust
Anyone install a slip on yet for thier 850. I like the HMF Swamp XL but don't know about thier optimizer, I keep hearing shady things about it being hard to dial in. I may have to go with the hotseat and try it w/ out a programmer any ideas? I don't mind loud, We ride in the middle of no where most of time.
FL8fitty is offline
post #2 of 17 (permalink) Old 10-21-2009, 06:31 AM
H2O
H2O's Avatar
I am interested in this slip-on also. I don't think you will have to run a optimizer or a programmer for only a slip-on ..... but a full pipe set I think you would need some added fuel.
2008 Polaris 700 X2
2008 Canam Outty 800 XT
2009 Polaris 850 EPS
H2O is offline
post #3 of 17 (permalink) Old 10-22-2009, 06:19 AM Thread Starter
FL8fitty's Avatar
I just heard from LTE and they are in the process of making the slip-on for the 850 in the next couple of weeks. The dual set-up should be available shortly thereafter. The Outties sound sooo good with thier dual set-up.
FL8fitty is offline
post #4 of 17 (permalink) Old 09-01-2010, 07:09 AM
dawson's Avatar
if you want a warranty on the exhaust you have to put the optimizer on it if you dont care about warranties then you dont have to run one. if you dont care about sound just pull the muffler off it sounds pretty badass.
dawson is offline
post #5 of 17 (permalink) Old 09-01-2010, 03:27 PM
OLDMAN's Avatar
I am running a Hot Seat on my 2010 850 and it does great. I did not put a programmer on it and it does just fine. I have over 800 miles on it and just put new brake pads on and that is it. Runs great.
OLDMAN is offline
post #6 of 17 (permalink) Old 09-01-2010, 03:32 PM
crimson850's Avatar
You do need the programmer. There is a reason they make them!!!!
2010 Polaris 850XP LE crimson red edition.-TOTALED
Pure polaris front and rear deluxe brush guards.
Pure polaris front and rear a arm guards.
Pure polaris lock & ride tall windshield
Pure polaris lock & ride gun scabbard
Pure polaris steel rear rack extender
ITP terra cross tires
Maxxis RAZR 4 speeds
UNI air filter
oury grips
RATH racing pre runner style chromoly bumper (front)
Ricochet Skid Plate (chassis)
Hot seat performance hypershift clutch kit
SSI decal kit
Powermadd handguard factory rider.
For any of your performance needs I would go with only Hotseat performance. I dont work for them just love there GREAT service and their amazing products[/SIZE][/SIZE][/SIZE]!
crimson850 is offline
post #7 of 17 (permalink) Old 09-01-2010, 04:22 PM
Gilly's Avatar
I dont know guys I've talked to a lot of people about a programmer including salesmen and its about a fifty fifty tie wether you need one or not. I think im going to go without.
Gilly is offline
post #8 of 17 (permalink) Old 09-19-2010, 07:57 PM
05sptsman's Avatar
I have a 2005 Sportsman 800 EFI and I run a Super Trapp IDSX Slip on system.
I've added a K&N filter and also installed the air box kit which is 6 1 inch
filtered cutouts to allow for more air to flow. Which in turn lets the motor breathe. To date I have not added a programmer however I may at some point. I won't need to do any Exhaust mods. If I do the programmer will map it for the way I have set up. Super Trapp uses a Disc system in the silencer. These Discs are used to fine tune your exhaust. The unit comes with 12 discs. The're very simple to install or remove. By adding or removing discs you can Richen up or Lean it out your mixture. Polaris EFI's generally come from the factory a bit on the rich side. I'm running all 12 discs. You can feel the difference as soon as you hit the throttle. It pulls longer and it takes care of that flat line power in the mid RPM range. The Exhaust sounds great and if it does for your 850 what it did for my 800 I'm sure you'll be smiling all the way through the MUD HOLE.
05sptsman is offline
post #9 of 17 (permalink) Old 09-19-2010, 09:05 PM
scottdeet's Avatar
I just put the HSP slip-on on my `07 800 efi.
I called and talk to a tech and was told I didn't need a programmer.
So I didn't and it's running fine.
I had my eye on the HMF swamp XL for a long time, but didn't do it as for the
need of the programmer (so I was told from the HMF tech).
I had the swamp xl watched in my ebay, put a call into the store that was selling it and was told you didn't need the programmer either. They sold to many locals that didn't run it with the programmer.
The HSP slip-on was cheaper then the swamp xl, but you have to repack it yourself once a year I was told, more if you like mudding.
I wasn't looking for any additional power, just a different sound.
Take care,
Scott Deeter
scottdeet is offline
post #10 of 17 (permalink) Old 09-20-2010, 01:31 AM
Smoothbassman's Avatar
Hot seat exhaust is insane!
  • Polaris 3500 Winch
  • Elka Stage 2 Triple Rate Shocks with Rebound
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
  • Ricochet Full Skid Kit
  • Go Pro Hero 3 Black Edition
Smoothbassman is offline
Over voltage Keith338 ATV Repair and Maintenance 31 06-06-2019 07:52 AM
'09 850 XP Exhaust options Smitty62 Polaris Sportsman 5 06-01-2018 07:18 PM
HMF Exhaust | Polaris Sportsman 850 SP HMF_Exhausts Polaris Sportsman 5 08-16-2017 08:25 PM
Fitting another model muffler to '00-'02 Magnum? RacerP Polaris Magnum 5 01-11-2017 05:06 AM
Shock interchange TDMax Polaris XP 7 07-13-2016 05:21 PM
