2017 sportsman 1000xp overheating - Polaris ATV Forum
 1Likes
  • 1 Post By polman500
post #1 of 7 (permalink) Old 07-15-2019, 04:27 PM Thread Starter
Codyo518's Avatar
Bike keeps overheating 10 minutes into riding the radiator is clean fan kicks on and have plenty of fluid....recently put a big gun slip on exhaust on don't know if that would have any reason for it to cause the over heating just trying to find any other reasons it could be
Codyo518 is offline
post #2 of 7 (permalink) Old 07-15-2019, 09:13 PM
sportsmandan's Avatar
it goes into limp mode ??
temp light comes on ?????
check engine light comes on ??
any stored codes ???
Plenty of members have aftermarket mufflers and i've never seen anyone have a issue with one other than its too loud !
2016 Scrambler 1000 xp
GSE single slip on muffler
Direction2 flares
2016 Sportsman 570 non ebs
Direction2 flares
ITP XTR radials
sportsmandan is offline
post #3 of 7 (permalink) Old 07-15-2019, 10:09 PM Thread Starter
Codyo518's Avatar
It goes into limp mode..check engine light comes on and I haven't had a chance to check the codes.....I was going to try and see if u could bleed any air out of the system to see if that helps
Codyo518 is offline
post #4 of 7 (permalink) Old 07-16-2019, 08:38 AM
most times the rad looks really clean but u really need to get in there and flush rad out with water from behind it going in between fan blades and from sides,
i've had it happen once , u can see dirt mud but its stuck in there, if u have already done that than u can park on a small hill or lift front of quad to purge air out and burp hose but if u have not just replaced fluid its probably not air in system,
obviously never open cap if fluid is not cold or then u could suck air in system, let fan cycle on off a couple of times with front jacked up or parked on hill.
did u check underneath quad to see if weeping hole is dripping when quad is warmed up ?
Direction2 flares
Direction2 flares
ITP XTR radials
post #5 of 7 (permalink) Old 07-16-2019, 08:46 AM
bp405's Avatar
Are both rad hoses getting hot???? T-stat may not be opening!!
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #6 of 7 (permalink) Old 07-20-2019, 03:27 AM
camlaw's Avatar
If it started overheating after ya installed aftermarket muffler..ya problem is it's running too lean..these machines are real lean stock from factory..but checking ya radiator is important..might look clean. But alot of dirt can hide in their
camlaw is offline
post #7 of 7 (permalink) Old 07-20-2019, 05:02 AM
Cody, you do know that the grill just pops right out to make cleaning the radiator very easy to clean on your machine don't you? Just press down and pull out on the tab at the top of the grill.
sportsmandan likes this.
polman500 is online now
