Steering Play Fix - Polaris ATV Forum
 5Likes
post #1 of 26 (permalink) Old 05-05-2018, 01:09 PM Thread Starter
autosport7's Avatar
Steering Play Fix
I spent the better part of my day servicing the beast.
Last night I installed my Cecco Diff cover. This morning I went and picked up some diff fluid to replace what I lost during the install. While there I figured Iíd snag a inner/outer tie rod ends as Iíve generated some play in my steering from left to right.
While talking with my service tech, he told me about a trick.
Below the power steering unit, there is a stem that connects to the bracket where your tie rod ends connect. He said to check that for play. I told him I was aware but that I had tightened that bolt already and it hasnít helped and that the bolt was as tight as it could be. He said, nonono, drip RED loctite in the splines of the lower steering stem and let it dry. Once itís dry, drip some more, repeat one more time and let it sit over night and then tighten that bolt again.
I figure what do I have to lose...?
As soon as I got back from the dealer I followed his directions. I left to go install a water heater at one of my rental properties, came back and tightened that bolt down. In the process, I snapped the bolt... I snapped that garbage, stretched Polaris provided bolt with a 1/4Ē drive with a long ass extension! Piece of garbage!
I went to Loweís and picked up a hardened steel replacement, came home, fiddle dicked around trying to get the nut on the other side, placed some RED loctite on it and cranked that bitch down.
Steering play is GONE! Feels like a brand new machine again!
The idea behind the RED loctite is to obviously stiffen it up in there, but also to harden and keep water and mud out as it does corrode and wear!
2015 Polaris Scrambler XP1000
Red Bull Graphics Kit
Spider Graphix - Footwell Dacals
Mud Motorsports Gripper Seat Cover
Rogue Grille - Blk/Blk/Red
Pure Polaris Hand Warmers
Pure Polaris Thumb Warmer
GBC Grim Reaper - 26/9/14 - 26/11/14 on Hiper Sidewinder Beadlocks
All Balls Wheel Bearings FR/RR
ROX Speed FX Foot Pegs
CECCO Frame Braces FR/RR
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Moog SSB Upgrade W/ Custom Zerk
Powermadd Sentinel Handguards
Renthal G169 Grips
Gear
Leatt 5.5 V.05 Turbine - Helmet
Oakley Airbrake - Goggles
EVS Sport - Chest/Back Protector
OGIO Dakar - 3L Hydration Pack
Shift Recon - Pants/Jersey/Gloves
Alpinestars MXGP - Jersey
Alpinestars S-MX Air Carbon Mesh - Gloves
Alpinestars Tech 8 - Boots
autosport7 is offline
post #2 of 26 (permalink) Old 05-05-2018, 01:32 PM Thread Starter
autosport7's Avatar
Tech told me when they sell a machine, they always drip the loctite down there when prepping them. They also do this on all their personal machines and has done wonders.
I said well you didnít do it to mine!
He said depending on how busy they are and what tech preps the machine it may not get done.
I did hear this from them before but hadnít got around to doing it and when talking to him this morning figured what better time than now.
Glad I took the time! Nothing worse than feeling bad about your machine, now I feel like every part of the Scrambler has been serviced and is ready to roll for the spring.
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Renthal G169 Grips
Gear
post #3 of 26 (permalink) Old 05-05-2018, 03:54 PM
Gulf550's Avatar
Dang thanks for posting this. I have been fighting Handel bar play since I purchased mine and can't stand it. I've also snapped my bolt. I will try what you suggested.
Gulf550 is offline
post #4 of 26 (permalink) Old 05-05-2018, 04:05 PM Thread Starter
autosport7's Avatar
You will be amazed!
Also had up and down play of my bars along with the left to right play.
For the up and down play, I replaced the upper steering stem bushing. Was great for about 1 ride, then back to play.
A fellow member (chronix) shipped me a Moog automotive bushing that he had customized with a grease zerk. I installed that, greased her up and wuhluh! All steering play now gone! Feels like a brand new machine again!
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Renthal G169 Grips
Gear
post #5 of 26 (permalink) Old 05-05-2018, 07:50 PM
sportsmandan's Avatar
Attachment 108066
Attachment 108074
Attachment 108082
Attachment 108090
thanks for posting this, good info, did u feel free play when moving bars left to right with quad on the ground or when checking for play with atv jacked up ?
I sometimes feel a little play but figured it was in lower steering bushing,
2016 Scrambler 1000 xp
GSE single slip on muffler
Direction2 flares
2016 Sportsman 570 non ebs
Direction2 flares
ITP XTR radials
sportsmandan is offline
post #6 of 26 (permalink) Old 05-06-2018, 05:12 AM Thread Starter
autosport7's Avatar
Attachment 108066
Attachment 108074
Attachment 108082
Attachment 108090
Felt play on the ground as well.
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Renthal G169 Grips
Gear
post #7 of 26 (permalink) Old 05-06-2018, 06:17 AM
shane-o's Avatar
I did the exact same thing to my cousins 550 , he has about 3000 miles since and still like new only concern would be having to remove it in the future , but likely wouldn't need to unless replacing eps unit
2015 xp 1000 black pearl,
-polaris front and rear bumpers
-polaris hand/thumb warmers
-polaris body guard
-gse slip on
-front diff fix
-cecco frame braces
-lock and ride front box.
-dobeck fuel controller
-big horn originals/mega mayhems depending on the ride
shane-o is offline
post #8 of 26 (permalink) Old 05-06-2018, 06:24 AM Thread Starter
autosport7's Avatar
Nah removal be just fine. It isnít JB Weld. The lower bracket would come off the splines no problem then just take a wire wheel to the splines and theyíd come clean with little effort.
I wish I had known about this when I bought it. It would save a lot of wear/tear on those splines. When I looked at mine I could def tell there was corrosion taking place.
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Renthal G169 Grips
Gear
post #9 of 26 (permalink) Old 05-06-2018, 07:21 AM
you can just use a bit of heat to liquify the lock tight if need be.
Direction2 flares
Direction2 flares
ITP XTR radials
post #10 of 26 (permalink) Old 05-06-2018, 11:23 AM Thread Starter
autosport7's Avatar
Been busy as hell today but just went out and checked the steering again after letting it sit all night and majority of the day today. I cannot believe how tight the steering is now!
CECCO Diff Cover
Uni Air Filter
EPI Clutch
Big Gun Exhaust
Renthal G169 Grips
Gear
2016 Sportsman 570 Steering Stem Skeaking Like Hell! How To Fix?? Matt_Justice Polaris Sportsman 570 3 11-11-2016 07:13 AM
Play in Steering after replacing Post moore3cam Polaris XP 7 09-07-2016 05:40 PM
Steering Play 2Tanks ATV Repair and Maintenance 8 07-16-2016 06:23 AM
Highlifter steering radius limitation JWD1000XP Polaris Highlifter 14 02-18-2016 05:56 PM
steering play in handle bars side to side on 1000XP JWD1000XP Polaris Sportsman XP 1000 7 12-23-2015 07:36 PM
