Superwinch Wiring - Page 2 - Polaris ATV Forum
post #11 of 22 (permalink) Old 12-16-2018, 11:51 AM
bp405's Avatar
No it should go battery, breaker, contactor, winch.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #12 of 22 (permalink) Old 12-18-2018, 07:36 PM Thread Starter
Kleiss1's Avatar
Thanks I’ll try it out when I get home this weekend. Thanks guys for all your great help. More questions to follow I’m sure.
Kleiss1 is offline
post #13 of 22 (permalink) Old 12-23-2018, 10:22 AM Thread Starter
Kleiss1's Avatar
I got it all wired up temporarily and when I turn key on and hit the switch the solenoid/contractor just clicks. I’ve check and rechecked everything. I’m stumped. Anybody?
Kleiss1 is offline
post #14 of 22 (permalink) Old 12-23-2018, 02:56 PM
Sprotsman's Avatar
Did you wire in the hand held remote? I eliminated that god awful thing. Try doing it using this and at least for now eliminate the hand held control. I later wired in a wireless remote that works great.
Sprotsman is offline
post #15 of 22 (permalink) Old 12-23-2018, 03:52 PM Thread Starter
Kleiss1's Avatar
I tried with the handlebar switch and hand held nothing. If I touch my battery charger leads directly to the Winch terminals should it work?
Kleiss1 is offline
post #16 of 22 (permalink) Old 12-23-2018, 04:54 PM
bp405's Avatar
Yes!!! Bump it to see if it turns. Is this winch brand new?
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #17 of 22 (permalink) Old 12-23-2018, 05:18 PM Thread Starter
Kleiss1's Avatar
Yes it’s new from Cabalas. Tried touching the terminals and it just hums. Must be bad winch. Crap, everything is all bolted in too. My luck.
Kleiss1 is offline
post #18 of 22 (permalink) Old 12-23-2018, 05:56 PM
bp405's Avatar
If that battery you're using to power the winch is a good battery then unfortunately that winch sounds like it's bad.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #19 of 22 (permalink) Old 12-23-2018, 06:11 PM Thread Starter
Kleiss1's Avatar
Okay now it gets interesting. If I take the wires off the winch motor and touch the battery charger leads to it it spools in and reverse the leads and it spools out. Maybe the contactor?
Kleiss1 is offline
post #20 of 22 (permalink) Old 12-24-2018, 04:45 AM
bp405's Avatar
I'm assuming you're directly powering the winch with the battery and eleiminating the contactor!?!?!?!
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
Pre Wired Winch harness and SuperWinch Terra 35 marcus556 Polaris Sportsman 570 17 01-10-2019 02:05 PM
Superwinch Installation Experiance badbeef67 ATV Gear and Gadgets 27 12-17-2018 02:52 PM
2006 polaris outlaw 500 wiring harness munchie93 ATV Repair and Maintenance 1 06-11-2018 06:35 AM
AWD switch wiring question davis911s Polaris Sportsman 0 07-23-2016 05:29 PM
2002 Sportsman 500 HO Wiring Harness Swap Ekxjar ATV Repair and Maintenance 8 05-24-2016 06:36 AM
