Hi, is there any adjustment for the camber on the 570 EPS? I just got mine back from the dealer. They did the fuel line safety recall and I had them check the steering out. I am concerned about the play in the steering. I had installed 1.5 inch spacers on all wheels for chain clearance, ran it all winter long and no problems. A couple days ago I rode it and stop to talk to a neighbor no problems. When I started back home the front end seemed loose and wobbly. The tech at the dealer said there were some low voltage codes and that he needed to update the software in the EPS and ECU. Then he proceeded to tell me that the spacers are not recommended and put undo stress on the steering box. He then said that is why there is too much camber in the front tires. I removed the spacers but they still have the camber. Any ideas would be greatly appreciated.
Tim
Tim
