Oil injection - Polaris ATV Forum
post #1 of 12 (permalink) Old 05-09-2019, 07:09 PM Thread Starter
Fishmousta's Avatar
Oil injection
2005 trailblazer heavy exhaust smoke. The bike would not start so I pulled the bowl and found it full of oil. I drained it, re-installed, starts and runs good but is exhausting a lot of blue smoke. No carb adjustments have been made since it was new. Is there a common problem with the oil injection using too much oil or is there something else that is defective?
Fishmousta is offline
post #2 of 12 (permalink) Old 05-10-2019, 05:30 AM
Two strokes that have been setting can have a pool of oil on the crankcase floor - it typically takes a long time (10 to 20 minutes) of moderate running to lift all the oil off the crankcase floor and start running normally. Time will vary depending on the type and amount of oil, type of fuel used, speed the engine is run at and some other less important things. Run it for a half hour or more and then report on the amount smoke.
Most common problem with the oil pump is wrong type of oil and operator cable hanging up.
latebird is offline
post #3 of 12 (permalink) Old 05-10-2019, 06:55 AM Thread Starter
Fishmousta's Avatar
Thank you for the reply. I ran it for about 5 minutes the other day thinking it would clear out. I was thinking it may be accumulation of oil in the crankcase. Without the service manual, I wasn't sure if there was a drain on the bottom of the crankcase to empty from. No binding on the cables.
post #4 of 12 (permalink) Old 05-10-2019, 08:32 AM
When you say no binding on the cables, you can see the oil pump operate and it is returning to it's stop pin as the throttle is closed?
What kind of oil is in the tank? Polaris blue?
latebird is offline
post #5 of 12 (permalink) Old 05-10-2019, 03:26 PM Thread Starter
Fishmousta's Avatar
I can see the oil pump arm rest on its stop and open completely at full throttle. I assume that if It was left sitting with the throttle partially open It could seep through the pump? It has used Polaris blue since it was new.
post #6 of 12 (permalink) Old 05-11-2019, 05:00 AM
Whether the throttle is partially open or not, oil can seep through the pump
latebird is offline
post #7 of 12 (permalink) Old 05-11-2019, 05:43 AM Thread Starter
Fishmousta's Avatar
Well that sucks. Is that inherent problem with these? We have had this bike since new and never had this problem.
post #8 of 12 (permalink) Old 05-11-2019, 10:55 AM
It's inherent to all two strokes with oil pumps and the higher the oil tank is located above the pump the more likely it is to happen - happens on older vehicles more so than new ones and the problem is exacerbated with alcohol blended fuel over non-ethanol fuel.
Just drive it and don't concern yourself about the smoke unless it is getting oil from somewhere else (like the counter balance in the 400) which the 250 doesn't have - only thing you can do is monitor the oil usage to make sure is is not using at an extraordinary rate.
latebird is offline
post #9 of 12 (permalink) Old 05-11-2019, 12:22 PM Thread Starter
Fishmousta's Avatar
Thanks for the advice. I'll rip on it once this rain let's up so I can post an update.
post #10 of 12 (permalink) Old 05-16-2019, 08:18 PM Thread Starter
Fishmousta's Avatar
After about 30 minutes of moderate riding, the thick cloud of oil smoke started to look normal. I guess it just needs to ridden more often.
Polaris xplorer 250 white smoke Luisra07 Polaris Xplorer and Xpedition 2 10-15-2018 05:15 PM
Need help asap please! Stuck oil injection shaft tb 250???? ironmikektm525 Polaris ATV How-Tos 1 06-16-2017 01:46 AM
2014 Sportsman 570 Oil-Filters rotor Polaris Sportsman 570 23 06-01-2017 05:16 PM
2006 Ranger 700 XP Rebuilt, Oil on top of pistons liquidcourage ATV Repair and Maintenance 3 01-02-2017 03:26 PM
oil injection pump? blainflake ATV Repair and Maintenance 6 06-24-2016 02:04 PM
