Steering Play Fix - Page 2 - Polaris ATV Forum
 5Likes
post #11 of 27 (permalink) Old 05-07-2018, 08:33 PM
sportsmandan's Avatar
well i checked my bike last night, not too good,
1900 miles,pretty much same condition as yours, i need rear wheel bearings, 1 side is really loose, ill have to wash quad good and see if its also bushings or just bearings,
and up front, there is a ton of play in splines like u said !! , its hard to tell condition of tie rods with all the spline play !!!
The Wife's 570, same mileage almost, also needs rear bearings.
I see you put All balls bearings in your signature list , how are they holding up ?
how many miles on them so far ?
Iíve bought All Balls before , just wondering if they are still pretty good quality. ??
2016 Scrambler 1000 xp
GSE single slip on muffler
Direction2 flares
2016 Sportsman 570 non ebs
Direction2 flares
ITP XTR radials
sportsmandan is offline
post #12 of 27 (permalink) Old 05-08-2018, 02:14 AM Thread Starter
autosport7's Avatar
The All Balls have about 200 H&M miles and another 50 Mines & Meadows miles on them. No movement yet.
sportsmandan likes this.
2015 Polaris Scrambler XP1000
Red Bull Graphics Kit
Spider Graphix - Footwell Dacals
Mud Motorsports Gripper Seat Cover
Rogue Grille - Blk/Blk/Red
Pure Polaris Hand Warmers
Pure Polaris Thumb Warmer
GBC Grim Reaper - 26/9/14 - 26/11/14 on Hiper Sidewinder Beadlocks
All Balls Wheel Bearings FR/RR
ROX Speed FX Foot Pegs
CECCO Frame Braces FR/RR
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Moog SSB Upgrade W/ Custom Zerk
Powermadd Sentinel Handguards
Renthal G169 Grips
Gear
Leatt 5.5 V.05 Turbine - Helmet
Oakley Airbrake - Goggles
EVS Sport - Chest/Back Protector
OGIO Dakar - 3L Hydration Pack
Shift Recon - Pants/Jersey/Gloves
Alpinestars MXGP - Jersey
Alpinestars S-MX Air Carbon Mesh - Gloves
Alpinestars Tech 8 - Boots
autosport7 is offline
post #13 of 27 (permalink) Old 05-08-2018, 03:39 AM
xOUTLAWx's Avatar
you guys are Lucky, I have the 2013 model with the old style steering stem foot so the only way for me to fix this is to change it for the updated pinch bolt model or put red locktite in there. Gonna be a bitch to fill it up since it's a very crowded area.
xOUTLAWx is offline
post #14 of 27 (permalink) Old 05-08-2018, 08:05 AM Thread Starter
autosport7's Avatar
Ours are crowded as well. Just able to get the loctite bottle close enough. Then grab the front wheel at 9 and 3 and move back and forth to really get that loctite down in there. Repeat a couple times and should tighten you up with or without the bolt style.
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Renthal G169 Grips
Gear
post #15 of 27 (permalink) Old 05-08-2018, 09:30 AM
Autosport, so now if steering is tight that means your ball joints are still good than ?
You didn't loosen the bolt a little first ? you just added lock tight.
tks for the replies.
post #16 of 27 (permalink) Old 05-09-2018, 03:51 AM
xOUTLAWx's Avatar
Ours are crowded as well. Just able to get the loctite bottle close enough. Then grab the front wheel at 9 and 5 and move back and forth to really get that loctite down in there. Repeat a couple times and should tighten you up with or without the bolt style.
Ill try that thanks. We are gonna see if it holds up good.
xOUTLAWx is offline
post #17 of 27 (permalink) Old 06-16-2018, 12:57 PM
Duse's Avatar
Originally Posted by Gulf550 View Post
Dang thanks for posting this. I have been fighting Handel bar play since I purchased mine and can't stand it. I've also snapped my bolt. I will try what you suggested.
You will be amazed!
Also had up and down play of my bars along with the left to right play.
For the up and down play, I replaced the upper steering stem bushing. Was great for about 1 ride, then back to play.
A fellow member (chronix) shipped me a Moog automotive bushing that he had customized with a grease zerk. I installed that, greased her up and wuhluh! All steering play now gone! Feels like a brand new machine again!
Good info
Got any more info on that Moog bushing(part # maybe)
I saw in one of your post ,,mines and meadows and your sig (city of champions)
Im guessing thats Pittsburgh?
Duse is offline
post #18 of 27 (permalink) Old 06-16-2018, 03:32 PM
807VikingMetal's Avatar
You will be amazed!
Good info
You just need the rubber part out of a 1 1/4 in swaybar bushing kit, I used a moog K7326.
Use the rubber bushing in place of the 2pc plastic stock one.
I added a grease fitting to the stock strap and made some grooves on the inside of the bushing to hold some grease inside.
Do not crank the nuts tight on the strap before grease/lubing the bushing and testing the steering resistance as this bushing can lock the bars so tight they wont turn.
Cheap effective mod, holds tight and absorbs vibration
Duse and autosport7 like this.
2012 850xp eps
32" Sludgehammers -5"/2" lift -Turner eagles
MSA battles 5+2 - GSE filter - Ranger Gears
RJWC single w/QC and programmer.
HD springs -QSC clutch kit/ EPI HD belt
Heretic Lights -Front diff fix -Cecco frame braces
Jccapri bushings -Swaybar removed.
807VikingMetal is offline
post #19 of 27 (permalink) Old 06-16-2018, 05:37 PM Thread Starter
autosport7's Avatar
You will be amazed!
Good info
Yes Pittsburgh.
Viking has some good info in his previous post.
Duse likes this.
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Renthal G169 Grips
Gear
post #20 of 27 (permalink) Old 11-16-2018, 08:10 PM Thread Starter
autosport7's Avatar
Update:
Few more intense rides and my steering still feels like the day I brought it home.
The other very noticeable difference Iíve found, absolute zero wheel wobble now.
I had a little wobble between 40-50mph. I figured it was the non-balanced 8ply Reapers. This steering fix has taken care of the wheel wobble as well.
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Renthal G169 Grips
Gear
2016 Sportsman 570 Steering Stem Skeaking Like Hell! How To Fix?? Matt_Justice Polaris Sportsman 570 3 11-11-2016 07:13 AM
Play in Steering after replacing Post moore3cam Polaris XP 7 09-07-2016 05:40 PM
Steering Play 2Tanks ATV Repair and Maintenance 8 07-16-2016 06:23 AM
Highlifter steering radius limitation JWD1000XP Polaris Highlifter 14 02-18-2016 05:56 PM
steering play in handle bars side to side on 1000XP JWD1000XP Polaris Sportsman XP 1000 7 12-23-2015 07:36 PM
