2016 Sportsman - "Lo 9.7" error code" - Polaris ATV Forum
post #1 of 19 (permalink) Old 12-18-2018, 12:54 PM Thread Starter
stout93's Avatar
Hi folks,
Don't visit the forum too often but thought I could reach out to you guys for some advice.
Tried starting my 2016 Sportsman 570 last weekend and it would turn over but not start. I charged the battery today and tried starting it and just got the click, click, click.
I see the error code "Lo 9.7". Tried Google but only see error codes 10.8, 10.9....
I'm no hard cord ATVer so any advice would be appreciated. Thanks
stout93 is offline
post #2 of 19 (permalink) Old 12-18-2018, 01:00 PM
mvn
mvn's Avatar
I'm thinking your voltage is low at 9.7 volts.
Mark
2012 850HO Touring EPS Pearl White
27" ITP XTR radials on 14" ITP SS212 wheels
Ricochet skid plates & A-arm guards
Rubberdown 1 1/2" lift
Cecco frame braces
JC Capri bushings
Rotopax fuel packs on custom mounts
Garmin 60CSx with Ram mount
Polaris 2500# winch with synthetic rope
Polaris front & rear brush guards
Polaris bar & thumb heaters
Polaris passenger grip heaters
NGK (6043) ILZKAR7A10 plugs
Good, fast, cheap.....pick 2!
mvn is offline
post #3 of 19 (permalink) Old 12-18-2018, 01:07 PM
sportsmandan's Avatar
Originally Posted by stout93 View Post
Hi folks,
first thing u need to do is check acid level in battery and add distilled water if low,
charge battery at lowest setting and see if it charges completely.
start quad and see if u get above 14 volts while quad running, if u do go get battery tested it might be shot.
if u dont have 14 volts i would start with replacing voltage regulator.
2016 Scrambler 1000 xp
GSE single slip on muffler
Direction2 flares
2016 Sportsman 570 non ebs
Direction2 flares
ITP XTR radials
sportsmandan is offline
post #4 of 19 (permalink) Old 12-18-2018, 04:55 PM
bp405's Avatar
Battery is discharged. Charge it. Load test it. If it's good fire up the wheeler and read the voltage while it running. Let us know how you make out.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #5 of 19 (permalink) Old 12-19-2018, 02:10 PM Thread Starter
stout93's Avatar
I charged it but still didn't start. Just click, click, click.
Am I better off in the long run just replacing the factory battery now? If so, what battery is recommended?
stout93 is offline
post #6 of 19 (permalink) Old 12-19-2018, 03:08 PM
bp405's Avatar
I'm a fan of Odyssey AGM batteries. But a quality AGM battery can be had from a number of reputable manufacturer.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #7 of 19 (permalink) Old 12-21-2018, 10:57 AM Thread Starter
stout93's Avatar
Those are a bit spendy. I was thinking something reliable, better than the factory battery for less than $100...maybe there is no such thing however..
stout93 is offline
post #8 of 19 (permalink) Old 12-21-2018, 11:06 AM
Don't scrimp - spend the extra $ and get a quality sealed AGM battery or go the extra mile and splurge on a Lithium battery. Average battery life is about 2 years for a conventional, vented, flooded lead acid battery - the click, click, click is the vehicle telling you the battery is discharged.
latebird is online now
post #9 of 19 (permalink) Old 12-21-2018, 11:53 AM Thread Starter
stout93's Avatar
Thanks. I appreciate all the advice on this thread.
stout93 is offline
post #10 of 19 (permalink) Old 12-21-2018, 05:40 PM
Have you LOOKED at batteries lately?
You can't get a Never-Start from Walmart for less than $100.
I use Walmart batteries exclusively and they average 4-5 years if you keep them charged.
polman500 is offline
Service manuals cookies ATV Repair and Maintenance 1100 08-12-2019 09:38 AM
2000 Polaris Sportsman 500 damn_newf Polaris Sportsman 4 11-25-2018 11:48 AM
