best battery charger /maintainer - Polaris ATV Forum
 4Likes
post #1 of 17 (permalink) Unread 04-04-2019, 06:59 AM Thread Starter
pokey's Avatar
What do you all consider to be the best battery chargers or maintainers for atvs. I had a Shumacher 10 amp that boiled an ag battery last winter it was an automatic type but was probably 25 yrs old so I keep an eye on when I have to use now. Also what size do you need for a atv.
pokey is offline
post #2 of 17 (permalink) Unread 04-04-2019, 09:43 AM
KH42-X2's Avatar
I use this one by Stanley, got it on sale for ~$15
https://www.amazon.com/STANLEY-BC8S-...r=8-7-fkmrnull
KH42-X2 is offline
post #3 of 17 (permalink) Unread 04-04-2019, 10:46 AM
I use Battery Tender brand - great warranty - have had two replaced in the last 5 years - I have 2 regular, two Jr., one 6 volt and one lithium - I use them on all my vehicles including my Dodge Dakota RT, Ford F-150 and Mercury Grand Marquis (the dodge has only had 10 miles put on it in the last year, my wife's Mercury only gets driven about 3 or 4 times a month and makes a couple trips to Wisconsin every year - we put 20,000 miles on it in 6 years - the F-150 has a faulty GEM and will turn on the cargo light randomly running the battery down) - I use them in my shop and on all my toys. I'm sure the Yuasa charger is just as good, but I can get Battery Tender's cheaper.
The one from Stanley is an 8/2 amp unit - the battery in an ATV usually calls for a charge rate of less than 2 amps - the Battery Tender charges at 1.25 amps for lead acid and the lithium charger charges at 750 milliamps. 2 amps can damage a small battery.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #4 of 17 (permalink) Unread 04-04-2019, 11:12 AM
PoPo3's Avatar
Your problem is using way to big of charger. Never go over 2 amp. I have been using the Harbor Freight unit for 20 years and they work good as others I have owned. And they only cost $9.99
https://www.harborfreight.com/automa...ger-42292.html
PoPo3 is offline
post #5 of 17 (permalink) Unread 04-04-2019, 11:52 AM
The Harbor Freight one is a 500 milliamp - should be safe for all lead acid batteries, but will take longer to charge fully - perfect for long term storage - I still recommend using an outlet timer to turn power off to the charger when the battery has been fully charged - turn it on for an hour or more daily to maintain the battery at a fully charged state.
FPD218 likes this.
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
latebird is offline
post #6 of 17 (permalink) Unread 04-04-2019, 12:15 PM
SlowRoller's Avatar
I like CTEK stuff. Use this, had it on my ranger for years went well. Works on the atv so far as well. It's $$ but you asked for best
https://www.amazon.com/CTEK-56-353-1.../dp/B000FRLO9Y
18' 850SP
SlowRoller is offline
post #7 of 17 (permalink) Unread 04-04-2019, 12:31 PM
The only thing wrong with the CTEK 7002 is it has an 8 amp output - it can damage an ATV battery
The CTEK 3300 @ 500 ma would be a better choice and cheaper too
https://www.amazon.com/dp/B000FQBWCY..._t1_B000FRLO9Y
SlowRoller likes this.
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
latebird is offline
post #8 of 17 (permalink) Unread 04-04-2019, 12:41 PM
SlowRoller's Avatar
Thanks! I'll have to grab one and not use my 7002 on it! Does dropping the 1A make a big difference? Asking out of curiosity, I'm simple when it comes to electronics sometimes!
18' 850SP
post #9 of 17 (permalink) Unread 04-04-2019, 01:40 PM
Yes - one amp makes a difference
2 amps continuous on a car battery will burn it up over a long period of time (might take a month or more) - 1 amp continuous on an ATV battery will burn it up in about the same period of time it takes 2 amps to burn up a car battery. 1/2 amp continuous (24/7) on an ATV battery will burn it up within a year. Automatic ATV chargers start at 1.25 to 1.5 amps till the battery reaches 80% charge, then it drops off to about .25 amps till 90% charged, then drops to 100 ma continuous - even at 100 ma 24/7 the battery can be damaged - that's why I plug my chargers into outlet timers - turn the charger on for an hour or two each day - when the charger is off there is a back drain from the battery through the charger - this simulates battery usage - then turn the charger back on till it reaches a full charge and shut it off again - might take an hour or more, so you have to monitor it for awhile to see how long it takes for the charger to go into float mode - once the cycle has been determined, set the timer and forget it (not totally - need to check it occasionally to make sure it has not failed - that can ruin a battery also) - you can remove the battery, disconnect it or leave it installed - important thing to do is keep the battery in a cool place while in storage - a constant temperature is best - I like to keep my long term storage batteries in a refrigerator and then charge them every 30 days.
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
latebird is offline
post #10 of 17 (permalink) Unread 04-04-2019, 01:52 PM
SlowRoller's Avatar
2 maps continuous on a car battery will burn it up over a long period of time (might take a month or more) - 1 amp continuous on an ATV battery will burn it up in about the same period of time it takes 2 amps to burn up a car battery. 1/2 amp continuous (24/7) on an ATV battery will burn it up within a year. Automatic ATV chargers start at 1.25 to 1.5 amps till the battery reaches 80% charge, then it drops off to about .25 amps till 90% charged, then drops to 100 ma continuous - even at 100 ma 24/7 the battery can be damaged - that's why I plug my chargers into outlet timers - turn the charger on for an hour or two each day - when the charger is off there is a back drain from the battery through the charger - this simulates battery usage - then turn the charger back on till it reaches a full charge and shut it off again - might take an hour or more, so you have to monitor it for awhile to see how long it takes for the charger to go into float mode - once the cycle has been determined, set the timer and forget it (not totally - need to check it occasionally to make sure it has not failed - that can ruin a battery also) - you can remove the battery, disconnect it or leave it installed - important thing to do is keep the battery in a cool place while in storage - a constant temperature is best - I like to keep my long term storage batteries in a refrigerator and then charge them every 30 days.
Thanks for taking the time to explain that too me. Cleared a few things up and gives me a better idea of what's going on. Ordered the smaller CTEK.
18' 850SP
NGK V Power or Iridium? RNL79 ATV Performance Modifications 10 02-14-2019 06:55 AM
Polaris Ground Cable Lenght Hondov65 ATV General Discussion 3 02-06-2019 08:46 AM
New to Forum. Needing help!!! PerkFarmPA ATV New Members 10 10-31-2017 05:23 PM
2012 550 X2 battery upgrade Stormrider1961 ATV Repair and Maintenance 1 01-16-2017 11:31 AM
battery charger connection fj5gtx Polaris Sportsman 570 8 12-27-2016 10:41 AM
